你好,我通过JTAG下载程序在软件WICED-Studio-6.2上对开发板下载程序是遇到困难?下载失败。下载过程如下:
09:30:38 **** Build of configuration Default for project 43xxx_Wi-Fi **** " E:UsersAdministratorDocumentsWICED-Studio-6.243xxx_Wi-Fimake.exe" CYW943907AEVAL1FJTAG=jlink-native"JLINK_PATH=E:Program FilesSEGGERJLink/" JLINK_EXE=Jlink.exe 下载运行 MAKEFILE MAKECMDGOALS=test.console-CYW943907AEVAL1F 下载运行 OTA2_SUPPORT 已禁用 正在构建引导加载程序 waf.bootloader-NoOS-NoNS-CYW943907AEVAL1F-P103-SoC.43909 使用 jlink_native,忽略 sflash_write_app ... prgm hdr cnt=3 total_size = 15492, entry_point = 0x696000 Loadsegment_offset = 0xA0 segment_size = 15256, segment_pad = 0 Loadsegment_offset = 0x3C40 segment_size = 32, segment_pad = 0 Loadsegment_offset = 0x3C68 segment_size = 204, segment_pad = 0 完成构建引导加载程序 测试。console-CYW943907AEVAL1F ----------------------------------|---------|---------| | | | 静态 | 模块 | 闪存 | RAM | ----------------------------------+---------+---------| App | 0 | 22466 | command_console | 0 | 4154 | command_console_ethernet | 0 | 1042 | command_console_FS | 0 | 13924 | command_console_mallinfo | 0 | 1057 | 0 | 1057 | command_console_P2P | 0 | 15645 | command_console_ping | 0 | 11511 | command_console_platform | 0 | 3286 | command_console_thread | 0 | 1034 | command_console_thread | 0 | 11511 | command_console_platform | 0 | 3286 | 1034 | command_console_wifi | 0 | 47987 | command_console_WPS | 0 | 3680 | crc | 0 | 1060 | DHCP_Server | 0 | 1562 | DNS | 0 | 136 | FileX | 0 | 23836 | 中断。23836 | Interrupt Vectors | 0 | 290 | iperf | 0 | 27300 | libc | 0 | 57847 | Linked_List | 0 | 434 | mbedTLS | 0 | 88698 | Networking | 0 | 32312 | NetX-Duo - 接口 Stacks | 0 | 16 | NVRam | 0 | 2210 | Other | 0 | 158165 | Packet Buffers | 0 | 146584 | platform | 0 | 843 | RAM Initialisation | 32 | 0 | resources | 0 | 32 | Ring_Buffer | 0 | 138 | Startup Stack Link Script fill | 0 | 408 | Supplicant - 支持者BESL | 0 | 34410 | ThreadX | 0 | 13340 | TLV | 0 | 216 | WICED | 0 | 10319 | wiced_log | 0 | 1578 | Wiced_RO_FS | 0 | 1358 | wifi_utils | 0 | 1789 | WWD | 0 | 10319 0 | 2543 | ----------------------------------+---------+---------| TOTAL (bytes) | 0 | 733210 | ----------------------------------|---------|---------| 创建文件系统 BCM94390x_targets.mk ... 下载 DCT ... build/test.console-CYW943907AEVAL1F/DCT.bin @ SFLASH_DCT_LOC=0x00008000 ./tools/common/Win32/mk_wicedfs32 ./tools/common/Win32/mk_wicedfs32 build/-CYW943907AEVAL1F/filesystem.bin build/-CYW943907AEVAL1F/resources/Staging/创建文件系统 已完成 构建应用程序查找表 SEGGER J-Link Commander V7.70 (Compiled Aug 3 2022 17:22:18) DLL version V7.70, compiled Aug 3 2022 17:20:31 成功读取 J-Link 命令文件。 