您好,
ESP32 从休眠唤醒到 wifi mac 能用,需要649ms,这个时间有点长,请帮看下哪里可以优化吗? rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:4 load:0x3fff0034,len:7184 ho 0 tail 12 room 4 load:0x40078000,len:14352 load:0x40080400,len:4448 0x40080400: _init at ??:? entry 0x400806f0 I (31) boot: ESP-IDF v4.1-dev-2259-ga70a6f897-dirty 2nd stage bootloader I (31) boot: compile time 17:02:17 I (32) boot: chip revision: 1 I (36) boot_comm: chip revision: 1, min. bootloader chip revision: 0 I (43) boot.esp32: SPI Speed : 40MHz I (48) boot.esp32: SPI Mode : DIO I (52) boot.esp32: SPI Flash Size : 2MB I (57) boot: Enabling RNG early entropy source... I (62) boot: Partition Table: I (66) boot: ## Label Usage Type ST Offset Length I (73) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (81) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (88) boot: 2 factory factory app 00 00 00010000 00100000 I (96) boot: End of partition table I (100) boot_comm: chip revision: 1, min. application chip revision: 0 I (107) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x179c4 ( 96708) map I (151) esp_image: segment 1: paddr=0x000279ec vaddr=0x3ffb0000 size=0x038e8 ( 14568) load I (157) esp_image: segment 2: paddr=0x0002b2dc vaddr=0x40080000 size=0x00404 ( 1028) load 0x40080000: _WindowOverflow4 at E:/evan/esp/work/esp/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1789 I (158) esp_image: segment 3: paddr=0x0002b6e8 vaddr=0x40080404 size=0x04930 ( 18736) load I (174) esp_image: segment 4: paddr=0x00030020 vaddr=0x400d0020 size=0x76904 (485636) map 0x400d0020: _stext at ??:? I (351) esp_image: segment 5: paddr=0x000a692c vaddr=0x40084d34 size=0x11490 ( 70800) load 0x40084d34: wDev_ProcessFiq at ??:? I (381) esp_image: segment 6: paddr=0x000b7dc4 vaddr=0x400c0000 size=0x00064 ( 100) I (381) esp_image: segment 7: paddr=0x000b7e30 vaddr=0x50000000 size=0x00010 ( 16) I (400) boot: Loaded app from partition at offset 0x10000 I (400) boot: Disabling RNG early entropy source... I (401) cpu_start: Pro cpu up. I (404) cpu_start: Application information: I (409) cpu_start: Project name: esp_my_node I (415) cpu_start: App version: v4.1-dev-2259-ga70a6f897-dirty I (422) cpu_start: Compile time: Feb 23 2020 23:32:34 I (428) cpu_start: ELF file SHA256: 341e89abb4d1f557... I (434) cpu_start: ESP-IDF: v4.1-dev-2259-ga70a6f897-dirty I (441) cpu_start: Starting app cpu, entry point is 0x4008137c 0x4008137c: call_start_cpu1 at E:/evan/esp/work/esp/esp-idf/components/esp32/cpu_start.c:274 I (0) cpu_start: App cpu up. I (451) heap_init: Initializing. RAM available for dynamic allocation: I (458) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (464) heap_init: At 3FFB9228 len 00026DD8 (155 KiB): DRAM I (470) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (477) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (483) heap_init: At 400961C4 len 00009E3C (39 KiB): IRAM I (489) cpu_start: Pro cpu start user code I (507) spi_flash: detected chip: generic I (508) spi_flash: flash io: dio W (508) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (518) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (529) esp_my_node: app main I (529) esp_my_node: Wake up from timer. Time spent in deep sleep: 10534ms I (589) wifi: wifi driver task: 3ffc0d4c, prio:23, stack:3584, core=0 I (589) system_api: Base MAC address is not set I (589) system_api: read default base MAC address from EFUSE I (589) wifi: wifi firmware version: 94efb94 I (599) wifi: config NVS flash: disabled I (599) wifi: config nano formating: disabled I (599) wifi: Init dynamic tx buffer num: 32 I (609) wifi: Init data frame dynamic rx buffer num: 32 I (609) wifi: Init management frame dynamic rx buffer num: 32 I (619) wifi: Init management short buffer num: 32 I (619) wifi: Init static rx buffer size: 1600 I (629) wifi: Init static rx buffer num: 10 I (629) wifi: Init dynamic rx buffer num: 32 I (649) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 1 I (649) wifi: mode : sta (fc:f5:c4:45:64:80) |
1个回答
要优化ESP32从深度休眠唤醒到工作的时间,可以从以下几个方面进行优化:
1. **减少启动过程中的延时**:检查启动过程中是否有不必要的延时,例如等待某些硬件设备就绪。如果有,尝试减少这些延时。 2. **优化SPI Flash读写速度**:ESP32使用SPI Flash存储程序和数据。优化SPI Flash的读写速度可以缩短唤醒时间。可以尝试调整SPI Flash的时钟频率和模式,以提高读写速度。 3. **使用更快的启动模式**:ESP32支持不同的启动模式,如QIO、QOUT、DIO和DOUT。QIO和DIO模式比QOUT和DOUT模式更快。检查当前使用的启动模式,如果可能的话,切换到更快的模式。 4. **减少程序大小**:程序大小越大,从Flash加载到RAM所需的时间就越长。尝试优化代码,减少程序大小,以缩短加载时间。 5. **使用外部晶振**:ESP32可以使用内部RC振荡器或外部晶振。外部晶振通常比内部RC振荡器更稳定,可以提高系统性能。如果可能的话,尝试使用外部晶振。 6. **优化WiFi连接过程**:在唤醒后,ESP32需要连接到WiFi网络。优化WiFi连接过程,例如使用更快的连接方法或预先配置WiFi设置,可以缩短连接时间。 7. **使用中断唤醒**:如果可能的话,使用中断唤醒ESP32,而不是使用定时器唤醒。中断唤醒可以更精确地控制唤醒时间,从而减少唤醒过程中的延时。 8. **检查电源管理设置**:检查电源管理设置,确保在休眠期间关闭不必要的硬件设备,以减少唤醒所需的时间。 9. **更新ESP-IDF版本**:您当前使用的是ESP-IDF v4.1-dev-2259-ga版本。尝试更新到最新的稳定版本,以获取可能的性能改进和bug修复。 通过以上方法,您可以尝试优化ESP32从深度休眠唤醒到工作的时间。请注意,实际效果可能因具体硬件和软件环境而异。 |
只有小组成员才能发言,加入小组>>
371 浏览 1 评论
1208 浏览 1 评论
591浏览 6评论
485浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
468浏览 5评论
467浏览 4评论
445浏览 4评论
GMT+8, 2024-12-31 05:15 , Processed in 1.131917 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
