求大佬们帮解决,感谢!
以下是OpenHARMony 4.1的启动信息: [ 1647.919512] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c40000000000 crc ab [ 1647.928516] w1_master_driver w1_bus_master1: Family 0 for 00.c40000000000.ab is not registered. LoongArch Initializing ... RAM(Cache AS RAM) Initializing ... Lock Scache Done. Copy spl code to locked scache... Jump to board_init_f... Enter board_init_f... _ __ __ _ _ ___ ___ __ _ _ / ___ __ \ | | | | | |\ | | __ [__ | | |\ | | | __ | \ | |___ |__| |__| | \| |__] ___] |__| | \| \ |__] |__/ / ============ddr4 init and training done!======== Trying to boot from BootSpace U-boot start ... Jump to board_init_f... U-Boot 2022.04-v2.0.0-00488-g864ea2f8 (Aug 01 2024 - 10:36:46 +0800) CPU: LA264 Speed: Cpu @ 997 MHz/ Mem @ 800 MHz/ Bus @ 200 MHz Model: loongson-2k300 Board: LS2K300-PAI DRAM: 512 MiB 512 MiB Jump to board_init_r.... Core: 36 devices, 20 uclasses, devicetree: board WDT: Not starting watchdog_d SF: Detected w25q16cl with page size 256 Bytes, erase size 4 KiB, total 2 MiB bdinfo is in spi-flash MMC: Card did not respond to voltage select! : -110 mmc_init: -95, time 13 Card did not respond to voltage select! : -110 mmc_init: -95, time 13 mmc@0x16148000 - probe failed: -95 emmc@0x16140000: 0 (eMMC)Card did not respond to voltage select! : -110 mmc_init: -95, time 13 Loading Environment from SPIFlash... OK frame buffer addr: 0x900000000dc00000 In: serial Out: serial vidconsole Err: serial vidconsole Net: eth0: ethernet@0x16020000 ************************** Notice ************************** Press c to enter u-boot console, m to enter boot menu ************************************************************ Autoboot in 0 seconds 8832600 bytes read in 192 ms (43.9 MiB/s) ## Booting kernel from Legacy Image at 9000000003000000 ... Image Name: Linux-5.10.97.lsgd Image Type: LoongArch Linux Kernel Image (gzip compressed) Data Size: 8832536 Bytes = 8.4 MiB Load Address: 00200000 Entry Point: 00e0d6c8 Verifying Checksum ... OK Uncompressing Kernel Image Warning: invalid device tree. Used linux default dtb 512 MiB [ 0.000000] Linux version 5.10.97.lsgd (loongson@loongson) (loongarch64-linux-gnu-gcc (LoongArch GNU toolchain vec.32-rc2) 8.3.0, GNU ld (GNU Binutils) 2.31.1.20190122) #1 PREEMPT Tue Jul 23 10:00:28 CST 2024 [ 0.000000] Primary instruction cache 32kB, 4-way, VIPT, linesize 64 bytes. [ 0.000000] Primary data cache 32kB, 4-way, VIPT, no aliases, linesize 64 bytes [ 0.000000] Unified victim cache 1024kB 16-way, linesize 64 bytes. [ 0.000000] Unified secondary cache 0kB direct mapped, linesize 1 bytes. [ 0.000000] 64-bit Loongson Processor probed (LA264 Core) [ 0.000000] CPU0 revision is: 0014a030 (Loongson-64bit) [ 0.000000] FPU0 revision is: 00000000 [ 0.000000] cmdline:console=ttyS0,115200 rw noinitrd init=/sbin/init rootfstype=ext4 rootwait root=/dev/mmcblk0p1 mtdparts=spi0.0:924k(uboot),32k(uboot_env),4k(bdinfo),56k(dtb),8k(ddr_context) fbcon=rotate:0 panel=default root=/dev/mmcblk0p1 mtdparts=spi0.0:924k(uboot),32k(uboot_env),4k(bdinfo),56k(dtb),8k(ddr_context) fbcon=rotate:0 panel=default [ 0.000000] BPI1001 with boot flags 2. [ 0.000000] convert legacy mem map to new mem map. [ 0.000000] SMBIOS 3.0 present. [ 0.000000] DMI: Loongson LS2K300/LS2K300-PAI, BIOS 2022.04-v2.0.0-00488-g864ea2f8 04/01/2022 [ 0.000000] CpuClock = 0 [ 0.000000] The BIOS Version: 2022.04-v2.0.0-00488-g864ea2f8 [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009c000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] earlycon: ns16550a0 at MMIO 0x0000000016100000 (options '115200n8') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] - disabling initrd [ 0.000000] start_pfn=0x80, end_pfn=0x28000, num_physpages:0x7b80 [ 0.000000] Wasting 8192 bytes for tracking 128 unused pages [ 0.000000] software IO TLB: mapped [mem 0x0000000001720000-0x0000000005720000] (64MB) [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x000000000effffff] [ 0.000000] node 0: [mem 0x0000000090000000-0x000000009fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000009fffffff] [ 0.000000] On node 0, zone DMA32: 128 pages in unavailable ranges [ 0.000000] On node 0, zone DMA32: 1024 pages in unavailable ranges [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 31492 [ 0.000000] Kernel command line: earlycon console=ttyS0,115200 rw noinitrd init=/sbin/init rootfstype=ext4 rootwait root=/dev/mmcblk0p1 mtdparts=spi0.0:924k(uboot),32k(uboot_env),4k(bdinfo),56k(dtb),8k(ddr_context) fbcon=rotate:0 panel=default root=/dev/mmcblk0p1 mtdparts=spi0.0:924k(uboot),32k(uboot_env),4k(bdinfo),56k(dtb),8k(ddr_context) fbcon=rotate:0 panel=default fbcon=logo-pos:center fbcon=logo-count:1 [ 0.000000] Dentry cache hash table entries: 65536 (order: 5, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 32768 (order: 4, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 351632K/505856K available (12391K kernel code, 3820K rwdata, 3856K rodata, 384K init, 1139K bss, 121456K reserved, 32768K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. [ 0.000000] NR_IRQS: 576, nr_irqs: 576, preallocated irqs: 16 [ 0.000000] random: get_random_bytes called from start_kernel+0x350/0x4e4 with crng_init=0 [ 0.000000] Constant clock event device register [ 0.000000] clocksource: Constant: mask: 0xffffffffffffffff max_cycles: 0x3759f22983, max_idle_ns: 881590413697 ns [ 0.000006] sched_clock: 64 bits at 120MHz, resolution 8ns, wraps every 4398046511102ns [ 0.008085] Constant clock source device register [ 0.012994] Console: colour dummy device 80x25 [ 0.017546] Calibrating delay loop (skipped), value calculated using timer frequency.. 240.00 BogoMIPS (lpj=120000) [ 0.028100] pid_max: default: 32768 minimum: 301 [ 0.032853] LSM: Security Framework initializing [ 0.037543] Yama: becoming mindful. [ 0.041171] Mount-cache hash table entries: 2048 (order: 0, 16384 bytes, linear) [ 0.048671] Mountpoint-cache hash table entries: 2048 (order: 0, 16384 bytes, linear) [ 0.058646] Performance counters: loongarch/loongson64 PMU enabled, 4 64-bit counters available to each CPU. [ 0.068715] rcu: Hierarchical SRCU implementation. [ 0.074121] devtmpfs: initialized [ 0.081632] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.091524] futex hash table entries: 256 (order: -2, 6144 bytes, linear) [ 0.098943] pinctrl core: initialized pinctrl subsystem [ 0.105410] NET: Registered protocol family 16 [ 0.109928] bbox:[info][blackbox_core.c:262] wait for log part [] begin! [ 0.117648] audit: initializing netlink subsys (disabled) [ 0.123129] bbox:[info][blackbox_core.c:267] wait for log part [] end! [ 0.130468] thermal_sys: Registered thermal governor 'step_wise' [ 0.131368] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1 [ 0.164223] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.373541] random: fast init done [ 1.848641] gpio-lsirq 16104000.gpio: register irqnum=107, vhwirq-base=128, rirq-base=78 [ 1.857993] loongson-lsia-dma 1612c000.iodma: DMA driver registered [ 1.864953] vgaarb: loaded [ 1.867999] SCSI subsystem initialized [ 1.872201] ls-spi 16010000.spi: controller is unqueued, this is deprecated [ 1.879871] usbcore: registered new interface driver usbfs [ 1.885459] usbcore: registered new interface driver hub [ 1.890871] usbcore: registered new device driver usb [ 1.896145] mc: Linux media interface: v0.10 [ 1.900492] videodev: Linux video capture interface: v2.00 [ 1.906100] pps_core: LinuxPPS API ver. 1 registered [ 1.911117] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.920364] PTP clock support registered [ 1.924624] Advanced Linux Sound Architecture Driver Initialized. [ 1.932300] clocksource: Switched to clocksource Constant [ 1.938069] VFS: Disk quotas dquot_6.6.0 [ 1.942097] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes) [ 1.949338] FS-Cache: Loaded [ 1.958588] NET: Registered protocol family 2 [ 1.963285] IP idents hash table entries: 8192 (order: 2, 65536 bytes, linear) [ 1.971620] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 16384 bytes, linear) [ 1.980330] TCP established hash table entries: 4096 (order: 1, 32768 bytes, linear) [ 1.988192] TCP bind hash table entries: 4096 (order: 1, 32768 bytes, linear) [ 1.995446] TCP: Hash tables configured (established 4096 bind 4096) [ 2.002058] UDP hash table entries: 512 (order: 0, 16384 bytes, linear) [ 2.008790] UDP-Lite hash table entries: 512 (order: 0, 16384 bytes, linear) [ 2.016103] NET: Registered protocol family 1 [ 2.021042] RPC: Registered named UNIX socket transport module. [ 