电子发烧友论坛|
最近测试esp-mesh,发现使用例程编译后没两个esp32开发板没办法组网,已经试遍所有办法。
SDK是Arduino 2.0.0 rc1(idf 4.4)。之前用IDF3.3.1测试也是相同的结果。 使用idf 4.4的代码如下(两块开发板刷入相同内容)。 #include #include #include "esp_wifi.h"#include "esp_system.h"#include "esp_event.h"#include "esp_log.h"#include "esp_mesh.h"#include "esp_mesh_internal.h"#include "nvs_flash.h"#include "esp_netif.h"static bool is_mesh_connected = false;static mesh_addr_t mesh_parent_addr;static int mesh_layer = -1;static esp_netif_t *netif_sta = NULL;#define CONFIG_MESH_ROUTE_TABLE_SIZE 50uint8_t g_meshAddr[6] = {0};uint8_t g_deviceId[6] = {0};#define CONFIG_MESH_TOPOLOGY MESH_TOPO_TREE /* MESH_TOPO_TREE / MESH_TOPO_CHAIN */#define CONFIG_MESH_PS_DEV_DUTY 10 /* 1 - 100 */#define CONFIG_MESH_PS_DEV_DUTY_TYPE MESH_PS_DEVICE_DUTY_REQUEST /* MESH_PS_DEVICE_DUTY_REQUEST / MESH_PS_DEVICE_DUTY_DEMAND */#define CONFIG_MESH_PS_NWK_DUTY 10#define CONFIG_MESH_PS_NWK_DUTY_DURATION -1#define CONFIG_MESH_PS_NWK_DUTY_RULE MESH_PS_NETWORK_DUTY_APPLIED_ENTIRE//#define CONFIG_MESH_ENABLE_PSvoid mesh_event_handler(void *arg, esp_event_base_t event_base, int32_t event_id, void *event_data){ mesh_addr_t id = {0}; static uint8_t last_layer = 0; switch(event_id) { case MESH_EVENT_STARTED: { esp_mesh_get_id(&id); Serial.printf("ID:%02x:%02x:%02x:%02x:%02x:%02xn", MAC2STR(id.addr)); is_mesh_connected = false; mesh_layer = esp_mesh_get_layer(); } break; case MESH_EVENT_STOPPED: { Serial.printf("n"); is_mesh_connected = false; mesh_layer = esp_mesh_get_layer(); } break; case MESH_EVENT_CHILD_CONNECTED: { mesh_event_child_connected_t *child_connected = (mesh_event_child_connected_t *)event_data; Serial.printf("aid:%d, %02x:%02x:%02x:%02x:%02x:%02xn", child_connected->aid, MAC2STR(child_connected->mac)); } break; case MESH_EVENT_CHILD_DISCONNECTED: { mesh_event_child_disconnected_t *child_disconnected = (mesh_event_child_disconnected_t *)event_data; Serial.printf("aid:%d, %02x:%02x:%02x:%02x:%02x:%02xn", child_disconnected->aid, MAC2STR(child_disconnected->mac)); } break; case MESH_EVENT_ROUTING_TABLE_ADD: { mesh_event_routing_table_change_t *routing_table = (mesh_event_routing_table_change_t *)event_data; Serial.printf("add %d, new:%dn", routing_table->rt_size_change, routing_table->rt_size_new); } break; case MESH_EVENT_ROUTING_TABLE_REMOVE: { mesh_event_routing_table_change_t *routing_table = (mesh_event_routing_table_change_t *)event_data; Serial.printf("remove %d, new:%dn", routing_table->rt_size_change, routing_table->rt_size_new); } break; case MESH_EVENT_NO_PARENT_FOUND: { mesh_event_no_parent_found_t *no_parent = (mesh_event_no_parent_found_t *)event_data; Serial.printf("scan times:%dn", no_parent->scan_times); } /* TODO handler for the failure */ break; case MESH_EVENT_PARENT_CONNECTED: { mesh_event_connected_t *connected = (mesh_event_connected_t *)event_data; esp_mesh_get_id(&id); mesh_layer = connected->self_layer; memcpy(&mesh_parent_addr.addr, connected->connected.bssid, 6); Serial.printf( "layer:%d-->%d, parent:%02x:%02x:%02x:%02x:%02x:%02x%s, ID:%02x:%02x:%02x:%02x:%02x:%02xn", last_layer, mesh_layer, MAC2STR(mesh_parent_addr.addr), esp_mesh_is_root() ? "" : (mesh_layer == 2) ? "" : "", MAC2STR(id.addr)); last_layer = mesh_layer; is_mesh_connected = true; if(esp_mesh_is_root()) { // 根节点需要在这里开启DHCP获取IP esp_netif_dhcpc_start(netif_sta); } else { } // 开启2个任务 // -> esp_mesh_comm_p2p_start(); } break; case