请问一下,esp32-at编译后make flash烧写成功后无法启动是什么问题?
板子信息: Chip is ESP32D0WDQ6 (revision 1) Features: WiFi, BT, Dual Core, Coding Scheme None 启动log: ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:6192 ho 0 tail 12 room 4 load:0x40078000,len:9888 load:0x40080400,len:6468 entry 0x40080760 I (30) boot: ESP-IDF v3.3-dev-343-g7fa9859 2nd stage bootloader I (30) boot: compile time 20:53:22 I (30) boot: Enabling RNG early entropy source... I (36) boot: SPI Speed : 40MHz I (40) boot: SPI Mode : DIO I (44) boot: SPI Flash Size : 4MB I (48) boot: Partition Table: I (52) boot: ## Label Usage Type ST Offset Length I (59) boot: 0 phy_init RF data 01 01 0000f000 00001000 I (67) boot: 1 otadata OTA data 01 00 00010000 00002000 I (74) boot: 2 nvs WiFi data 01 02 00012000 0000e000 I (81) boot: 3 at_customize unknown 40 00 00020000 000e0000 I (89) boot: 4 ota_0 OTA app 00 10 00100000 00180000 I (96) boot: 5 ota_1 OTA app 00 11 00280000 00180000 I (104) boot: End of partition table I (108) boot: No factory image, trying OTA 0 I (113) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x25078 (151672) map I (175) esp_image: segment 1: paddr=0x001250a0 vaddr=0x3ffbdb60 size=0x034a8 ( 13480) load I (181) esp_image: segment 2: paddr=0x00128550 vaddr=0x3ffc1008 size=0x00000 ( 0) load I (182) esp_image: segment 3: paddr=0x00128558 vaddr=0x40080000 size=0x00400 ( 1024) load I (191) esp_image: segment 4: paddr=0x00128960 vaddr=0x40080400 size=0x076b0 ( 30384) load I (213) esp_image: segment 5: paddr=0x00130018 vaddr=0x400d0018 size=0xf81a8 (1016232) map I (569) esp_image: segment 6: paddr=0x002281c8 vaddr=0x40087ab0 size=0x0f428 ( 62504) load I (595) esp_image: segment 7: paddr=0x002375f8 vaddr=0x400c0000 size=0x00064 ( 100) load I (595) esp_image: segment 8: paddr=0x00237664 vaddr=0x50000000 size=0x00000 ( 0) load I (602) esp_image: segment 9: paddr=0x0023766c vaddr=0x50000000 size=0x00000 ( 0) load I (624) boot: Loaded app from partition at offset 0x100000 I (624) boot: Disabling RNG early entropy source... |
1个回答
根据您提供的信息,您的ESP32板子型号为ESP32D0WDQ6,具有WiFi和BT功能,双核心,编码方案为None。在烧录过程中,您使用了make flash命令,但是烧录成功后无法启动。以下是一些建议和可能的原因:
1. 检查烧录文件是否正确:请确保您烧录的文件是正确的,没有损坏或不完整。您可以尝试重新编译并烧录一次。 2. 检查烧录过程中的参数设置:请确保您在烧录过程中使用的参数(如波特率、烧录速度等)与您的设备兼容。如果不确定,可以尝试使用默认参数进行烧录。 3. 检查电源和连接:请确保您的ESP32板子电源稳定,连接线没有松动或损坏。不稳定的电源或连接问题可能会导致烧录失败或设备无法启动。 4. 检查板子硬件:如果以上步骤都无法解决问题,可能是板子本身存在硬件问题。您可以尝试更换一块新的ESP32板子进行测试。 5. 检查启动配置:请检查您的设备启动配置是否正确。例如,确保SPI Flash的启动模式设置为QIO或QOUT,以及分区表是否正确配置。 6. 检查固件版本:请确保您烧录的固件版本与您的ESP32板子兼容。如果不兼容,可能会导致设备无法启动。 7. 检查日志信息:您提供的日志信息显示,设备在启动过程中遇到了一些问题。您可以仔细检查日志,查找可能的错误信息或异常情况,以便进一步分析问题。 8. 尝试使用其他烧录工具:如果问题仍然存在,您可以尝试使用其他烧录工具(如esptool.py)进行烧录,看看是否能够解决问题。 总之,要解决这个问题,您需要从多个方面进行排查,包括烧录文件、参数设置、硬件连接、启动配置等。希望这些建议能帮助您找到问题所在并解决它。 |
只有小组成员才能发言,加入小组>>
982 浏览 1 评论
553浏览 6评论
463浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
447浏览 5评论
448浏览 4评论
420浏览 4评论
GMT+8, 2024-11-28 06:08 , Processed in 0.744956 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