2.027058] RPC: Registered udp transport module. [ 2.031814] RPC: Registered tcp transport module. [ 2.036581] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.045916] Initialise system trusted keyrings [ 2.050622] workingset: timestamp_bits=46 max_order=15 bucket_order=0 [ 2.062178] zbud: loaded [ 2.066285] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.073193] NFS: Registering the id_resolver key type [ 2.078369] Key type id_resolver registered [ 2.082600] Key type id_legacy registered [ 2.086735] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.093513] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 2.100987] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 2.108703] Key type asymmetric registered [ 2.112858] Asymmetric key parser 'x509' registered [ 2.117996] io scheduler mq-deadline registered [ 2.122592] io scheduler kyber registered [ 2.126764] io scheduler bfq registered [ 2.131197] pinctrl-single 16000490.pinmux: 128 pins, size 32 [ 2.140138] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled [ 2.150672] printk: console [ttyS0] disabled [ 2.155122] 16100000.serial: ttyS0 at MMIO 0x16100000 (irq = 16, base_baud = 12500000) is a 16550A [ 2.164287] printk: console [ttyS0] enabled [ 2.164287] printk: console [ttyS0] enabled [ 2.172715] printk: bootconsole [ns16550a0] disabled [ 2.172715] printk: bootconsole [ns16550a0] disabled [ 2.183374] 16100800.serial: ttyS2 at MMIO 0x16100800 (irq = 17, base_baud = 12500000) is a 16550A [ 2.193420] [drm] LSK0300 DC found [ 2.197127] lsdc 16090000.dc: [drm] Has OF graph support [ 2.212048] brd: module loaded [ 2.220552] loop: module loaded [ 2.223746] the cryptoloop driver has been deprecated and will be removed in in Linux 5.16 [ 2.232515] probe success! [ 2.236215] SPI-UID: e6:69:b0:d5:27:5a:4f:2b:e6:69:b0:d5:27:5a:4f:2b [ 2.242734] spi-nor spi0.0: s25fl016k (2048 Kbytes) [ 2.247674] 5 cmdlinepart partitions found on MTD device spi0.0 [ 2.253624] Creating 5 MTD partitions on "spi0.0": [ 2.258468] 0x000000000000-0x0000000e7000 : "uboot" [ 2.264434] 0x0000000e7000-0x0000000ef000 : "uboot_env" [ 2.270620] 0x0000000ef000-0x0000000f0000 : "bdinfo" [ 2.276567] 0x0000000f0000-0x0000000fe000 : "dtb" [ 2.282173] 0x0000000fe000-0x000000100000 : "ddr_context" [ 2.290366] CAN device driver interface [ 2.294566] stmmaceth 16020000.ethernet: IRQ eth_wake_irq not found [ 2.300872] stmmaceth 16020000.ethernet: IRQ eth_lpi not found [ 2.306831] stmmaceth 16020000.ethernet: Cannot get CSR clock [ 2.312616] stmmaceth 16020000.ethernet: PTP uses main clock [ 2.318308] stmmaceth 16020000.ethernet: no reset control found [ 2.324529] stmmaceth 16020000.ethernet: User ID: 0x11, Synopsys ID: 0x37 [ 2.331372] stmmaceth 16020000.ethernet: DWMAC1000 [ 2.336278] stmmaceth 16020000.ethernet: DMA HW capability register supported [ 2.343448] stmmaceth 16020000.ethernet: RX Checksum Offload Engine supported [ 2.350617] stmmaceth 16020000.ethernet: COE Type 2 [ 2.355517] stmmaceth 16020000.ethernet: TX Checksum insertion supported [ 2.362249] stmmaceth 16020000.ethernet: Wake-Up On Lan supported [ 2.368433] stmmaceth 16020000.ethernet: Enhanced/Alternate descriptors [ 2.375083] stmmaceth 16020000.ethernet: Enabled extended descriptors [ 2.381555] stmmaceth 16020000.ethernet: Ring mode enabled [ 2.387068] stmmaceth 16020000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 2.394779] stmmaceth 16020000.ethernet: device MAC address 06:6b:21:4c:ee:c0 [ 2.404551] PPP generic driver version 2.4.2 [ 2.409089] PPP BSD Compression module registered [ 2.413832] PPP Deflate Compression module registered [ 2.418938] PPP MPPE Compression module registered [ 2.423773] NET: Registered protocol family 24 [ 2.428534] dwc2 16040000.otg: supply vusb_d not found, using dummy regulator [ 2.435846] dwc2 16040000.otg: supply vusb_a not found, using dummy regulator [ 2.648327] dwc2 16040000.otg: dwc2_check_params: Invalid parameter lpm=1 [ 2.655153] dwc2 16040000.otg: dwc2_check_params: Invalid parameter lpm_clock_gating=1 [ 2.663108] dwc2 16040000.otg: dwc2_check_params: Invalid parameter besl=1 [ 2.670018] dwc2 16040000.otg: dwc2_check_params: Invalid parameter hird_threshold_en=1 [ 2.678060] dwc2 16040000.otg: dwc2_check_params: Invalid parameter g_rx_fifo_size=2048 [ 2.686102] dwc2 16040000.otg: dwc2_check_params: Invalid parameter g_np_tx_fifo_size=1024 [ 2.694406] dwc2 16040000.otg: dwc2_check_param_tx_fifo_sizes: Invalid parameter g_tx_fifo_size[1]=312 [ 2.703755] dwc2 16040000.otg: dwc2_check_param_tx_fifo_sizes: Invalid parameter g_tx_fifo_size[2]=312 [ 2.713123] dwc2 16040000.otg: EPs: 7, dedicated fifos, 3016 entries in SPRAM [ 2.720692] dwc2 16040000.otg: DWC OTG Controller [ 2.725446] dwc2 16040000.otg: new USB bus registered, assigned bus number 1 [ 2.732553] dwc2 16040000.otg: irq 48, io mem 0x16040000 [ 2.738555] hub 1-0:1.0: USB hub found [ 2.742360] hub 1-0:1.0: 1 port detected [ 2.747259] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.753883] ehci-pci: EHCI PCI platform driver [ 2.758420] ehci-platform: EHCI generic platform driver [ 2.763901] ehci-platform 16080000.ehci: EHCI Host Controller [ 2.769799] ehci-platform 16080000.ehci: new USB bus registered, assigned bus number 2 [ 2.777962] ehci-platform 16080000.ehci: irq 46, io mem 0x16080000 [ 2.790317] ehci-platform 16080000.ehci: USB 2.0 started, EHCI 1.00 [ 2.797115] hub 2-0:1.0: USB hub found [ 2.800928] hub 2-0:1.0: 1 port detected [ 2.805291] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.811533] ohci-pci: OHCI PCI platform driver [ 2.816060] ohci-platform: OHCI generic platform driver [ 2.821484] ohci-platform 16088000.ohci: Generic Platform OHCI controller [ 2.828506] ohci-platform 16088000.ohci: new USB bus registered, assigned bus number 3 [ 2.836575] ohci-platform 16088000.ohci: irq 47, io mem 0x16088000 [ 2.898797] hub 3-0:1.0: USB hub found [ 2.902609] hub 3-0:1.0: 1 port detected [ 2.907069] usbcore: registered new interface driver cdc_acm [ 2.912854] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 2.920991] usbcore: registered new interface driver usb-storage [ 2.927142] usbcore: registered new interface driver option [ 2.932768] usbserial: USB Serial support registered for GSM modem (1-port) [ 2.940154] using random self ethernet address [ 2.944633] using random host ethernet address [ 2.949587] usb0: HOST MAC 92:55:96:07:ac:51 [ 2.953882] usb0: MAC 1e:fe:34:72:89:3b [ 2.957915] using random self ethernet address [ 2.962427] using random host ethernet address [ 2.966956] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [ 2.973607] g_ether gadget: g_ether ready [ 2.977703] dwc2 16040000.otg: bound driver g_ether [ 2.982947] mousedev: PS/2 mouse device common for all mice [ 2.988974] i2c /dev entries driver [ 2.994644] usbcore: registered new interface driver uvcvideo [ 3.000823] USB Video Class driver (1.1.1) [ 3.005220] gspca_main: v2.14.0 registered [ 3.009411] usbcore: registered new interface driver ov519 [ 3.014968] usbcore: registered new interface driver ov534 [ 3.020516] usbcore: registered new interface driver ov534_9 [ 3.026238] usbcore: registered new interface driver spca500 [ 3.031945] usb 1-1: new high-speed USB device number 2 using dwc2 [ 3.038196] usbcore: registered new interface driver spca501 [ 3.044048] usbcore: registered new interface driver spca505 [ 3.049771] usbcore: registered new interface driver spca506 [ 3.055492] usbcore: registered new interface driver spca508 [ 3.061192] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 3.068230] usbcore: registered new interface driver spca561 [ 3.073998] usbcore: registered new interface driver spca1528 [ 3.079865] usbcore: registered new interface driver gspca_zc3xx [ 3.085938] usbcore: registered new interface driver usbtv [ 3.091456] Driver for 1-wire Dallas network protocol. [ 3.096912] gpio-68 (onewire): enforced open drain please flag it properly in DT/ACPI DSDT/board file [ 3.108281] ls2x-wdt 16124000.syscon: Loongson2 Watchdog driver registered [ 3.118709] ls2k_sdio 16140000.sdio: Use exclusive dma engine. [ 3.208445] hub 2-1:1.0: USB hub found [ 3.217441] hub 2-1:1.0: 4 ports detected [ 3.537118] ls2k_sdio 16148000.sdio: Use exclusive dma engine. [ 3.556479] ls2k_sdio 16148000.sdio: Got CD GPIO [ 4.179034] hid: raw HID events driver (C) Jiri Kosina [ 4.189482] usbcore: registered new interface driver usbhid [ 4.207299] usbhid: USB HID core driver [ 4.219369] hilog major get : 241 [ 4.227470] device_create succ [ 4.239299] hilog_init