电子发烧友论坛|
ESP32-LyraT4.3运行ADF下WWE的demo报错 Can't support stack on external memory due to ESP32 chip is 1。这个错误是什么原因产生的,应该如何去解决呢?
ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0030,len:6936 load:0x40078000,len:15512 load:0x40080400,len:4492 0x40080400: _init at ??:? entry 0x400806b4 I (27) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (27) boot: compile time 10:57:00 I (27) boot: chip revision: 1 I (30) boot_comm: chip revision: 1, min. bootloader chip revision: 0 I (37) qio_mode: Enabling default flash chip QIO I (42) boot.esp32: SPI Speed : 80MHz I (47) boot.esp32: SPI Mode : QIO I (52) boot.esp32: SPI Flash Size : 4MB I (56) boot: Enabling RNG early entropy source... I (62) boot: Partition Table: I (65) boot: ## Label Usage Type ST Offset Length I (73) boot: 0 nvs WiFi data 01 02 00009000 00004000 I (80) boot: 1 otadata OTA data 01 00 0000d000 00002000 I (87) boot: 2 phy_init RF data 01 01 0000f000 00001000 I (95) boot: 3 ota_0 OTA app 00 10 00010000 00300000 I (102) boot: 4 flash_tone Unknown data 01 27 00310000 00032000 I (110) boot: End of partition table I (114) boot: No factory image, trying OTA 0 I (119) boot_comm: chip revision: 1, min. application chip revision: 0 I (126) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=3e41ch (255004) map I (205) esp_image: segment 1: paddr=0004e444 vaddr=3ffb0000 size=01bd4h ( 7124) load I (208) esp_image: segment 2: paddr=00050020 vaddr=400d0020 size=74ce4h (478436) map I (343) esp_image: segment 3: paddr=000c4d0c vaddr=3ffb1bd4 size=00c64h ( 3172) load I (344) esp_image: segment 4: paddr=000c5978 vaddr=40080000 size=13820h ( 79904) load I (374) esp_image: segment 5: paddr=000d91a0 vaddr=50000000 size=00010h ( 16) load I (384) boot: Loaded app from partition at offset 0x10000 I (419) boot: Set actual ota_seq=1 in otadata[0] I (419) boot: Disabling RNG early entropy source... I (430) psram: This chip is ESP32-D0WD I (430) spiram: Found 64MBit SPI RAM device I (430) spiram: SPI RAM mode: flash 80m sram 80m I (433) spiram: PSRAM initialized, cache is in low/high (2-core) mode. I (441) cpu_start: Pro cpu up. I (444) cpu_start: Starting app cpu, entry point is 0x400816cc 0x400816cc: call_start_cpu1 at E:/APP_software_Install/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/cpu_start.c:155 I (0) cpu_start: App cpu up. I (923) spiram: SPI SRAM memory test OK I (931) cpu_start: Pro cpu start user code I (931) cpu_start: cpu freq: 240000000 I (931) cpu_start: Application information: I (934) cpu_start: Project name: example_wwe I (939) cpu_start: App version: 1 I (944) cpu_start: Compile time: Nov 25 2022 10:56:28 I (950) cpu_start: ELF file SHA256: 49b302ab54ea15c8... I (956) cpu_start: ESP-IDF: v4.4-dirty I (961) heap_init: Initializing. RAM available for dynamic allocation: I (968) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (974) heap_init: At 3FFB4890 len 0002B770 (173 KiB): DRAM I (980) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (987) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (993) heap_init: At 40093820 len 0000C7E0 (49 KiB): IRAM I (999) spiram: Adding pool of 4095K of external SPI memory to heap allocator I (1008) spi_flash: detected chip: generic I (1012) spi_flash: flash io: qio I (1017) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (1027) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations W (1037) AUIDO_MEM: Can't support stack on external memory due to ESP32 chip is 1 I (1047) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 I (1057) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 I (1067) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 W (1087) PERIPH_TOUCH: _touch_init E (1087) gpio: gpio_install_isr_service(449): GPIO isr service already installed I (1097) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 I (1097) ES8388_DRIVER: init,out:02, in:00 W (1107) AUDIO_BOARD: The board has already been initialized! W (1107) AUIDO_MEM: Can't support stack on external memory due to ESP32 chip is 1 ----------------------------- ESP Audio Platform ----------------------------- | | | ESP_AUDIO-v1.7.0-81-gf766253-4717e99-25dbfe4 | | Compile date: Jun 15 2022-06:58:11 | ------------------------------------------------------------------------------ I (1157) LYRAT_V4_3: I2S0, MCLK output by GPIO0 I (1157) wwe_example: Func:setup_player, Line:137, MEM Total:4426507 Bytes, Inter:308967 Bytes, Dram:259951 Bytes I (1167) wwe_example: esp_audio instance is:0x3f800b44 E (1177) I2S: register I2S object to platform failed I (1177) LYRAT_V4_3: I2S0, MCLK output by GPIO0 W (1197) AUIDO_MEM: Can't support stack on external memory due to ESP32 chip is 1 I (1207) wwe_example: Recorder has been created Deprecated Quantized wakeNet5: wakeNet5_v1_hilexin_5_0.95_0.90, mode:0 (Dec 10 2021 20:15:15) 3 Initial ONE-MIC auido front-end for speech recognition, mode:1, (Dec 10 2021 20:29:24) W (1317) RECORDER_SR: Multinet is not enabled in SDKCONFIG W (1317) AUIDO_MEM: Can't support stack on external memory due to ESP32 chip is 1 W (1327) AUIDO_MEM: Can't support stack on external memory due to ESP32 chip is 1 W (1337) AUIDO_MEM: Can't support stack on external memory due to ESP32 chip is 1 W (1457) AUIDO_MEM: Can't support stack on external memory due to ESP32 chip is 1 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2340浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2528浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 20:39 , Processed in 0.493646 second(s), Total 72, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
512
