make[1]: Entering directory `/mnt/Share/esp_iot_sdk_v1.1.1/app'
make[2]: Entering directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/user' DEPEND: xt-xcc -M -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle user_main.c DEPEND: xt-xcc -M -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle global_unit.c make[2]: Leaving directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/user' make[2]: Entering directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/user' xt-xcc -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -o .output/eagle/debug/obj/global_unit.o -c global_unit.c xt-xcc -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -o .output/eagle/debug/obj/user_main.o -c user_main.c xt-ar ru .output/eagle/debug/lib/libuser.a .output/eagle/debug/obj/global_unit.o .output/eagle/debug/obj/user_main.o make[2]: Leaving directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/user' make[2]: Entering directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/driver' make[2]: Leaving directory `/mnt/Share/esp_iot_sdk_v1.1.1/app/driver' xt-xcc -L../lib -nostdlib -T../ld/eagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lmain -ljson -lupgrade -lssl -lpwm -lsmartconfig user/.output/eagle/debug/lib/libuser.a driver/.output/eagle/debug/lib/libdriver.a -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out /opt/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .output/eagle/debug/image/eagle.app.v6.out section `.text' will not fit in region `iram1_0_seg' collect2: error: ld returned 1 exit status |
1个回答
这个错误信息提示编译器在尝试将生成的代码放入ESP8266或ESP32的内部RAM(通常称为`iram1`)时遇到了问题。`.text`是程序的文本(代码)段,而`iram1_0_seg`是内部RAM的一个区域。错误表明编译后的代码大小超出了这个区域的大小限制。
### 可能的原因: 1. **代码太大**:程序中的代码或静态数据可能过多,导致生成的`.text`段超出了内部RAM的限制。 2. **优化级别**:编译选项中可能使用了不恰当的优化级别,导致生成的代码体积过大。 3. **未使用的代码**:可能存在大量未使用的代码或数据,这些可以通过更严格的优化选项去除。 4. **内存分配**:程序可能在内部RAM中分配了过多的静态或全局变量。 ### 解决方法: 1. **检查代码**:审查代码,移除不必要的功能和未使用的变量。 2. **优化级别调整**:尝试使用不同的优化级别。例如,使用`-Os`(优化空间)而不是`-O2`(优化速度)。 3. **链接时优化**:使用`-Wl,--gc-sections`选项来移除未使用的代码和数据段。 4. **内存分析**:使用工具如`size`或`nm`来分析程序的内存使用情况,找出占用空间大的部分。 5. **代码分割**:如果可能,尝试将一些功能模块化,以便在需要时才加载到RAM中。 6. **使用外部存储**:考虑将部分数据或代码存储到外部存储器(如SPI Flash)中,以减少内部RAM的使用。 ### 具体步骤: 1. **清理代码**:删除或注释掉未使用的代码和数据。 2. **重新编译**:在清理后重新编译,看是否问题解决。 3. **使用`size`命令**:运行`size`命令来查看各个部分的内存使用情况。 ```bash size your_binary_file.elf ``` 4. **调整优化选项**:根据`size`命令的输出调整编译选项。 5. **使用链接时优化**:在Makefile中添加`-Wl,--gc-sections`选项。 ### 示例Makefile修改: ```make CFLAGS += -Os -Wl,--gc-sections ``` 这些步骤应该能帮助你诊断和解决`.text`段超出`iram1_0_seg`区域的问题。如果问题依旧存在,可能需要更深入地分析代码结构和编译选项。 |
只有小组成员才能发言,加入小组>>
429浏览 6评论
362浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
343浏览 5评论
349浏览 4评论
327浏览 4评论
GMT+8, 2024-9-1 07:40 , Processed in 0.703402 second(s), Total 83, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
