## Environment
Audio development kit: ESP32-LyraTD-MSC Audio kit version: v2.2 [Required] Module or chip used: ESP32-WROVER-E [Required] IDF version: v5.2.1 [Required] ADF version: v2.6-108-g1f275b50 Build system: visual code/idf.py [Required] Running log: All logs from power-on to problem recurrence Compiler version : xtensa-esp-elf-gcc.exe (crosstool-NG esp-13.2.0_20230928) 13.2.0 Operating system: Windows (Windows only) Environment type: PowerShell Using an IDE?: Yes, Visual Code+ IDF extension Power supply: USB ## Problem Description ESP32-LyraTD-MSC v2.2板子不能跑 ESP-ADF wwe example, CPU会crash/死机。 当 ‘I (12132) main_task: Returned from app_main()“ log 打印后, 任何声音输入系统都不会有反应, 几十秒后, 系统就会死机 ### Expected Behavior 按照官方说明,这个板子应该能正常跑这个应用. ### Actual Behavior Crash. ### Steps to Reproduce 1. 按照https://github.com/espressif/esp-adf/tree/master/examples readme 的板子/参考应用对照表, wwe example(examples/speech_recognition/wwe)应该在 ESP32-LyraTD-MSC板子上能跑起来. 也试了另外一个参考应用VAD (examples/speech_recognition/vad) 在同一块板子上能成功跑起来. 2. In VSCode, 从wwe example创建一个应用,没改任何代码。 3. 根据ADF文档(https://docs.espressif.com/projects/esp ... tions.html),修改一些 memory/system 如下: a. Enabled SPI PSRAM. The option CONFIG_SPIRAM_CACHE_WORKAROUND, set by default in the same menu, kept enabled. b. Not enable Bluetooth. c. CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST set as “yes” d. Set CONFIG_WL_SECTOR_SIZE as 512 in Component config > Wear Levelling e. Flash SPI mode as QIO f. Flash SPI speed as 80MHz g. CPU frequency as 240MHz h. Set Default receive window size as 5 times(7200) greater than Maximum Segment Size(1440) in Component config > LWIP > TCP i. Set Flash Size as 4MB 4.根据wwe参考应用说明中 "Troubleshooting" 一节(https://github.com/espressif/esp-adf/tr ... nition/wwe), 修改espesp-adfcomponentsaudio_haldriverzl38063.c ( tw_upload_dsp_firmware(0) ===> tw_upload_dsp_firmware(-1); )进行强制dsp firmware下载。 5. 编译并运行应该,发现会死机而且log里有警告: "W (10615) RECORDER_SR: Multinet is not enabled in SDKCONFIG" , 于是在sdkconfig设置里: . enable "use multinet" . Chinese Speech Commands Model: Chinese Single Recognition(mn2_cn) . Select wake words: nihaoxiaozhi(wn5_nihaoxiaozi) 6. 重新编译并运行,还是会死机: rst:0x1 (POWERON_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0030,len:7524 load:0x40078000,len:16528 ho 0 tail 12 room 4 load:0x40080400,len:4 0x40080400: _init at ??:? load:0x40080404,len:4312 entry 0x4008065c I (31) boot: ESP-IDF v5.2.1-dirty 2nd stage bootloader I (31) boot: compile time May 7 2024 23:55:14 I (31) boot: Multicore bootloader I (35) boot: chip revision: v1.0 I (39) qio_mode: Enabling default flash chip QIO I (44) boot.esp32: SPI Speed : 80MHz I (49) boot.esp32: SPI Mode : QIO I (54) boot.esp32: SPI Flash Size : 4MB I (58) boot: Enabling RNG early entropy source... I (64) boot: Partition Table: I (67) boot: ## Label Usage Type ST Offset Length I (74) boot: 0 nvs WiFi data 01 02 00009000 00004000 I (82) boot: 1 otadata OTA data 01 00 0000d000 00002000 I (89) boot: 2 phy_init RF data 01 01 0000f000 00001000 I (97) boot: 3 ota_0 OTA app 00 10 00010000 00300000 I (104) boot: 4 flash_tone Unknown data 01 27 00310000 00032000 I (112) boot: End of partition table I (116) boot: No factory image, trying OTA 0 I (121) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=193ea0h (1654432) map I (554) esp_image: segment 1: paddr=001a3ec8 vaddr=3ffb0000 size=0285ch ( 10332) load I (557) esp_image: segment 2: paddr=001a672c vaddr=40080000 size=098ech ( 39148) load I (571) esp_image: segment 3: paddr=001b0020 vaddr=400d0020 size=50828h (329768) map I (656) esp_image: segment 4: paddr=00200850 vaddr=400898ec size=0a0a4h ( 41124) load I (679) boot: Loaded app from partition at offset 0x10000 I (717) boot: Set actual ota_seq=1 in otadata[0] I (718) boot: Disabling RNG early entropy source... I (728) cpu_start: Multicore app I (728) quad_psram: This chip is ESP32-D0WD I (729) esp_psram: Found 8MB PSRAM device I (731) esp_psram: Speed: 80MHz I (734) esp_psram: PSRAM initialized, cache is in low/high (2-core) mode. W (742) esp_psram: Virtual address not enough for PSRAM, map as much as we can. 4MB is mapped I (1214) esp_psram: SPI SRAM memory test OK I (1222) cpu_start: Pro cpu start user code I (1222) cpu_start: cpu freq: 240000000 Hz I (1222) cpu_start: Application information: I (1226) cpu_start: Project name: example_wwe I (1231) cpu_start: App version: 1 I (1236) cpu_start: Compile time: May 8 2024 10:09:58 I (1242) cpu_start: ELF file SHA256: b05478608... I (1247) cpu_start: ESP-IDF: v5.2.1-dirty I (1253) cpu_start: Min chip rev: v0.0 I (1257) cpu_start: Max chip rev: v3.99 I (1262) cpu_start: Chip rev: v1.0 I (1267) heap_init: Initializing. RAM available for dynamic allocation: I (1274) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1281) heap_init: At 3FFB3938 len 0002C6C8 (177 KiB): DRAM I (1287) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (1293) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1300) heap_init: At 40093990 len 0000C670 (49 KiB): IRAM I (1306) esp_psram: Adding pool of 4096K of PSRAM memory to heap allocator I (1314) spi_flash: detected chip: generic I (1318) spi_flash: flash io: qio W (1323) i2c: This driver is an old driver, please migrate your application code to adapt driver/i2c_master.h W (1333) ADC: legacy driver is deprecated, please migrate to esp_adc/adc_oneshot.h I (1342) main_task: Started on CPU0 I (1352) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations I (1352) main_task: Calling app_main() I (2352) SPI: ** Loading DSP firmware ret:0,Status:0 ** I (2352) SPI: b=1 I (2352) SPI: 1- Firmware boot loading started .... I (5392) SPI: prgmBase 0x00080200 I (5392) SPI: execAddr 0x00084040 I (5392) SPI: DONE I (5402) SPI: 2- Loading the image to RAM....done I (5402) SPI: -- Saving firmware to flash.... I (11002) SPI: -- Saving firmware to flash....done I (11022) SPI: 3- Loading the config file into the device RAM.... I (11192) SPI: -- Saving config to flash.... I (11432) SPI: -- Saving config to flash....done I (11632) SPI: Device boot loading completed successfully... I (11632) gpio: GPIO[22]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 I (11642) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 W (11652) AUDIO_BOARD: The board has already been initialized! ----------------------------- ESP Audio Platform ----------------------------- | | | ESP_AUDIO-v1.7.3-40-g00ffda8-dbab925-9815982 | | Compile date: Apr 12 2024-02:32:01 | I (11692) wwe_example: Func:setup_player, Line:140, MEM Total:4434152 Bytes, Inter:332075 Bytes, Dram:282103 Bytes I (11702) wwe_example: esp_audio instance is:0x3f801d10 I (11822) wwe_example: Recorder has been created I (11822) RECORDER_SR: The first wakenet model: wn5_nihaoxiaozhi I (11822) AFE_SR: afe interface for speech recognition I (11832) AFE_SR: AFE version: SR_V220727 I (11832) AFE_SR: Initial auido front-end, total channel: 2, mic num: 1, ref num: 1 I (11842) AFE_SR: aec_init: 0, se_init: 1, vad_init: 1 I (11842) AFE_SR: wakenet_init: 1 Deprecated Quantized wakenet5: wakeNet5_v1_nihaoxiaozhi_6_0.983_0.95, mode:0 (Nov 21 2023 19:15:51) Please switch to ESP32-S3 and wakenet9 ! // 请问这个需要处理吗?按照说明ESP32-LyraTD-MSC是可以支持的啊? I (11962) AFE_SR: wake num: 1, mode: 1, (Nov 21 2023 19:15:51) SINGLE_RECOGNITION: v2; (Nov 21 2023 19:40:21) W (11962) MN: MultiNet may cause WatchDog on ESP32 sometimes! //同问,既然ESP32-LyraTD-MSC可以支持,为啥还会watchdog超时?