处理脚本文件... J-Link>r J-Link 连接尚未建立,但命令需要。 通过 USB 连接到 J-Link......O.K. 固件:J-Link V9 已编译 2021 年 5 月 7 日 16:26:12 硬件版本:V9.60 J-Link 正常运行时间(自启动以来):不适用(此型号不支持) 编号:69667006 许可证:RDI、GDB、FlashDL、FlashBP、JFlash VTref=3.327V 目标连接尚未建立,但命令需要。 已选择设备“CYW43907”。 通过 JTAG 连接目标 TotalIRLen = 4, IRPrint = 0x01 JTAG 链检测发现 1 个设备: #0 Id:0x5BA00477, IRLen: 04, CoreSight JTAG-DP 检测到 DPv0 扫描 AP 映射以查找所有可用 AP AP[2]:由于已到达 AP 地图的尽头,因此停止 AP 扫描 AP[0]:APB-AP (IDR: 0x44770002) AP[1]:JTAG-AP (IDR: 0x24760010) 正在遍历 AP 映射以查找要使用的 APB-AP, AP[0]:找到 APB-AP ROMTbl[0][0]:CompAddr: 80001000 CID: B105900D, PID: 008BBC14 Cortex-R4 找到 Cortex-R4 r1p4 4 个代码断点,4 个数据断点 调试架构 ARMv7.0 数据字节序:小 主ID寄存器:0x411FC144 I-Cache L1:32 KB,256 组,32 字节/行,4 路 D-Cache L1:32 KB,256 组,32 字节/行,4 路 TCM类型寄存器:0x00010001 MPU类型寄存器:0x00000800 系统控制寄存器: 指令字节序:小 一级指令缓存已启用 一级数据缓存已启用 MPU 启用 使能分支预测 内存区域: 区域:默认描述:默认访问模式 区域:APB-AP(AP0)描述:AP0 地址中的 DMA 类似加速。 空间 Cortex-R4 已确定。 复位延迟:0 ms 复位类型 正常:切换复位引脚并停止 CPU 内核。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:Done ResetTarget() end J-Link>w4 0x18020634 0 Writing 00000000 -> 18020634 J-Link>loadbin build/test.console-CYW943907AEVAL1F/DCT.bin 0x14008000 'loadbin':执行隐式重置 MCU 停止。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:完成 ResetTarget() end 下载文件 [build/test.console-CYW943907AEVAL1F/DCT.bin]... J-Link:闪存下载:Bank 0 @ 0x14000000: 跳过。 内容已匹配 O.K. J-Link>qc 脚本处理已完成。 下载引导程序 ... SEGGER J-Link Commander V7.70 (Compiled Aug 3 2022 17:22:18) DLL version V7.70, compiled Aug 3 2022 17:20:31 成功读取 J-Link 命令文件。 处理脚本文件... J-Link>r J-Link 连接尚未建立,但命令需要。 通过 USB 连接到 J-Link......O.K. 固件:J-Link V9 已编译 2021 年 5 月 7 日 16:26:12 硬件版本:V9.60 J-Link 正常运行时间(自启动以来):不适用(此型号不支持) 编号:69667006 许可证:RDI、GDB、FlashDL、FlashBP、JFlash VTref=3.335V 目标连接尚未建立,但命令需要。 已选择设备“CYW43907”。 通过 JTAG 连接目标 TotalIRLen = 4, IRPrint = 0x01 JTAG 链检测发现 1 个设备: #0 Id:0x5BA00477, IRLen: 04, CoreSight JTAG-DP 检测到 DPv0 扫描 AP 映射以查找所有可用 AP AP[2]:由于已到达 AP 地图的尽头,因此停止 AP 扫描 AP[0]:APB-AP (IDR: 0x44770002) AP[1]:JTAG-AP (IDR: 0x24760010) 正在遍历 AP 映射以查找要使用的 APB-AP, AP[0]:找到 APB-AP ROMTbl[0][0]:CompAddr: 80001000 CID: B105900D, PID: 008BBC14 Cortex-R4 找到 Cortex-R4 r1p4 4 个代码断点,4 个数据断点 调试架构 ARMv7.0 数据字节序:小 主ID寄存器:0x411FC144 I-Cache L1:32 KB,256 组,32 字节/行,4 路 D-Cache L1:32 KB,256 组,32 字节/行,4 路 TCM类型寄存器:0x00010001 MPU类型寄存器:0x00000800 系统控制寄存器: 指令字节序:小 一级指令缓存已禁用 一级数据缓存已禁用 MPU 启用 使能分支预测 内存区域: 区域:默认描述:默认访问模式 区域:APB-AP(AP0)描述:AP0 地址中的 DMA 类似加速。 空间 Cortex-R4 已确定。 复位延迟:0 ms 复位类型 正常:切换复位引脚并停止 CPU 内核。