Start0 [ 4.249411] zrhung hung_wp_screen_init start [ 4.264328] zrhung hung_wp_screen_init done [ 4.279342] ls2k300_adc 1611c000.adc: ADC Device registered successfully [ 4.302018] access_token_id: access_tokenid init success [ 4.319906] loongson-i2sp loongson-i2s-dai: Set xfs <128> ... [ 4.376332] xt_time: kernel timezone is -0000 [ 4.390534] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully [ 4.409373] Initializing XFRM netlink socket [ 4.420817] NET: Registered protocol family 10 [ 4.439991] Segment Routing with IPv6 [ 4.447898] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 4.471926] NET: Registered protocol family 17 [ 4.482321] NET: Registered protocol family 15 [ 4.498536] can: controller area network core [ 4.511411] NET: Registered protocol family 29 [ 4.524300] can: raw protocol [ 4.535304] can: broadcast manager protocol [ 4.545315] can: netlink gateway - max_hops=1 [ 4.557488] 8021q: 802.1Q VLAN Support v1.8 [ 4.576419] NET: Registered protocol family 21 [ 4.587337] Key type dns_resolver registered [ 4.600787] registered taskstats version 1 [ 4.614308] Loading compiled-in X.509 certificates [ 4.627048] zswap: loaded using pool zstd/zbud [ 4.850801] ls-spi-io 1610c000.spi: controller is unqueued, this is deprecated [ 4.869626] mcp320x spi2.0: supply vref not found, using dummy regulator [ 4.892981] [drm] LSK0300 DC found [ 4.903555] lsdc 16090000.dc: [drm] Has OF graph support [ 4.919341] lsdc 16090000.dc: [drm] output-0 is a DPI panel [ 4.938344] lsdc 16090000.dc: [drm] bridge-0 attached to encoder-0 [ 4.956301] lsdc 16090000.dc: [drm] number of outputs: 1 [ 4.970350] lsdc 16090000.dc: [drm] display pipe 0 initialized [ 4.993752] [drm] Initialized lsdc 1.0.0 20200701 for 16090000.dc on minor 0 [ 5.117653] Console: switching to colour frame buffer device 128x37 [ 5.150338] lsdc 16090000.dc: [drm] fb0: lsdcdrmfb frame buffer device [ 5.524415] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search. [ 5.587380] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.602884] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.621304] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.638303] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.655304] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.671306] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.688304] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.704303] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 5.721304] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.738304] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.754303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.771303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.787303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.798599] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.813304] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.827333] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.846303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.862303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.879303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.895303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.912310] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.928303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.945304] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.961303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.978303] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 5.994304] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.002588] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.010889] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.019187] mmc0: new high speed MMC card at address 0001 [ 6.024651] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.033434] mmcblk0: mmc0:0001 08A391 7.28 GiB [ 6.038142] mmcblk0boot0: mmc0:0001 08A391 partition 1 4.00 MiB [ 6.044155] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.052516] mmcblk0boot1: mmc0:0001 08A391 partition 2 4.00 MiB [ 6.059175] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.067966] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.076385] mmcblk0: p1 [ 6.080159] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.089831] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.098123] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.106388] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.114675] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.122942] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.131203] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.139456] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.147754] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.156025] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.164280] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.172533] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.180786] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.189040] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.197299] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.205552] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.213897] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.222416] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.230928] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.244408] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.252963] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.261488] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.275441] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.283806] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.292160] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.300420] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.308686] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.316944] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.325203] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.333500] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.341757] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.350013] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.358329] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.366585] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.374842] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.383099] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.391355] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.399618] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.407949] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.416206] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.424471] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.432729] es8328 0-0011: ASoC: error at soc_component_read_no_lock on es8328.0-0011: -5 [ 6.441093] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.552363] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 6.560719] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.569233] es8328 0-0011: ASoC: error at soc_component_write_no_lock on es8328.0-0011: -5 [ 6.577570] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.586099] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.594613] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.603133] es8328 0-0011: ASoC: error at snd_soc_component_update_bits on es8328.0-0011: -5 [ 6.612739] [I/osal_cdev] register hdf class success [ 6.617967] [I/osal_cdev] add cdev dev_mgr success [ 6.617967] [ 6.624479] [I/osal_cdev] add cdev devsvc_mgr success [ 6.624479] [ 6.631147] [I/devmgr_service] start svcmgr result 0 [ 6.636243] [I/hcs_blob_if] CheckHcsBlobLength: the blobLength: 15724, byteAlign: 1 [ 6.644475] [I/device_node] launch devnode [ 6.648775] [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:0, count:106) [ 6.657315] [I/gpio_manager] GpioManagerAdd: start:0 count:106 added success! [ 6.664585] [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:0, count:106) succeed! [ 6.674200] [I/linux_gpio_adapter] LinuxGpioInit: dev service: init done! [ 6.681145] [I/device_node] launch devnode HDF_PLATFORM_GPIO_MANAGER [ 6.687619] [I/gpio_service] GpioServiceBind: enter! [ 6.692701] [I/gpio_service] GpioServiceBind: success! [ 6.698069] [I/osal_cdev] add cdev HDF_PLATFORM_GPIO_MANAGER success [ 6.698069] [ 6.706042] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_EMMC [ 6.715141] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_MMC_0, ret = -207 [ 6.723273] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_SDIO [ 