在 LYRAT_V4_3 开发板上,运行pipeline_play_sdcard_music例程,一运行就报一下错误
I (258) cpu_start: App cpu up. I (285) cpu_start: Pro cpu start user code I (285) cpu_start: cpu freq: 160000000 I (285) cpu_start: Application information: I (289) cpu_start: Project name: play_sdcard_music I (295) cpu_start: App version: v2.4-30-gc323b97-dirty I (302) cpu_start: Compile time: Jul 26 2022 16:07:54 I (308) cpu_start: ELF file SHA256: 2556a07c93545cfe... I (314) cpu_start: ESP-IDF: v4.4.1-dirty I (319) heap_init: Initializing. RAM available for dynamic allocation: I (326) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (332) heap_init: At 3FFB3050 len 0002CFB0 (179 KiB): DRAM I (339) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (345) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (351) heap_init: At 4008FA00 len 00010600 (65 KiB): IRAM I (359) spi_flash: detected chip: generic I (362) spi_flash: flash io: dio I (367) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (377) PLAY_SDCARD_MUSIC: [ 1 ] Mount sdcard E (537) sdmmc_sd: sdmmc_init_sd_scr: send_scr (1) returned 0x107 E (537) vfs_fat_sdmmc: sdmmc_card_init failed (0x107). E (537) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place. E (547) PERIPH_SDCARD: mount sdcard error! E (1707) sdmmc_sd: sdmmc_init_sd_scr: send_scr (1) returned 0x107 E (1707) vfs_fat_sdmmc: sdmmc_card_init failed (0x107). E (1707) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place. E (1717) PERIPH_SDCARD: mount sdcard error! E (2707) sdmmc_sd: sdmmc_init_sd_scr: send_scr (1) returned 0x107 E (2707) vfs_fat_sdmmc: sdmmc_card_init failed (0x107). E (2707) SDCARD: Failed to initialize the card (263). Make sure SD card lines have pull-up resistors in place. E (2717) PERIPH_SDCARD: mount sdcard error! |
1个回答
为了帮助您解决问题,请按照以下步骤进行排查:
1. 确保您的开发板已经连接到计算机,并且已经安装了正确的驱动程序。 2. 检查您的开发板是否有足够的电源供应。 3. 确保您的SD卡已经插入到开发板的SD卡插槽中,并且已经格式化为FAT32文件系统。 4. 检查您的开发板是否已经烧录了正确的固件。您可以尝试重新烧录固件,以确保固件是最新的。 5. 检查您的开发板是否已经连接到正确的串口。在烧录程序时,请确保选择正确的串口和波特率。 6. 如果您使用的是ESP-IDF开发环境,请确保您的环境已经设置正确,并且已经安装了所有必要的依赖项。 7. 检查您的代码是否已经正确配置了SD卡的路径和文件名。例如,确保您的代码中使用的文件路径与实际存储在SD卡上的文件路径相匹配。 8. 如果以上步骤都无法解决问题,请尝试查看开发板的日志输出,以获取更多关于错误的详细信息。这可能有助于您确定问题的根本原因。 |
只有小组成员才能发言,加入小组>>
313 浏览 0 评论
1170 浏览 1 评论
586浏览 6评论
483浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
468浏览 5评论
467浏览 4评论
442浏览 4评论
GMT+8, 2024-12-26 16:41 , Processed in 0.862461 second(s), Total 83, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