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:完成 ResetTarget() end J-Link>w4 0x18020634 0 写入 00000000 -> 18020634 J-Link>loadbin build/waf.bootloader-NoOS-NoNS-CYW943907AEVAL1F-P103-SoC.43909/binary/waf.bootloader-NoOS-NoNS-CYW943907AEVAL1F-P103-SoC.43909.trx.bin 0x14000000 xml-ph-0000@deepl.internal 'loadbin':执行隐式重置 MCU 停止。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:完成 ResetTarget() end 下载文件 [build/waf.bootloader-NoOS-NoNS-CYW943907AEVAL1F-P103-SoC.43909/binary/waf.bootloader-NoOS-NoNS-CYW943907AEVAL1F-P103-SoC.43909.trx.bin]... J-Link:闪存下载:Bank 0 @ 0x14000000: 跳过。内容已匹配 O.K. J-Link>qc 脚本处理已完成。 完成下载引导程序 下载资源文件系统 ... build/test.console-CYW943907AEVAL1F/filesystem.bin at sector 17 size 125... SEGGER J-Link Commander V7.70 (Compiled Aug 3 2022 17:22:18) DLL version V7.70, compiled Aug 3 2022 17:20:31 成功读取 J-Link 命令文件。 处理脚本文件... J-Link>r J-Link 连接尚未建立,但命令需要。 通过 USB 连接到 J-Link......O.K. 固件:J-Link V9 已编译 2021 年 5 月 7 日 16:26:12 硬件版本:V9.60 J-Link 正常运行时间(自启动以来):不适用(此型号不支持) 编号:69667006 许可证:RDI、GDB、FlashDL、FlashBP、JFlash VTref=3.335V 目标连接尚未建立,但命令需要。 已选择设备“CYW43907”。 通过 JTAG 连接目标 TotalIRLen = 4, IRPrint = 0x01 JTAG 链检测发现 1 个设备: #0 Id:0x5BA00477, IRLen: 04, CoreSight JTAG-DP 检测到 DPv0 扫描 AP 映射以查找所有可用 AP AP[2]:由于已到达 AP 地图的尽头,因此停止 AP 扫描 AP[0]:APB-AP (IDR: 0x44770002) AP[1]:JTAG-AP (IDR: 0x24760010) 正在遍历 AP 映射以查找要使用的 APB-AP, AP[0]:找到 APB-AP ROMTbl[0][0]:CompAddr: 80001000 CID: B105900D, PID: 008BBC14 Cortex-R4 找到 Cortex-R4 r1p4 4 个代码断点,4 个数据断点 调试架构 ARMv7.0 数据字节序:小 主ID寄存器:0x411FC144 I-Cache L1:32 KB,256 组,32 字节/行,4 路 D-Cache L1:32 KB,256 组,32 字节/行,4 路 TCM类型寄存器:0x00010001 MPU类型寄存器:0x00000800 系统控制寄存器: 指令字节序:小 一级指令缓存已禁用 一级数据缓存已禁用 MPU 启用 使能分支预测 内存区域: 区域:默认描述:默认访问模式 区域:APB-AP(AP0)描述:AP0 地址中的 DMA 类似加速。 空间 Cortex-R4 已确定。 复位延迟:0 ms 复位类型 正常:切换复位引脚并停止 CPU 内核。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:Done ResetTarget() end J-Link>loadbin build/test.console-CYW943907AEVAL1F/filesystem.bin 0x14011000 'loadbin':执行隐式重置 MCU 停止。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:完成 ResetTarget() end 下载文件 [build/test.console-CYW943907AEVAL1F/filesystem.bin]... J-Link:闪存下载:Bank 0 @ 0x14000000: 跳过。 内容已匹配 O.K. J-Link>qc 脚本处理已完成。 下载 APP0 build/test.console-CYW943907AEVAL1F/binary/test.console-CYW943907AEVAL1F.stripped.elf @ sector 142 address 581632 size 126... SEGGER J-Link Commander V7.70 (Compiled Aug 3 2022 17:22:18) DLL version V7.70, compiled Aug 3 2022 17:20:31 成功读取 J-Link 命令文件。 处理脚本文件... J-Link>r J-Link 连接尚未建立,但命令需要。 通过 USB 连接到 J-Link......O.K. 