评分 |
Error (10206): Verilog HDL Module Declaration error at test_light.v(2): top module port "light" is not found in the port list。
解决:top module需要加上port list。 |
You have more than one JTAG cable available so you must use the --cable option
to choose between them (or open the "Run/Run" or "Run/Debug" dialog and go to the "Target Connection" tab). No --cable option was provided (or you selected Automatic) 解决:有多个Target Connection:需要指定其中的USB-BLASTER[USB] |
有人发现了WARNING:
module Tube( CLK, RST_N, DATA, SEL ); input CLK; input RST_N; output [7:0]DATA; output [7:0]SEL; //数码管公共端 reg [7:0]DATA_R; reg [23:0]TIME_CNT; reg [3:0]NUM; //------------------------------------------------------ //计时 TIME_CNT always @( posedge CLK or negedge RST_N) begin if(!RST_N) TIME_CNT <= 24'B0; else TIME_CNT <= TIME_CNT + 1'B1; end //------------------------------------------------------------- //每2的24次方时钟周期,数字+1 always @( posedge CLK or negedge RST_N) begin if(!RST_N) NUM <= 4'h0; else if(TIME_CNT == 24'hFF_FFFF) NUM <= (NUM == 9)? 4'H0 : NUM + 4'B1; end //---------------------------------------------------------- parameter num_0 = 8'b1100_0000, num_1 = 8'b1111_1001, num_2 = 8'b1010_0100, num_3 = 8'b1011_0000, num_4 = 8'b1001_1001, num_5 = 8'b1001_0010, num_6 = 8'b1000_0010, num_7 = 8'b1111_1000, num_8 = 8'b1000_0000, num_9 = 8'b1001_0000; //------------------------------------------------------------------ always @(NUM)begin case(NUM) 0 : DATA_R = num_0; 1 : DATA_R = num_1; 2 : DATA_R = num_2; 3 : DATA_R = num_3; 4 : DATA_R = num_4; 5 : DATA_R = num_5; 6 : DATA_R = num_6; 7 : DATA_R = num_7; 8 : DATA_R = num_8; 9 : DATA_R = num_9; default : ; endcase end //--------------------------------------------------------------------- assign DATA = DATA_R; assign SEL = 8'b1111_0001; endmodule 仿真成功,下载到板上也没问题。但有个警告 Warning (10240): Verilog HDL Always Construct warning at Tube.v(46): inferring latch(es) for variable "DATA_R", which holds its previous value in one or more paths through the always construct Warning: Latch DATA_R[0] has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal NUM[1]............................... 想知道怎样才没有这警告。。。。 分析WARNING,猜测感觉代码风格不完整,出现竞争现象,容易不稳定,但是数码管显示可以稳定,因为小于1Ns的不稳定肉眼不察觉; 改代码为: //9 : DATA_R = num_9; default : DATA_R = num_9; |
Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
解决:把它们设置成三态高阻 |
沙发: 在test_light.v文件中, 输入输出端口没有端口light,但内部定义了一个端口为light的信号.
板凳: 下载器选择问题 马扎: 响应的模块将会生成一个组合逻辑, 而不完整的状态输出将会产生latch. 使得系统提示不稳定.所以只是一个warning. 地板: 因为一些不用管脚,不设定就会导致它输出未知,所以要使得外界输入输出对芯片无影响,可以把它们设定为3态。 |
emmyundf 发表于 2012-7-19 16:51 请问下怎么指定其中的USB-BLASTER[USB]啊?。。 |
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
252 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1501 浏览 0 评论
907 浏览 0 评论
855 浏览 0 评论
658 浏览 0 评论
4427 浏览 63 评论
/9
GMT+8, 2025-12-2 21:20 , Processed in 0.790112 second(s), Total 97, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