6.732364] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_MMC_2, ret = -207 [ 6.740495] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_WATCHDOG [ 6.749933] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_WATCHDOG_0, ret = -207 [ 6.758500] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_RTC [ 6.767505] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_RTC, ret = -207 [ 6.775490] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_UART [ 6.784582] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_UART_1, ret = -207 [ 6.792823] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_UART [ 6.801914] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_UART_0, ret = -207 [ 6.810133] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_REGULATOR_MANAGER [ 6.820356] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_REGULATOR_MANAGER, ret = -207 [ 6.829563] [I/device_node] launch devnode HDF_PLATFORM_I2C_MANAGER [ 6.835948] [I/i2c_core] I2cManagerBind: enter! [ 6.840590] [E/devnode_ext] device service interface is null [ 6.846365] [I/device_node] release devnode HDF_PLATFORM_I2C_MANAGER [ 6.852837] [I/i2c_core] I2cManagerRelease: enter! [ 6.857737] [I/i2c_core] I2cManagerRelease: no service binded! [ 6.863687] [E/devmgr_service] devmgr detach device 501 not found [ 6.869901] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_I2C_MANAGER, ret = -205 [ 6.878557] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver linux_regulator_adapter [ 6.888171] [E/devhost_service_clnt] failed to AddDevice , ret = -207 [ 6.894756] [I/device_node] launch devnode [ 6.899052] [I/i2c_linux_adapter] LinuxI2cInit: enter! [ 6.904308] [I/i2c_linux_adapter] LinuxI2cProbe: enter! [ 6.909657] [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 0 add success! [ 6.916741] [I/i2c_linux_adapter] LinuxI2cProbe: enter! [ 6.922087] [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 1 add success! [ 6.929169] [I/i2c_linux_adapter] LinuxI2cInit: done! [ 6.934336] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_SPI [ 6.943346] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_SPI_2, ret = -207 [ 6.951477] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_SPI [ 6.960480] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_SPI_1, ret = -207 [ 6.968611] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_SPI [ 6.977631] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_SPI_0, ret = -207 [ 6.985766] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_PWM [ 6.994771] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_PWM_1, ret = -207 [ 7.002901] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_PLATFORM_PWM [ 7.011904] [E/devhost_service_clnt] failed to AddDevice HDF_PLATFORM_PWM_0, ret = -207 [ 7.020033] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_MIPI_TX [ 7.028598] [E/devhost_service_clnt] failed to AddDevice HDF_MIPI_TX, ret = -207 [ 7.036158] [I/device_node] launch devnode hdf_dsoftbus [ 7.041498] [E/"hdf_dsoftbus"] softbus driver bind success [ 7.047097] [E/"hdf_dsoftbus"] init softbus module manager success [ 7.053483] [I/osal_cdev] add cdev hdf_dsoftbus success [ 7.053483] [ 7.060331] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_VIBRATOR [ 7.068988] [E/devhost_service_clnt] failed to AddDevice hdf_misc_vibrator, ret = -207 [ 7.077032] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_LINEAR_VIBRATOR [ 7.086296] [E/devhost_service_clnt] failed to AddDevice hdf_misc_linear_vibrator, ret = -207 [ 7.094991] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_MGR_AP [ 7.104082] [E/devhost_service_clnt] failed to AddDevice hdf_sensor_manager_ap, ret = -207 [ 7.112488] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_WIFI [ 7.120794] [E/devhost_service_clnt] failed to AddDevice hdfwifi, ret = -207 [ 7.128010] [I/device_node] launch devnode hdf_input_host [ 7.133525] [I/HDF_LOG_TAG] HdfInputManagerInit: enter [ 7.138778] [I/HDF_LOG_TAG] HdfInputManagerInit: exit succ [ 7.144471] [I/osal_cdev] add cdev hdf_input_host success [ 7.144471] [ 7.151495] [I/device_node] launch devnode hdf_input_event1 [ 7.157186] [I/HDF_LOG_TAG] HdfTouchDriverProbe: enter [ 7.162464] [I/HDF_LOG_TAG] HdfTouchDriverProbe: main_touch exit succ [ 7.169111] [I/osal_cdev] add cdev hdf_input_event1 success [ 7.169111] [ 7.176319] [I/device_node] launch devnode hdf_touch_gt911_service [ 7.182621] [I/HDF_INPUT_DRV] HdfGoodixChipInit: enter [ 7.187923] [I/HDF_LOG_TAG] ChipMatchCheck: boardNode's father name = touch0, chipNode's grandpa name = touch0 [ 7.198073] [E/HDF_LOG_TAG] SetTiming: enable = 0 [ 7.344352] [E/HDF_LOG_TAG] InputI2cRead: i2c read err [ 7.349608] [E/HDF_INPUT_DRV] ChipDetect: read chip version failed [ 7.355905] [I/HDF_LOG_TAG] ChipDriverInit: reset chip 1 time [ 7.361775] [E/HDF_LOG_TAG] SetTiming: enable = 1 [ 7.544342] [E/HDF_LOG_TAG] InputI2cRead: i2c read err [ 7.549595] [E/HDF_INPUT_DRV] ChipDetect: read chip version failed [ 7.555893] [I/HDF_LOG_TAG] ChipDriverInit: reset chip 0 time [ 7.561761] [E/HDF_LOG_TAG] SetTiming: enable = 1 [ 7.640319] [I/device_node] release devnode hdf_touch_gt911_service [ 7.650302] [I/HDF_INPUT_DRV] HdfGoodixChipRelease: goodix chip is release [ 7.664302] [E/devmgr_service] devmgr detach device 2000202 not found [ 7.677304] [E/devhost_service_clnt] failed to AddDevice hdf_touch_gt911_service, ret = -204 [ 7.695333] [I/device_node] launch devnode [ 7.699659] [I/HDF_LOG_TAG] LoadCachedHid: exit [ 7.704327] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_BL [ 7.716303] [E/devhost_service_clnt] failed to AddDevice hdf_bl, ret = -207 [ 7.730303] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver PWM_BL [ 7.746302] [E/devhost_service_clnt] failed to AddDevice , ret = -207 [ 7.759302] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver LCD_ICN9700 [ 7.776304] [E/devhost_service_clnt] failed to AddDevice , ret = -207 [ 7.789303] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HI351XX_DISP [ 7.807303] [E/devhost_service_clnt] failed to AddDevice , ret = -207 [ 7.820303] [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_DISP [ 7.837302] [E/devhost_service_clnt] failed to AddDevice hdf_disp, ret = -207 [ 7.851321] [I/hdf_power_manager] HdfPmTaskQueueInit HdfTaskQueueCreate success [ 7.866362] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 8.166550] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 8.181335] ALSA device list: [ 8.184327] #0: PAI ES8388 [ 8.249884] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 8.258637] cfg80211: failed to load regulatory.db [ 8.598146] EXT4-fs (mmcblk0p1): recovery complete [ 8.603350] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null) [ 8.611581] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 8.617811] devtmpfs: mounted [ 8.621651] Freeing unused kernel memory: 384K [ 8.626128] This architecture does not have kernel memory protection. [ 8.632622] Run /sbin/init as init process __ /\ \ \ \ \ ___ ___ ___ __ ____ ___ ___ \ \ \ __ / __ \ / __ \ / _ \ / _ \ / ,__\ / __ \ / _ \ \ \ \L\ \/\ \L\ \/\ \L\ \/\ \/\ \/\ \L\ \/\__, `\/\ \L\ \/\ \/\ \ \ \____/\ \____/\ \____/\ \_\ \_\ \____ \/\____/\ \____/\ \_\ \_\ \/___/ \/___/ \/___/ \/_/\/_/\/___L\ \/___/ \/___/ \/_/\/_/ /\____/ \_/__/ [RCS]: /etc/init.d/S00devs mknod: /dev/console: File exists mknod: /dev/ttyS0: File exists mknod: /dev/null: File exists [RCS]: /etc/init.d/S01mdev [RCS]: /etc/init.d/S02_check_boot [RCS]: /etc/init.d/S03resizerootfs Rootfs Resized. [RCS]: /etc/init.d/S30dbus Starting system message bus: [ 8.716609] [pid=83][Init][INFO][init_adapter.c:91]ExecuteRcs, child process id 83. [ 9.262393] random: dbus-daemon: uninitialized urandom read (12 bytes read) [ 9.290247] random: dbus-daemon: uninitialized urandom read (12 bytes read) done [RCS]: /etc/init.d/S50sshd [ 10.486340] random: crng init done Starting sshd: OK [RCS]: /etc/init.d/S70vsftpd Starting vsftpd: OK [RCS]: /etc/init.d/S80network [ 10.700884] stmmaceth 16020000.ethernet eth0: PHY [stmmac-0:00] driver [YT8531 Gigabit Ethernet] (irq=POLL) [ 10.720353] stmmaceth 16020000.ethernet eth0: No Safety Features support found [ 10.727625] stmmaceth 16020000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported [ 10.736088] stmmaceth 16020000.ethernet eth0: registered PTP clock [ 10.742595] stmmaceth 16020000.ethernet eth0: configuring for phy/rgmii link mode [RCS]: /etc/init.d/S82ohos ohos_service_start [ 10.805094] [pid=1][Init][INFO][init_group_manager.c:201]boot start device.boot.group [ 10.805155] [pid=1][PARAM][INFO][param_service.c:393]InitParamService pipe: /dev/unix/socket/paramservice. [ 10.813525] [pid=1][PARAM][INFO][param_base.c:204]Max selinux label 1 1 [ 10.823559] [pid=1][PARAM][INFO][param_server.c:422]Load default parameters from /system/etc/param/ohos_const. [ 10.832491] [pid=1][PARAM][INFO][param_server.c:422]Load default parameters from /vendor/etc/param. [ 10.844609] [pid=1][PARAM][INFO][param_server.c:422]Load default parameters from /system/etc/param. [ 10.854586] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.build.characteristics' error:107 [ 10.863731] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.product.model' error:107 [ 10.874098] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.product.name' error:107 [ 10.883803] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.software.model' error:107 [ 10.964659] hilog ringbuffer full, drop 8 line(s) log 01-01 08:00:10.679 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.model' error:107 01-01 08:00:10.689 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.name' error:107 01-01 08:00:10.699 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.software.model' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.manufacturer' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.brand' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.build.product' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.hardwareversion' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.bootloader.version' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.cpu.abilist' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.software.version' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.firstapiversion' error:107 01-01 08:00:10.709 1 1 E 02C02/PARAM: [param_server.c:393]Failed to set param 'const.product.hardwareprofile' error:107 01-01 08:00:10.713 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'ohos.servicectrl.reboot.' gid -1 uid 1000 01-01 08:00:10.714 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'ohos.boot.' gid -1 uid 1000 01-01 08:00:10.714 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'bootevent.param_watcher.started' gid -1 uid -1 01-01 08:00:10.715 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'startup.device.' gid -1 uid 1000 01-01 08:00:10.717 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'persist.xts.devattest.' gid -1 uid -1 01-01 08:00:10.718 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'ohos.boot.sn' gid -1 uid 0 01-01 08:00:10.718 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'const.product.udid' gid -1 uid 0 01-01 08:00:10.718 1 1 W 02C02/PARAM: [param_dac.c:170]Invalid dac for 'const.product.devUdid' gid -1 uid 0 01-01 08:00:10.720 1 1 I 02C02/PARAM: [param_dac.c:207]Load parameter label total 51 success /system/etc/param/ohos.para.dac 01-01 08:00:10.720 1 1 I 02C02/PARAM: [param_persistadp.c:48]LoadPersistParam from file /storage/data/system/param/persist_parameters paramNum 0 01-01 08:00:10.720 1 1 E 02C02/PARAM: [param_persistadp.c:38]No valid persist parameter file /storage/data/system/param/tmp_persist_parameters 01-01 08:00:10.765 1 1 I 02C01/Init: [init_config.c:108]ohos.boot.mode 01-01 08:00:10.767 1 1 E 02C01/Init: [init_jobs.c:78]ParseJob, failed to get cmds for job! 01-01 08:00:10.767 1 1 E 02C01/Init: [init_utils.c:534]Read dir :/system/etc/init failed.2 01-01 08:00:10.768 1 1 E 02C01/Init: [init_utils.c:534]Read dir :/vendor/etc/init failed.2 01-01 08:00:10.769 1 1 E 02C01/Init: [init_common_cmds.c:390]Failed to change mode " /dev/hdf/hdfwifi " to 0666, err=2 01-01 08:00:10.771 1 1 I 02C01/Init: [init_service_manager.c:1086]Service info ueventd start service bt ext parameter ueventd. 01-01 08:00:10.771 1 1 E 02C01/Init: [init_service_manager.c:1116]Cannot find service ueventd. 01-01 08:00:10.771 1 1 I 02C01/Init: [init_common_service.c:585]Service info shell starting 01-01 08:00:10.773 1 1 I 02C01/Init: [init_common_service.c:632]Service info shell(pid 146) started 01-01 08:00:10.773 1 1 I 02C01/Init: [init_common_service.c:585]Service info apphilogcat starting 01-01 08:00:10.774 1 1 I 02C01/Init: [init_common_service.c:632]Service info apphilogcat(pid 147) started 01-01 08:00:10.774 1 1 I 02C01/Init: [init_common_service.c:585]Service info foundation starting 01-01 08:00:10.780 1 1 I 02C01/Init: [init_common_service.c:632]Service info foundation(pid 148) started 01-01 08:00:10.815 1 1 I 02C01/Init: [init_common_service.c:585]Service info bundle_daemon starting 01-01 08:00:10.823 1 1 I 02C01/Init: [init_common_service.c:632]Service info bundle_daemon(pid 149) started 01-01 08:00:10.823 1 1 I 02C01/Init: [init_common_service.c:585]Service info appspawn starting 01-01 08:00:10.824 1 1 I 02C01/Init: [init_common_service.c:632]Service info appspawn(pid 150) started 01-01 08:00:10.829 1 1 I 02C01/Init: [init_common_service.c:585]Service info media_server starting 01-01 08:00:10.831 1 1 E 02C01/Init: [init[ 11.394726] [E/devmgr_service] device hdf_disp not in configed device list _common_service.c:595]start service media_server invalid, please check /bin/media_server. 01-01 08:00:10.832 1 1 E 02C01/Init: [init_service_manager.c:1123]Service media_server start failed! 01-01 08:00:10.832 1 1 I 02C01/Init: [init_common_service.c:585[ 11.424743] binder: 154:159 transaction failed 29189/-22, size 36-8 line 3290 ]Service info wms_server starting 01-01 08:00:10.834 1 1 I 02C01/Init: [init_common_service.c:632]Service info wms_server(pid 151) started 01-01 08:00:10.834 1 1 I 02C01/Init: [init_common_service.c:585]Service info hiview starting 01-01 08:00:10.835 1 1 E 02C01/Init: [init_common_service.c:595]start service hiview invalid, please check /bin/hiview. 01-01 08:00:10.835 1 1 E 02C01/Init: [init_service_manager.c:1123]Service hiview start failed! 01-01 08:00:10.835 1 1 I 02C01/Init: [init_common_service.c:585]Service info deviceauth_service starting 01-01 08:00:10.836 1 1 I 02C01/Ini[ 11.482742] binder: 154:159 transaction failed 29189/-22, size 36-8 line 3290 t: [init_common_service.c:632]Service info deviceauth_service(pid 152) started 01-01 08:00:10.838 1 1 I 02C01/Init: [init_common_service.c:585]Service info softbus_server starting 01-01 08:00:10.844 1 1 I 02C01/Init: [init_common_service.c:632]Service info softbus_server(pid 153) started 01-01 08:00:10.844 1 1 I 02C01/Init: [init_common_service.c:585]Service info devattest_service starting 01-[ 11.524832] binder: 151:163 transaction failed 29189/-22, size 36-8 line 3290 01 08:00:10.846 1 1 I 02C01/Init: [init_common_service.c:632]Service info devattest_service(pid [ 11.541558] binder: 154:159 transaction failed 29189/-22, size 36-8 line 3290 154) started 01-01 08:00:10.847[ 11.551325] [E/devmgr_service] device hdf_input_event2 not in configed device list 1 1 I 02C01/Ini[ 11.560120] binder: 155:167 transaction failed 29189/-22, size 36-8 line 3290 t: [init_common_service.c:585]Service info huks_server starting 01-01 08:00:10.855 1 1 I 02C01/Init: [init_common_service.c:632]Service info huks_server(pid 155) started 01-01 08:00:10.974 1[ 11.583528] binder: 151:163 transaction failed 29189/-22, size 36-8 line 3290 49 149 E 01100/bundle_deamon: BundleDaemon::Init(53): register default feature api success 01-0[ 11.599075] binder: 154:159 transaction failed 29189/-22, size 36-8 line 3290 1 08:00:11.206 151 151 I 02510/display_layer_c: LayerInitialize: success 01-01 08:00:11.235 157 154 I 05D00/DEVATTEST: devattes[ 11.618101] binder: 155:167 transaction failed 29189/-22, size 36-8 line 3290 t-start 01-01 08:00:11.235 157 154 I 01800/Samgr: Bootstrap core services(count:1). 01-01 08:00:11.235 157 154 I 01800/Samgr: Init service:attest_service 01-01 08:00:11.239 158 154 I 01800/[ 11.642005] binder: 151:163 transaction failed 29189/-22, size 36-8 line 3290 Samgr: Initialize Client Registry! 01-01 08:00:11.248 159 154 E 01518/IPCRPC: ipc send request [ 11.657568] binder: 154:159 transaction failed 29189/-22, size 36-8 line 3290 failed res = -32. 01-01 08:00:11.248 158 154 I 01800/Samgr: Init service attest_service success! 01-01 08:00:11.248 158 154 I 01800/Samgr: Initialized all core system services! 