固件:J-Link V9 已编译 2021 年 5 月 7 日 16:26:12 硬件版本:V9.60 J-Link 正常运行时间(自启动以来):不适用(此型号不支持) 编号:69667006 许可证:RDI、GDB、FlashDL、FlashBP、JFlash VTref=3.345V 目标连接尚未建立,但命令需要。 已选择设备“CYW43907”。 通过 JTAG 连接目标 TotalIRLen = 4, IRPrint = 0x01 JTAG 链检测发现 1 个设备: #0 Id:0x5BA00477, IRLen: 04, CoreSight JTAG-DP 检测到 DPv0 扫描 AP 映射以查找所有可用 AP AP[2]:由于已到达 AP 地图的尽头,因此停止 AP 扫描 AP[0]:APB-AP (IDR: 0x44770002) AP[1]:JTAG-AP (IDR: 0x24760010) 正在遍历 AP 映射以查找要使用的 APB-AP, AP[0]:找到 APB-AP ROMTbl[0][0]:CompAddr: 80001000 CID: B105900D, PID: 008BBC14 Cortex-R4 找到 Cortex-R4 r1p4 4 个代码断点,4 个数据断点 调试架构 ARMv7.0 数据字节序:小 主ID寄存器:0x411FC144 I-Cache L1:32 KB,256 组,32 字节/行,4 路 D-Cache L1:32 KB,256 组,32 字节/行,4 路 TCM类型寄存器:0x00010001 MPU类型寄存器:0x00000800 系统控制寄存器: 指令字节序:小 一级指令缓存已禁用 一级数据缓存已禁用 MPU 启用 使能分支预测 记忆区域: 区域:默认 描述:默认访问模式 区域:APB-AP(AP0)描述:AP0 地址中的 DMA 类似加速。 空间 Cortex-R4 已确定。 复位延迟:0 ms 复位类型 正常:切换复位引脚并停止 CPU 内核。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:Done ResetTarget() end J-Link>loadbin build/test.console-CYW943907AEVAL1F/binary/test.console-CYW943907AEVAL1F.stripped.elf.bin 0x1408E000 'loadbin':执行隐式重置 MCU 停止。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:完成 ResetTarget() end 下载文件 [build/test.console-CYW943907AEVAL1F/binary/test.console-CYW943907AEVAL1F.stripped.elf.bin]... J-Link:闪存下载:Bank 0 @ 0x14000000: 跳过。 内容已匹配 O.K. J-Link>qc 脚本处理已完成。 下载 wiced_apps.mk 中的应用程序查找表 ... build/test.console-CYW943907AEVAL1F/APPS.bin @ 0x00010000 大小 SEGGER J-Link Commander V7.70 (Compiled Aug 3 2022 17:22:18) DLL version V7.70, compiled Aug 3 2022 17:20:31 成功读取 J-Link 命令文件。 处理脚本文件... J-Link>r J-Link 连接尚未建立,但命令需要。 通过 USB 连接到 J-Link......O.K. 固件:J-Link V9 已编译 2021 年 5 月 7 日 16:26:12 硬件版本:V9.60 J-Link 正常运行时间(自启动以来):不适用(此型号不支持) 编号:69667006 许可证:RDI、GDB、FlashDL、FlashBP、JFlash VTref=3.337V 目标连接尚未建立,但命令需要。 已选择设备“CYW43907”。 通过 JTAG 连接目标 TotalIRLen = 4, IRPrint = 0x01 JTAG 链检测发现 1 个设备: #0 Id:0x5BA00477, IRLen: 04, CoreSight JTAG-DP 检测到 DPv0 扫描 AP 映射以查找所有可用 AP AP[2]:由于已到达 AP 地图的尽头,因此停止 AP 扫描 AP[0]:APB-AP (IDR: 0x44770002) AP[1]:JTAG-AP (IDR: 0x24760010) 正在遍历 AP 映射以查找要使用的 APB-AP, AP[0]:找到 APB-AP ROMTbl[0][0]:CompAddr: 80001000 CID: B105900D, PID: 008BBC14 Cortex-R4 找到 Cortex-R4 r1p4 4 个代码断点,4 个数据断点 调试架构 ARMv7.0 数据字节序:小 主ID寄存器:0x411FC144 I-Cache L1:32 KB,256 组,32 字节/行,4 路 D-Cache L1:32 KB,256 组,32 字节/行,4 路 TCM类型寄存器:0x00010001 MPU类型寄存器:0x00000800 系统控制寄存器: 指令字节序:小 一级指令缓存已禁用 一级数据缓存已禁用 MPU 启用 使能分支预测 内存区域: 区域:默认描述:默认访问模式 区域:APB-AP(AP0)描述:AP0 地址中的 DMA 类似加速。 空间 Cortex-R4 已确定。 复位延迟:0 ms 复位类型 正常:切换复位引脚并停止 CPU 内核。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:Done ResetTarget() end J-Link>loadbin build/test.console-CYW943907AEVAL1F/APPS.bin 0x14010000 'loadbin':执行隐式重置 MCU 停止。