官方可以fix这个问题吗? esp_mn_commands_update_from_sdkconfig I (11972) MN_COMMAND: ---------------------SPEECH COMMANDS--------------------- I (11972) MN_COMMAND: Command ID0, phrase ID0: da kai kong tiao I (11982) MN_COMMAND: Command ID1, phrase ID1: guan bi kong tiao I (11992) MN_COMMAND: Command ID2, phrase ID2: zeng da feng su I (11992) MN_COMMAND: Command ID3, phrase ID3: jian xiao feng su I (12002) MN_COMMAND: Command ID4, phrase ID4: sheng gao yi du I (12012) MN_COMMAND: Command ID5, phrase ID5: jiang di yi du I (12012) MN_COMMAND: Command ID6, phrase ID6: zhi re mo shi I (12022) MN_COMMAND: Command ID7, phrase ID7: zhi leng mo shi I (12032) MN_COMMAND: Command ID8, phrase ID8: song feng mo shi I (12032) MN_COMMAND: Command ID9, phrase ID9: jie neng mo shi I (12042) MN_COMMAND: Command ID10, phrase ID10: chu shi mo shi I (12042) MN_COMMAND: Command ID11, phrase ID11: jian kang mo shi I (12052) MN_COMMAND: Command ID12, phrase ID12: shui mian mo shi I (12062) MN_COMMAND: Command ID13, phrase ID13: da kai lan ya I (12062) MN_COMMAND: Command ID14, phrase ID14: guan bi lan ya I (12072) MN_COMMAND: Command ID15, phrase ID15: kai shi bo fang I (12082) MN_COMMAND: Command ID16, phrase ID16: zan ting bo fang I (12092) MN_COMMAND: Command ID17, phrase ID17: ding shi yi xiao shi I (12092) MN_COMMAND: Command ID18, phrase ID18: da kai dian deng I (12102) MN_COMMAND: Command ID19, phrase ID19: guan bi dian deng I (12112) MN_COMMAND: --------------------------------------------------------- I (12132) main_task: Returned from app_main() // 这条log打印出来后系统会停在这里,无论如何说提示词毫无反应,过了几十秒,系统就崩了,崩的log如下 Guru Meditation Error: Core 0 panic'ed (LoadStoreAlignment). Exception was unhandled. Core 0 register dump: PC : 0x4011e70f PS : 0x00060730 A0 : 0x800f69c5 A1 : 0x3f826950 0x4011e70f: bitrv2 at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:234 A2 : 0x00000100 A3 : 0x00000000 A4 : 0x3f826df0 A5 : 0x4015c205 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000000 A9 : 0x7f7fffff A10 : 0xb8bd1c6d A11 : 0xbffe49e8 A12 : 0xbb360b61 A13 : 0x3f826df0 A14 : 0x003fffff A15 : 0x3ffb8470 SAR : 0x00000004 EXCCAUSE: 0x00000009 EXCVADDR: 0x4015c205 LBEG : 0x400f8841 LEND : 0x400f8866 LCOUNT : 0x00000000 0x400f8841: WindowingEnergy at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:1645 (inlined by) WebRtcNs_ProcessCore at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:1916 0x400f8866: WebRtcNs_ProcessCore at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:1917 Backtrace: 0x4011e70c:0x3f826950 0x400f69c2:0x3f8269a0 0x400f8a39:0x3f8269f0 0x400f95be:0x3f827b10 0x400f4b89:0x3f827b30 0x400f36da:0x3f827b60 0x400f3898:0x3f827b80 0x400dd015:0x3f827ba0 0x4011e70c: bitrv2 at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:230 0x400f69c2: WebRtc_rdft at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:155 0x400f8a39: FFT at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:1564 (inlined by) WebRtcNs_ProcessCore at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:1944 0x400f95be: WebRtcNs_Process at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/noise_suppression/webrtc_ns.c:2126 0x400f4b89: ns_process at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/esp_ns.c:16 0x400f36da: afe_feed_aec_init_false at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_front_end/esp_afe_sr.c:546 0x400f3898: afe_feed at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_front_end/esp_afe_sr.c:623 0x400dd015: feed_task at C:/Users/hyuan/esp/esp-adf/components/audio_recorder/recorder_sr.c:248 ELF file SHA256: b05478608 CPU halted. ================== sdkconfig file attached |
1个回答
以下是一些建议来解决您可能遇到的问题:
1. 确保您的硬件和软件环境满足ESP-ADF的要求。根据您的描述,您已经使用了ESP32-LyraTD-MSC音频开发套件,版本为v2.2,以及ESP32-WROVER-E模块。请确保您的硬件是兼容的。 2. 检查您的ESP-IDF版本。您提到使用的是v5.2.1版本。请确保这个版本与ESP-ADF的版本兼容。如果不兼容,请尝试升级或降级ESP-IDF。 3. 检查您的ESP-ADF版本。您提到的版本是v2.6-108-g1f275b50。请确保这个版本与您的ESP-IDF版本兼容。如果不兼容,请尝试升级或降级ESP-ADF。 4. 确保您的Visual Studio Code和idf.py插件是最新版本。这有助于确保编译和部署过程中没有错误。 5. 检查您的运行日志,查找可能的错误或警告。这有助于确定问题所在。如果可能,请提供更多关于问题重现的详细信息。 6. 如果您在编译过程中遇到问题,请尝试清理项目并重新编译。在Visual Studio Code的终端中,您可以使用以下命令: ``` idf.py clean idf.py build ``` 7. 如果您在部署过程中遇到问题,请尝试重新烧录固件到ESP32-LyraTD-MSC。使用以下命令: ``` idf.py flash ``` |
只有小组成员才能发言,加入小组>>
473浏览 6评论
397浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
376浏览 5评论
383浏览 4评论
353浏览 4评论
GMT+8, 2024-9-27 12:02 , Processed in 0.780008 second(s), Total 82, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
