esp32s3 芯片,编译环境是idf4.3 每次开启复位“phy_init: failed to load RF calibration data (0xffffffff), falling back to full ”
如下log [22:37:08.654]收←◆ [22:37:08.679]收←◆[0;32mI (233) esp_image: segment 4: paddr=000b46bc vaddr=40376448 size=0c5fch ( 50684) load[0m [0;32mI (244) esp_image: segment 5: paddr=000c0cc0 vaddr=600fe000 size=00010h ( 16) load[0m [0;32mI (250) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (251) boot: Disabling RNG early entropy source...[0m [0;33mW (253) bootloader_random: RNG for ESP32-S3 not currently supported[0m [0;32mI (271) cpu_start: Pro cpu up.[0m [0;32mI (271) cpu_start: Starting app cpu, entry point is 0x4037505c[0m [0;32mI (0) cpu_start: App cpu up.[0m [0;32mI (285) cpu_start: Pro cpu start user code[0m [0;32mI (285) cpu_start: cpu freq: 160000000[0m [0;32mI (285) cpu_start: Application information:[0m [0;32mI (288) cpu_start: Project name: mqtt_ssl[0m [0;32mI (293) cpu_start: App version: 1[0m [0;32mI (298) cpu_start: Compile time: Mar 5 2022 22:34:54[0m [0;32mI (304) cpu_start: ELF file SHA256: 37284e84702eb7d1...[0m [0;32mI (310) cpu_start: ESP-IDF: HEAD-HASH-NOTFOUND[0m [0;32mI (316) heap_init: Initializing. RAM available for dynamic allocation:[0m [0;32mI (323) heap_init: At 3FC9A2F8 len 00045D08 (279 KiB): D/IRAM[0m [0;32mI (329) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM[0m [0;32mI (336) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM[0m [0;32mI (343) spi_flash: detected chip: gd[0m [0;32mI (346) spi_flash: flash io: dio[0m [0;33mW (350) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.[0m [0;32mI (364) cpu_start: Starting scheduler on PRO CPU.[0m [0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m [0;32mI (374) MQTTS_EXAMPLE: [APP] Startup..[0m [0;32mI (374) MQTTS_EXAMPLE: [APP] Free memory: 356916 bytes[0m [0;32mI (384) MQTTS_EXAMPLE: [APP] IDF version: HEAD-HASH-NOTFOUND[0m [0;32mI (414) pp: pp rom version: e7ae62f[0m [0;32mI (414) net80211: net80211 rom version: e7ae62f[0m I (424) wifi:wifi driver task: 3fce569c, prio:23, stack:6656, core=0 [0;32mI (424) system_api: Base MAC address is not set[0m [0;32mI (424) system_api: read default base MAC address from EFUSE[0m I (444) wifi:wifi firmware version: 4c9ede1 I (444) wifi:wifi certification v [22:37:08.895]收←◆ersion: v7.0 I (444) wifi:config NVS flash: enabled I (444) wifi:config nano formating: disabled I (454) wifi:Init data frame dynamic rx buffer num: 32 I (454) wifi:Init management frame dynamic rx buffer num: 32 I (464) wifi:Init management short buffer num: 32 I (464) wifi:Init dynamic tx buffer num: 32 I (464) wifi:Init static tx FG buffer num: 2 I (474) wifi:Init static rx buffer size: 1600 I (474) wifi:Init static rx buffer num: 10 I (484) wifi:Init dynamic rx buffer num: 32 [0;32mI (484) wifi_init: rx ba win: 6[0m [0;32mI (484) wifi_init: tcpip mbox: 32[0m [0;32mI (494) wifi_init: udp mbox: 6[0m [0;32mI (494) wifi_init: tcp mbox: 6[0m [0;32mI (504) wifi_init: tcp tx win: 5744[0m [0;32mI (504) wifi_init: tcp rx win: 5744[0m [0;32mI (504) wifi_init: tcp mss: 1440[0m [0;32mI (514) wifi_init: WiFi IRAM OP enabled[0m [0;32mI (514) wifi_init: WiFi RX IRAM OP enabled[0m [0;32mI (524) example_connect: Connecting to lili...[0m [0;32mI (524) phy_init: phy_version 100,24b028a,Jul 1 2021,14:17:09[0m [0;33mW (534) phy_init: failed to load RF calibration data (0xffffffff), falling back to full ESP-ROM:esp32s3-20210327 [22:37:09.007]收←◆Build:Mar 27 2021 rst:0x13 (GLITCH_RTC_RST),boot:0x8 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0108,len:0x1580 load:0x403b6000,len:0x878 load:0x403ba000,len:0x2ae0 entry 0x403b61c0 |
1个回答
以下是一些建议来解决这个问题:
1. 检查硬件连接:确保您的 ESP32-S3 模块的天线连接正确,没有松动或损坏。 2. 检查电源供应:确保您的 ESP32-S3 模块的电源供应稳定,电压在规定的范围内。 3. 更新固件:尝试使用最新版本的 ESP-IDF(如 IDF v4.4),以解决可能的已知问题。 4. 重新烧录固件:尝试重新烧录固件,以排除烧录过程中可能发生的错误。 5. 检查代码:检查您的代码中是否有任何可能导致 Wi-Fi 校准失败的问题。例如,确保您正确地初始化了 Wi-Fi 模块。 6. 使用 esp_wifi_set_config() 函数:在您的代码中,使用 esp_wifi_set_config() 函数设置 Wi-Fi 配置,确保所有参数都正确设置。 7. 检查环境干扰:确保您的 ESP32-S3 模块周围没有强烈的电磁干扰,这可能会影响 Wi-Fi 校准过程。 8. 尝试使用不同的 Wi-Fi 信道:在您的代码中,尝试使用不同的 Wi-Fi 信道,以排除信道干扰的可能性。 9. 查看 ESP-IDF 的 issue 跟踪器:在 ESP-IDF 的 GitHub 仓库中查看是否有其他用户遇到了类似的问题,并查看是否有解决方案。 |
只有小组成员才能发言,加入小组>>
430浏览 6评论
363浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
344浏览 5评论
350浏览 4评论
328浏览 4评论
GMT+8, 2024-9-2 00:20 , Processed in 0.813964 second(s), Total 82, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