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:完成 ResetTarget() end 下载文件 [build/test.console-CYW943907AEVAL1F/APPS.bin]... J-Link:闪存下载:Bank 0 @ 0x14000000: 跳过。 内容已匹配 O.K. J-Link>qc 脚本处理已完成。 重置目标 SEGGER J-Link Commander V7.70 (Compiled Aug 3 2022 17:22:18) DLL version V7.70, compiled Aug 3 2022 17:20:31 成功读取 J-Link 命令文件。 处理脚本文件... J-Link>r J-Link 连接尚未建立,但命令需要。 通过 USB 连接到 J-Link......O.K. 固件:J-Link V9 已编译 2021 年 5 月 7 日 16:26:12 硬件版本:V9.60 J-Link 正常运行时间(自启动以来):不适用(此型号不支持) 编号:69667006 许可证:RDI、GDB、FlashDL、FlashBP、JFlash VTref=3.333V 目标连接尚未建立,但命令需要。 已选择设备“CYW43907”。 通过 JTAG 连接目标 TotalIRLen = 4, IRPrint = 0x01 JTAG 链检测发现 1 个设备: #0 Id:0x5BA00477, IRLen: 04, CoreSight JTAG-DP 检测到 DPv0 扫描 AP 映射以查找所有可用 AP AP[2]:由于已到达 AP 地图的尽头,因此停止 AP 扫描 AP[0]:APB-AP (IDR: 0x44770002) AP[1]:JTAG-AP (IDR: 0x24760010) 正在遍历 AP 映射以查找要使用的 APB-AP, AP[0]:找到 APB-AP ROMTbl[0][0]:CompAddr: 80001000 CID: B105900D, PID: 008BBC14 Cortex-R4 找到 Cortex-R4 r1p4 4 个代码断点,4 个数据断点 调试架构 ARMv7.0 数据字节序:小 主ID寄存器:0x411FC144 I-Cache L1:32 KB,256 组,32 字节/行,4 路 D-Cache L1:32 KB,256 组,32 字节/行,4 路 TCM类型寄存器:0x00010001 MPU类型寄存器:0x00000800 系统控制寄存器: 指令字节序:小 一级指令缓存已禁用 一级数据缓存已禁用 MPU 启用 使能分支预测 内存区域: 区域:默认描述:默认访问模式 区域:APB-AP(AP0)描述:AP0 地址中的 DMA 类似加速。 空间 Cortex-R4 已确定。 复位延迟:0 ms 复位类型 正常:切换复位引脚并停止 CPU 内核。 ResetTarget() 启动 J-Link 脚本:重置 J-Link 脚本:完成 ResetTarget() end J-Link>go J-Link>loadbin 0x14000000 解析参数时出错 语法:loadbin [,] J-Link>qc 脚本处理已完成。 构建完整的 制作 .gdbinit 09:30:52 编译完成(耗时 14 秒 440ms) 麻烦帮我看看是什么问题? 还有就是工程有个警告,不知是否影响,如下: |
1个回答
以下是一些可能的原因及解决方法:
1. **JTAG连接问题**:请确保JTAG线缆连接正确,且开发板和计算机之间的连接稳定。 2. **JTAG驱动问题**:确保您的计算机已安装了正确的JTAG驱动程序。如果没有,请安装或更新驱动程序。 3. **JLink软件问题**:检查您的JLink软件版本是否与WICED Studio 6.2兼容。如果不兼容,请更新或降级JLink软件。 4. **开发板问题**:确保开发板已正确设置为JTAG模式。有些开发板需要手动设置JTAG模式,例如通过拨动开关或设置跳线。 5. **WICED Studio设置问题**:检查WICED Studio中的项目设置,确保所有路径和配置都正确。例如,确保JLINK_PATH和JLINK_EXE指向正确的文件夹和可执行文件。 6. **固件版本问题**:确保您的开发板固件版本与WICED Studio 6.2兼容。如果不兼容,请更新或降级固件。 7. **编译问题**:从您提供的信息中,我看到有一条警告信息:“正在构建引导加载程序 w”。这可能表示编译过程中存在问题。请检查编译输出,查找可能的错误或警告,并根据需要进行修复。 8. **权限问题**:确保您有足够的权限在WICED Studio中执行下载操作。如果没有,请尝试以管理员身份运行WICED Studio。 9. **防火墙或杀毒软件干扰**:有时防火墙或杀毒软件可能会阻止WICED Studio与开发板之间的通信。请检查您的防火墙和杀毒软件设置,确保它们不会干扰下载过程。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1512 浏览 0 评论
Wi-Fi 8:开启极高可靠性 (UHR) 连接的新纪元——2
1595 浏览 0 评论
5629 浏览 0 评论
你在使用WI-FI6模块PTR7002时遇到过哪些通信问题?欢迎分享解决方案!
10581 浏览 0 评论
13003 浏览 1 评论
/9
GMT+8, 2025-12-3 05:33 , Processed in 0.457773 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9667