01-01 08:00:11.248 158 154 I 01800/Samgr: Goto next boot step return code:-9 01-01 08:00:11.276 151 151 E 02510/hdf_syscall_adapter: Failed to dispatch serv call ioctl -202 01-01 08:00:11.276 151 151 E 02510/hdf_devmgr_adapter: HdfLoadDriverByServiceName failed to load khdf driver hdf_disp 01-01 08:00:11.276 151 151 E 02510/hdf_syscall_adapter: TrytoLoadIoService: load hdf_disp driver failed 01-01 08:00:11.276 151 151 E 02510/display_layer_c: DispCmdSend:bad remote service found 01-01 08:00:11.276 151 151 E 02510/display_layer_c: cmd:DISP_CMD_GET_PANEL_INFO failure 01-01 08:00:11.276 151 151 I 02510/display_layer_c: GetLayerInstance: GetInfo failed, use default setting 01-01 08:00:11.277 151 151 D 02510/display_layer_c: GetDisplayInfo: width = 1024, height = 600, rotAngle = 0 01-01 08:00:11.292 151 151 I 02510/display_layer_c: CreateLayer: open layer success 01-01 08:00:11.307 159 154 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.310 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 0, id = 0x1010014 01-01 08:00:11.316 155 155 I 02F06/HUKS[ 11.776675] hilog ringbuffer full, drop 15 line(s) log : RegisterAbilit[ 11.783957] hilog ringbuffer full, drop 7 line(s) log y[35]: register [ 11.790222] hilog ringbuffer full, drop 10 line(s) log ability i = 1, i[ 11.796395] hilog ringbuffer full, drop 5 line(s) log d = 0x1010001 [ 11.803041] hilog ringbuffer full, drop 4 line(s) log 01-01 08:00:11.[ 11.809686] hilog ringbuffer full, drop 16 line(s) log 316 155 155 I 02[ 11.815855] hilog ringbuffer full, drop 3 line(s) log F06/HUKS: RegisterAbility[35]: register ability i = 2, id = 0x1010002 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 3, id = 0x1010065 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 4, id = 0x1010066 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 5, id = 0x1020001 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 6, id = 0x1020002 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 7, id = 0x1020066 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 8, id = 0x1020065 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 9, id = 0x1050001 01-01 08:00:11.316 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 10, id = 0x1050002 01-01 08:00:11.317 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 11, id = 0x1050066 01-01 08:00:11.317 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 12, id = 0x1060001 01-01 08:00:11.317 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 13, id = 0x1060002 01-01 08:00:11.317 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 14, id = 0x1060066 01-01 08:00:11.317 155 155 I 02F06/HUKS: RegisterAbility[35]: regi[ 11.942614] hilog ringbuffer full, drop 11 line(s) log ster ability i = 15, id = 0x1170001 01-01 08:00:11.319 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 16, id = 0x1170014 01-01 08:00:11.320 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 17, id = 0x10d0014 01-01 08:00:11.320 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 18, id = 0x10e0014 01-01 08:00:11.320 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 19, id = 0x10f0014 01-01 08:00:11.320 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 20, id = 0x11c0014 01-01 08:00:11.320 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 21, id = 0x1180001 01-01 08:00:11.321 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 22, id = 0x1180014 01-01 08:00:11.321 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 23, id = 0x1100014 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 24, id = 0x1110014 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 25, id = 0x1120014 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 26, id = 0x11d0014 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 27, id = 0x1040064 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 28, id = 0x1040065 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 29, id = 0x1040066 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 30, id = 0x1030033 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 31, id = 0x1030034 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 32, id = 0x1150000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 33, id = 0x1070000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 34, id = 0x1080000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 35, id = 0x1090000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 36, id = 0x11b0000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 37, id = 0x1160000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 38, id = 0x10a0000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 39, id = 0x10b0000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 40, id = 0x10c0000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 41, id = 0x11a0000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 42, id = 0x1140000 01-01 08:00:11.322 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 43, id = 0x1190000 01-01 08:00:11.323 155 155 I 02F06/HUKS: RegisterAbility[35]: register ability i = 44, id = 0x1130000 01-01 08:00:11.323 155 155 I 02F06/HUKS: GenerateAuthTokenKey[625]: generate At key success! 01-01 08:00:11.323 155 155 I 02F06/HUKS: HksCoreInitAuthTokenKey[659]: generate At k[ 12.232079] hilog ringbuffer full, drop 7 line(s) log ey success! 0[ 12.238451] hilog ringbuffer full, drop 2 line(s) log 1-01 08:00:11.323 155 155 I 02F06/HUKS: RecordKeyOperation[1106]: use key, path: /storage/data/service/el1/public/huks_service/maindata/hks_client/info, key alias: minfo1_****data 01-01 08:00:11.325 151 151 I 02510/HDF_LOG_TAG: GfxInitialize: gfx initialize success 01-01 08:00:11.333 151 151 I 01800/Samgr: Bootstrap core services(count:3). 01-01 08:00:11.333 155 155 I 02F06/HUKS: RecordKeyOperation[1106]: use key, path: /storage/data/service/el1/public/huks_service/maindata/hks_client/info, key alias: minfo2_****data 01-01 08:00:11.333 151 151 I 01800/Samgr: Init service:Broadcast 01-01 08:00:11.333 151 151 I 01800/Samgr: Init service:WMS 01-01 08:00:11.333 151 151 I 01800/Samgr: Init service:IMS 01-01 08:00:11.334 155 155 I 02F06/HUKS: RecordKeyOperation[1106]: use key, path: /storage/data/service/el1/public/huks_service/maindata/hks_client/info, key alias: rinfo1_****data 01-01 08:00:11.337 155 155 I 02F06/HUKS: RecordKeyOperation[1106]: use key, path: /storage/data/service/el1/public/huks_service/maindata/hks_client/info, key alias: rinfo2_****data 01-01 08:00:11.339 155 155 W 02C02/PARAM: [param_base.c:483]Param 'const.product.udid' label gid:12 uid:12 mode 0100 01-01 08:00:11.339 155 155 W 02C02/PARAM: [param_base.c:484]Cfg label 6156 gid:-1 uid:0 mode 01e8 01-01 08:00:11.339 161 151 I 01800/Samgr: Initialize Client Registry! 01-01 08:00:11.339 161 151 I 01800/Samgr: Init service Broadcast success! 01-01 08:00:11.349 163 151 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.349 162 151 I 01800/Samgr: Init service WMS success! 01-01 08:00:11.349 162 151 I 01800/Samgr: Init service IMS success! 01-01 08:00:11.349 162 151 I 01800/Samgr: Initialized all core system services! 01-01 08:00:11.349 162 151 I 01800/Samgr: Goto next boot step return code:-9 01-01 08:00:11.350 151 151 I 02510/HDF_LOG_TAG: GetInputInterface: exit succ 01-01 08:00:11.350 151 151 I 02510/HDF_LOG_TAG: OpenInputDevice: open dev1 succ, service name = hdf_input_event1 Error: init_mtd_info_open_fd: /dev/mtd2 open failed! (13) 12 12 01-01 08:00:11.351 155 155 W 02C02/PARAM: [param_base.c:483]Param 'const.product.devUdid' label gid:12 uid:12 mode 0100 01-01 08:00:11.351 155 155 W 02C02/PARAM: [param_base.c:484]Cfg label 6208 gid:-1 uid:0 mode 01e8 01-01 08:00:11.352 155 155 I 02F06/HUKS: Init[70]: HUKS service init 01-01 08:00:11.353 155 155 I 02F06/HUKS: Init[183]: HUKS feature init 01-01 08:00:11.353 151 151 I 02510/HDF_LOG_TAG: RegisterReportCallback: device1 register callback succ, evtCallbackNum = 1 01-01 08:00:11.353 155 155 I 01800/Samgr: Bootstrap core services(count:1). 01-01 08:00:11.354 155 155 I 01800/Samgr: Init service:huks_service 01-01 08:00:11.364 159 154 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.375 166 155 I 01800/Samgr: Initialize Client Registry! 01-01 08:00:11.383 167 155 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.383 166 155 I 01800/Samgr: Init service huks_service success! 01-01 08:00:11.383 166 155 I 01800/Samgr: Initialized all core system services! 