GENERAL DESCRIPtiON
The AD79811 is a 16-bit, successive approximation, PulSAR® analog-to-digital converter (ADC) designed for high temperature operation. The AD7981 is capable of sample rates of up to 600 kSPS while maintaining low power consumption from a single power supply, VDD. It is a fast throughput, high accuracy, high temperature, successive approximation register (SAR) ADC, packaged in a small form factor with a versatile serial port interface (SPI). On the CNV rising edge, the AD7981 samples an analog input, IN+, between 0 V and REF with respect to a ground sense, IN−. The reference voltage, REF, is applied externally and can be set independent of the supply voltage, VDD. The device power scales linearly with throughput. The SPI-compatible serial interface also features the ability, using the SDI input, to daisy-chain several ADCs on a single, 3-wire bus and provides an optional busy indicator. It is compatible with 1.8 V, 2.5 V, 3 V, or 5 V logic, using the separate supply, VIO. For space constrained applications, the AD7981 is available in a 10-lead mini small outline package (MSOP) with operation specified from −55°C to +175°C and 10-lead ceramic flat package (FLATPACK) with operation specified from −55°C to +210°C. These packages are designed for robustness at extreme temperatures, including monometallic wire bonding, and are qualified for up to 1000 hours of operation at the maximum temperature rating. FEATURES Extreme high temperature operation Specified temperature range −55°C to +210°C (10-lead FLATPACK) −55°C to +175°C (10-lead MSOP) High performance Pseudo differential analog input range 0 V to VREF with VREF between 2.4 V and 5.1 V Throughput: 600 kSPS Zero latency architecture 16-bit resolution with no missing codes INL: ±2.5 LSB maximum, DNL: ±0.9 LSB maximum Dynamic range: 92 dB, VREF = 5 V SNR: 91 dB at fIN = 1 kHz, VREF = 5 V THD: −102 dB at fIN = 1 kHz, VREF = 5 V SINAD: 90.5 dB at fIN = 1 kHz, VREF = 5 V Low power dissipation Single-supply 2.5 V operation with 1.8 V to 5 V logic interface 2.25 mW typical at 600 kSPS (VDD only) 4.65 mW typical at 600 kSPS (total) 75 μW typical at 10 kSPS Proprietary serial interface SPI-/QSPI-/MICROWIRE-/DSP-compatible Daisy-chain multiple ADCs and busy indicator Small footprint 10-lead, 3 mm × 3 mm, monometallic wire bonding MSOP 10-lead, 0.255 inches × 0.255 inches, monometallic wire bonding FLATPACK APPLICATIONS Oil and gas exploration Avionics Heavy industrial High temperature environments Scientific instrumentation |
相关推荐 |
GMT+8, 2024-9-8 12:20 , Processed in 0.662212 second(s), Total 38, Slave 30 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