01-01 08:00:11.383 166 155 I 01800/Samg[ 12.523195] hilog ringbuffer full, drop 57 line(s) log r: Goto next boo[ 12.529419] hilog ringbuffer full, drop 5 line(s) log t step return code:-9 01-01 08:00:11.407 163 151 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.423 159 154 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.423 151 151 E 02510/hdf_syscall_adapter: Failed to dispatch serv call ioctl -202 01-01 08:00:11.425 151 151 E 02510/hdf_devmgr_adapter: HdfLoadDriverByServiceName failed to load khdf driver hdf_input_event2 01-01 08:00:11.425 151 151 E 02510/hdf_syscall_adapter: TrytoLoadIoService: load hdf_input_event2 driver failed 01-01 08:00:11.426 151 151 E 02510/HDF_LOG_TAG: OpenInputDevice: fail to get io service: hdf_input_event2 01-01 08:00:11.441 167 155 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.465 163 151 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.480 159 154 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.491 167 155 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.515 163 151 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.531 159 154 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.541 167 155 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.565 163 151 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.576 148 148 I 00000/(null): Init pms service success 01-01 08:00:11.578 148 148 I 00000/(null): [DMSLITE][Init:83][dms service start success] 01-01 08:00:11.578 148 148 I 00000/PowerMgr: [power_manage_service.c] Init# Succeed to init power manager service 01-01 08:00:11.578 148 148 E 00000/PowerMgr: [running_lock_handler.c] OpenLockFile# Failed to open /proc/power/power_lock, err: No such file or directory 01-01 08:00:11.578 148 148 E 00000/PowerMgr: [running_lock_hub.c] RunningLockHubInit# Failed to init runninglock ops 01-01 08:00:11.578 148 148 E 00000/PowerMgr: [suspend_controller.c] SuspendControllerInit# Failed to init running lock hub 01-01 08:00:11.578 148 148 I 00000/PowerMgr: [power_manage_feature.c] Init# Succeed to register power manage feature 01-01 08:00:11.578 148 148 I 00000/PowerMgr: [screen_saver_feature.c] Init# Succeed to register screen saver feature 01-01 08:00:11.579 148 148 E 01800/Samgr: ParseSysCap GetJsonStream failed! 01-01 08:00:11.579 148 148 I 00000/(null): Init pms inner feature success 01-01 08:00:11.579 148 148 I 00000/(null): Init pms lite feature success 01-01 08:00:11.579 148 148 I 00000/(null): Init pms lite inner feature success 01-01 08:00:11.579 148 148 I 00000/(null): Init ipcAuth feature success 01-01 08:00:11.579 148 148 D 01100/bundlems: BundleMS start success 01-01 08:00:11.579 148 148 D 01100/bundlems: BundleMS inner feature start success 01-01 08:00:11.579 148 148 D 01100/bundlems: BundleMS feature start success 01-01 08:00:11.581 159 154 E 01518/IPCRPC: ipc send request failed res = -32. 01-01 08:00:11.582 148 148 I 01300/abilityms: AbilityManagerService::Init(47): ams starts successfully 01-01 08:00:11.582 148 148 I 01300/abilityms: AbilityInnerFeature::Init(60): ams inner feature init success 01-01 08:00:11.582 148 148 I 01300/abilityms: AbilityMgrFeature::Init(76): ams feature init success 01-01 08:00:11.582 148 148 I 01800/Samgr: Bootstrap core services(count:9). 01-01 08:00:11.582 148 148 I 01800/Samgr: Init service:Broadcast 01-01 08:00:11.582 148 148 I 01800/Samgr: Init service:permissionms 01-01 08:00:11.582 148 148 I 01800/Samgr: Init service:dtbschedsrv 01-01 08:00:11.583 148 148 I 01800/Samgr: Init service:powermgr 01-01 08:00:11.583 148 148 I 01800/Samgr: Init service:battery_device 01-01 08:00:11.583 148 148 I 01800/Samgr: Init service:battery_service 01-01 08:00:11.583 148 148 I 01800/Samgr: Init service:samgr 01-01 08:00:11.583 148 148 I 01800/Samgr: Init service:bundlems 01-01 08:00:11.583 148 148 I 01800/Samgr: Init service:abilityms 01-01 08:00:11.605 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.605 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<-2>! 01-01 08:00:11.605 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.605 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<-2>! 01-01 08:00:11.612 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.612 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<-2>! 01-01 08:00:11.612 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.612 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<-2>! 01-01 08:00:11.612 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.612 174 148 D 01800/Samgr: Remote Get Communicati[ 12.949411] hilog ringbuffer full, drop 19 line(s) log on Strategy No Permissio[ 12.963279] hilog ringbuffer full, drop 4 line(s) log n<-2>! 01-01 08[ 12.969686] hilog ringbuffer full, drop 10 line(s) log :00:11.618 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.618 180 148 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 08:00:11.618 180 148 E 01518/IPCRPC: invalid callback id. 01-01 08:00:11.618 180 148 E 01518/IPCRPC: first add death callback for handle = 2. 01-01 08:00:11.618 180 148 I 01800/Samgr: Register Endpoint<151, 2, 0> 01-01 08:00:11.624 163 151 E 01518/IPCRPC: invalid callback id. 01-01 08:00:11.624 180 148 D 01800/Samgr: Register Feature pid<151>, id<2, 0> ret:0 01-01 08:00:11.625 163 151 D 01800/Samgr: RegisterRemoteFeatures ret:0 01-01 08:00:11.625 180 148 D 01800/Samgr: Register Feature pid<151>, id<2, 1> ret:0 01-01 08:00:11.625 163 151 D 01800/Samgr: RegisterRemoteFeatures ret:0 01-01 08:00:11.625 163[ 13.045912] hilog ringbuffer full, drop 2 line(s) log 151 I 01800/Samgr: Register endpoint and iunknown f[ 13.056676] hilog ringbuffer full, drop 17 line(s) log inished! remain<[ 13.063334] hilog ringbuffer full, drop 3 line(s) log 0> iunknown! 01[ 13.069594] hilog ringbuffer full, drop 4 line(s) log -01 08:00:11.625[ 13.076289] hilog ringbuffer full, drop 10 line(s) log 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<-2>! 01-01 08:00:11.625 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.625 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<[ 13.106623] hilog ringbuffer full, drop 2 line(s) log -2>! 01-01 08:0[ 13.112823] hilog ringbuffer full, drop 4 line(s) log 0:11.625 174 148 I 01518/IPCRPC:[ 13.121730] hilog ringbuffer full, drop 2 line(s) log Internal ipc request called 01-01 08:00:11.625 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<-2>! 01-01 08:00:11.625 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.625 174 148 D 01800/Samgr: Remote Get Communication Strategy No Permission<-2>! 01-01 08:00:11.625 174 148 I 01800/Samgr: Init service battery_device success! 01-01 08:00:11.625 174 148 D 00000/PowerMgr: [power_mgr_timer_util.c] PowerMgrCreateTimer# Succeed to create timer, id: 0x55737f6b20 01-01 08:00:11.631 174 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.631 180 148 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 08:00:11.631 180 148 E 01518/IPCRPC: invalid callback id. 01-01 08:00:11.631 180 148 E 01518/IPCRPC: first add death callback for handle = 3. 01-01 08:00:11.637 180 148 I 01800/Samgr: Register Endpoint<154, 3, 0> 01-01 08:00:11.638 159 154 E 01518/IPCRPC: invalid callback id. 01-01 08:00:11.638 180 148 D 01800/Samgr: Register Feature pid<154>, id<3, 0> ret:0 01-01 08:00:11.638 159 154 D 01800/Samgr: RegisterRemoteFeatures ret:0 01-01 08:00:11.638 159 154 I 01800/Samgr: Register endpoint and iunknown finished! remain<0> iunknown! 01-01 08:00:11.638 174 148 D 01800/Samgr: Register Feature pid<1[ 13.251142] hilog ringbuffer full, drop 7 line(s) log 48>, id<0, 9> re[ 13.257898] hilog ringbuffer full, drop 1 line(s) log t:0 01-01 08:00[ 13.264054] hilog ringbuffer full, drop 1 line(s) log :11.638 174 148 I 01800/Samgr: Register server s[ 13.274305] hilog ringbuffer full, drop 4 line(s) log a id<18446744073709551615, 9> retry:1 ret:0! 01-01 08:00:11.638 174 148 D 01800/Samgr: Add Policy Success 01-01 08:00:11.638 174 148 I 01800/Samgr: Init service battery_service success! 01-01 08:00:11.638 174 148 I 01800/Samgr: Initialized all core system services! 01-01 08:00:11.638 1[ 13.311799] hilog ringbuffer full, drop 5 line(s) log 74 148 I 01800/Samgr: Goto next boot step return code:-9 01-01 08:00:11.764 150 150 I 00000/(null): RegisterAbility AceAbility 01-01 08:00:11.764 150 150 I 00000/(null): [appspawn_service.c:47][appspawn] get service name appspawn. 01-01 08:00:11.764 150 150 I 00000/(null): [appspawn_service.c:189][appspawn] register service succeed. 0x5556f3c000. 01-01 08:00:11.764 150 150 I 00000/(null): [appspawn_service.c:47][appspawn] get service name appspawn. 01-01 08:00:11.764 150 150 I 00000/(null): [appspawn_service.c:198][appspawn] register featureapi succeed. 01-01 08:00:11.799 176 148 I 01518/IPCRPC: Internal ipc re[ 13.371453] hilog ringbuffer full, drop 8 line(s) log quest called 01-01 08:00:11.799 176 148 D 01800/Samgr: Cannot Find Feature id<-1, -1> ret:-11 01-01 08:00:11.974 149 149 I 01800/Samgr: Bootstrap core services(count:1). 01-01 08:00:11.974 149 149 I 01800/Samgr: Init service:bundle_daemon 01-01 08:00:11.975 183 149 I 01800/Samgr: Initialize Client Registry! 01-01 08:00:11.975 180 148 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 08:00:11.976 180 148 E 01518/IPCRPC: invalid callback id. 01-01 08:00:11.976 180 148 E 01518/IPCRPC: first add death callback for handle = 4. 01-01 08:00:11.976 180 148 I 01800/Samgr: Register Endpoint<149, 4, 0> 01-01 08:00:11.976 184 149 E 01518/IPCRPC: invalid callback id. 01-01 08:00:11.976 180 148 D 01800/Samgr: Register Feature pid<149>, id<4, 0> ret:0 01-01 08:00:11.976 184 149 D 01800/Samgr: RegisterRemoteFeatures ret:0 01-01 08:00:11.976 184 149 I 01800/Samgr: Register endpoint and iunknown finished! remain<0> iunknown! 01-01 08:00:11.976 180 148 D 01800/Samgr: Register Feature pid<149>, id<4, 0> ret:0 01-01 08:00:11.976 183 149 I 01800/Samgr: Register server sa id<18446744073709551615, 0> retry:1 ret:0! 01-01 08:00:11.976 183 149 I 01800/Samgr: Init service bundle_daemon success! 01-01 08:00:11.976 183 149 I 01800/Samgr: Initialized all core system services! 01-01 08:00:11.976 183 149 I 01800/Samgr: Goto next boot step return code:-9 01-01 08:00:11.999 176 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:11.999 176 148 D 01800/Samgr: Judge Auth ret:0 01-01 08:00:11.999 176 148 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 08:00:11.999 176 148 I 01518/IPCRPC: current handle already exist 01-01 08:00:11.999 176 148 I 01800/Samgr: Create remote sa proxy! 01-01 08:00:11.999 184 149 I 01100/bundle_deamon: BundleDaemon::Invoke(103): bundle_daemon invoke start 9 01-01 08:00:12.003 184 149 I 01100/bundle_deamon: BundleDaemon::Invoke(103): bundle_daemon invoke start 6 01-01 08:00:12.003 184 149 E 01100/bundle_deamon: BundleDaemonHandler::RemoveFile(244): realPath fail! 01-01 08:00:12.009 176 148 I 01100/bundlems: create ZipFile instance 01-01 08:00:12.009 176 148 I 01100/bundlems: open: /system/internal/screensaver.hap 01-01 08:00:12.011 176 148 I 01100/bundlems: parse 7 central entries from /system/internal/screensaver.hap 01-01 08:00:12.011 176 148 I 01100/bundlems: extract file config.json 01-01 08:00:12.011 176 148 I 01100/bundlems: get entry by name: config.json 01-01 08:00:12.011 176 148 D 01100/bundlems: get entry successed 01-01 08:00:12.011 176 148 I 01100/bundlems: unzip with store 01-01 08:00:12.011 176 148 I 01100/bundlems: seek to entry start 0x00021d50 01-01 08:00:12.011 176 148 I 01100/bundlems: unzip with store success 01-01 08:00:12.011 176 148 I 01100/bundlems: close: /system/internal/screensaver.hap 01-01 08:00:12.016 176 148 D 01800/Samgr: SAMGR_GetSystemCapabilities begin 01-01 08:00:12.016 176 148 I 01518/IPCRPC: Internal ipc request called 01-01 08:00:12.016 176 148 D 01800/Samgr: ProcSysCap option: 4 begin 01-01 08:00:12.016 176 148 D 01800/Samgr: ProcGetAllSysCap replyNum: 0, size: 0, startIdx: 0, nextRequestIdx: 0 01-01 08:00:12.016 176 148 D 01800/Samgr: ProcSysCap end 01-01 08:00:12.016 176 148 D 01800/Samgr: SendGetAllSysCapsRequest startIdx:0, ret:0! 01-01 08:00:12.016 176 148 D 01800/Samgr: SAMGR_GetSystemCapabilities ret = 0 01-01 08:00:12.017 176 148 I 01100/bundlems: create ZipFile instance 01-01 08:00:12.017 176 148 I 01100/bundlems: open: /system/internal/cameraApp.hap 01-01 08:00:12.019 176 148 I 01100/bundlems: parse 14 central entries from /system/internal/cameraApp.hap 01-01 08:00:12.019 176 148 I 01100/bundlems: extract file config.json 01-01[ 13.715837] hilog ringbuffer full, drop 10 line(s) log 08:00:12.019 176 148 I 01100/bundlems: get entry by name: config.json 01-01 08:00:12.019 176 148 D 01100/bundlems: get entry successed 01-01 08:00:12.019 176 148 I 01100/bundlems: unzip with store 01-01 08:00:12.019 176 148 I 01100/bundlems: seek to entry start 0x0001d4b0 01-01 08:00:12.019 176 148 I 01100/bundlems: unzip with store success 01-01 08:00:12.019 176 148 I 01100/bundlems: close: /system/internal/cameraApp.hap 01-01 08:00:13.089 180 148 D 01800/Samgr: Judge Auth ret:0 01-01 08:00:13.089 194 194 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 08:00:13.095 194 194 I 01518/IPCRPC: current handle already exist 01-01 08:00:13.095 194 194 I 01800/Samgr: Create remote sa proxy! 01-01 08:00:13.095 180 148 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 08:00:13.095 194 194 I 00000/(null): [appspawn_service.c:47][appspawn] get service name appspawn. 01-01 08:00:13.097 194 194 D 01100/bundlems: DeserializeInnerBundleInfos start 01-01 08:00:13.098 194 194 D 01100/bundlems: DeserializeInnerBundleInfos finished 01-01 08:00:13.133 163 151 I 02510/display_gralloc_c: GrallocInitialize: gralloc initialize success 01-01 08:00:13.134 163 151 E 02510/display_gralloc_c: AllocMem: not support memory usage: 0x4 01-01 08:00:13.134 163 151 I 02510/display_gralloc_c: AllocMem: use System V shared memory! 01-01 08:00:13.140 194 194 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 0[ 13.849030] stmmaceth 16020000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx 8:00:13.140 194 [ 13.858778] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready 194 I 02510/display_gralloc_c: GrallocInitialize: gralloc initialize success 01-01 08:00:13.140 163 151 E 02510/display_gralloc_c: AllocMem: not support memory usage: 0x4 01-01 08:00:13.140 163 151 I 02510/display_gralloc_c: AllocMem: use System V shared memory! 01-01 08:00:13.193 194 194 I 00000/(null): Ability OnActive 01-01 08:00:13.193 194 194 I 00000/(null): AbilitySlice OnActive 01-01 08:00:13.193 194 194 I 00000/(null): perform transact ability state done [3] 01-01 08:00:13.193 180 148 I 01300/abilityms: AbilityMgrFeature::Invoke(90): ams invoke called 01-01 08:00:13.198 177 148 D 01300/abilityms: AbilityMgrHandler::AbilityTransaction(220): start 01-01 08:00:13.198 177 148 D 01300/abilityms: AbilityWorker::AbilityTransaction(86): ability token(51539607552), state(3) 01-01 08:00:13.198 177 148 D 01300/abilityms: AbilityActivateTask::Execute(26): start 01-01 08:00:13.530 153 153 I 05701/CommSvc: [softbus_server_stub.c:267] Init# Init success SOFTBUS_SERVICE=softbus_service 01-01 08:00:13.530 153 153 I 01800/Samgr: Bootstrap core services(count:1). 01-01 08:00:13.530 153 153 I 01800/Samgr: Init service:softbus_service 01-01 08:00:13.530 199 153 I 01800/Samgr: Initialize Client Registry! 01-01 08:00:13.537 180 148 I 01518/IPCRPC: ipc skeleton wait for proxy init 01-01 08:00:13.537 180 148 E 01518/IPCRPC: invalid callback id. 01-01 08:00:13.537 180 148 E 01518/IPCRPC: first add death callback for handle = 9. 01-01 08:00:13.537 180 148 I 01800/Samgr: Register Endpoint<153, 9, 0> 01-01 08:00:13.537 200 153 E 01518/IPCRPC: invalid callback id. 01-01 08:00:13.537 180 148 D 01800/Samgr: Register Feature pid<153>, id<9, 0> ret:0 01-01 08:00:13.538 200 153 D 01800/Samgr: RegisterRemoteFeatures ret:0 01-01 08:00:13.538 200 153 I 01800/Samgr: Register endpoint and iunknown finished! remain<0> iunknown! 01-01 08:00:13.538 180 148 D 01800/Samgr: Register Feature pid<153>, id<9, 0> ret:0 01-01 08:00:13.538 199 153 I 01800/Samgr: Register server sa id<18446744073709551615, 0> retry:1 ret:0! 01-01 08:00:13.538 199 153 I 01800/Samgr: Init service softbus_service success! 01-01 08:00:13.538 199 153 I 01800/Samgr: Initialized all core system services! 01-01 08:00:13.538 199 153 I 01800/Samgr: Goto next boot step return code:-9 01-01 08:00:13.543 153 153 E 05708/CommAdapter: [softbus_adapter_thread.c:245] SoftBusConfTransPthreadAttr# pthread_attr_setstacksize failed, ret=22 01-01 08:00:13.543 153 153 E 05708/CommAdapter: [softbus_adapter_thread.c:282] SoftBusThreadCreate# SoftBusConfTransPthreadAttr failed, ret=-426442706 01-01 08:00:13.543 153 153 E 05707/CommUtils: [message_handler.c:214] StartNewLooperThread# Init DeathProcTask ThreadAttr failed 01-01 08:00:13.543 153 153 E 05707/CommUtils: [message_handler.c:460] CreateNewLooper# start fail 01-01 08:00:13.543 153 153 E 05707/CommUtils: [message_handler.c:571] LooperInit# init BusCenter looper fail. 01-01 08:00:13.543 153 153 E 05701/CommSvc: [softbus_server_frame.c:129] InitSoftBusServer# softbus looper init failed. # |
只有小组成员才能发言,加入小组>>
112 浏览 0 评论
龙芯2k0300先锋派开发板更新到OpenHarmony4.1,使用正点原子的ATK-MD0700R 7寸触摸屏时触摸没任何响应
43 浏览 0 评论
313 浏览 1 评论
[龙芯2K0300蜂鸟板] 如何查看uart 与tty 的对应关系
455 浏览 0 评论
448 浏览 0 评论
796浏览 26评论
344浏览 4评论
570浏览 3评论
1400浏览 2评论
441浏览 2评论
GMT+8, 2024-8-10 03:20 , Processed in 0.387161 second(s), Total 45, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