MESH_EVENT_PARENT_DISCONNECTED: { mesh_event_disconnected_t *disconnected = (mesh_event_disconnected_t *)event_data; Serial.printf( "reason:%dn", disconnected->reason); is_mesh_connected = false; mesh_layer = esp_mesh_get_layer(); } break; case MESH_EVENT_LAYER_CHANGE: { mesh_event_layer_change_t *layer_change = (mesh_event_layer_change_t *)event_data; mesh_layer = layer_change->new_layer; Serial.printf("layer:%d-->%d%sn", last_layer, mesh_layer, esp_mesh_is_root() ? "" : (mesh_layer == 2) ? "" : ""); last_layer = mesh_layer; if(mesh_layer == 1) { // 这里1是根节点,意味着节点此时变化为根节点 // 此处可以添加节点切换的用户自定义功能 } else { } } break; case MESH_EVENT_ROOT_ADDRESS: { mesh_event_root_address_t *root_addr = (mesh_event_root_address_t *)event_data; esp_mesh_get_id(&id); Serial.printf("root address:%02x:%02x:%02x:%02x:%02x:%02x, ID:%02x:%02x:%02x:%02x:%02x:%02xn", MAC2STR(root_addr->addr), MAC2STR(id.addr)); // 此处登记自身在路由表中的地址 int route_table_size = 0; mesh_addr_t route_table[CONFIG_MESH_ROUTE_TABLE_SIZE]; esp_mesh_get_routing_table((mesh_addr_t *) &route_table, CONFIG_MESH_ROUTE_TABLE_SIZE * 6, &route_table_size); memcpy(g_meshAddr, route_table[0].addr, 6); Serial.printf("meshAddr:%02x:%02x:%02x:%02x:%02x:%02xn", MAC2STR(g_meshAddr)); // 此处设置默认设备ID memcpy(g_deviceId, g_meshAddr, 6); } break; case MESH_EVENT_VOTE_STARTED: { mesh_event_vote_started_t *vote_started = (mesh_event_vote_started_t *)event_data; Serial.printf( "attempts:%d, reason:%d, rc_addr:%02x:%02x:%02x:%02x:%02x:%02xn", vote_started->attempts, vote_started->reason, MAC2STR(vote_started->rc_addr.addr)); } break; case MESH_EVENT_VOTE_STOPPED: { Serial.printf("n"); break; } case MESH_EVENT_ROOT_SWITCH_REQ: { mesh_event_root_switch_req_t *switch_req = (mesh_event_root_switch_req_t *)event_data; Serial.printf( "reason:%d, rc_addr:%02x:%02x:%02x:%02x:%02x:%02xn", switch_req->reason, MAC2STR( switch_req->rc_addr.addr)); } break; case MESH_EVENT_ROOT_SWITCH_ACK: { /* new root */ mesh_layer = esp_mesh_get_layer(); esp_mesh_get_parent_bssid(&mesh_parent_addr); Serial.printf("layer:%d, parent:%02x:%02x:%02x:%02x:%02x:%02xn", mesh_layer, MAC2STR(mesh_parent_addr.addr)); } break; case MESH_EVENT_TODS_STATE: { mesh_event_toDS_state_t *toDs_state = (mesh_event_toDS_state_t *)event_data; Serial.printf("state:%dn", *toDs_state); } break; case MESH_EVENT_ROOT_FIXED: { mesh_event_root_fixed_t *root_fixed = (mesh_event_root_fixed_t *)event_data; Serial.printf("%sn", root_fixed->is_fixed ? "fixed" : "not fixed"); } break; case MESH_EVENT_ROOT_ASKED_YIELD: { mesh_event_root_conflict_t *root_conflict = (mesh_event_root_conflict_t *)event_data; Serial.printf( "%02x:%02x:%02x:%02x:%02x:%02x, rssi:%d, capacity:%dn", MAC2STR(root_conflict->addr), root_conflict->rssi, root_conflict->capacity); } break; case MESH_EVENT_CHANNEL_SWITCH: { mesh_event_channel_switch_t *channel_switch = (mesh_event_channel_switch_t *)event_data; Serial.printf("new channel:%dn", channel_switch->channel); } break; case MESH_EVENT_SCAN_DONE: { mesh_event_scan_done_t *scan_done = (mesh_event_scan_done_t *)event_data; Serial.printf("number:%dn", scan_done->number); } break; case MESH_EVENT_NETWORK_STATE: { mesh_event_network_state_t *network_state = (mesh_event_network_state_t *)event_data; Serial.printf("is_rootless:%dn", network_state->is_rootless); } break; case MESH_EVENT_STOP_RECONNECTION: { Serial.printf("n"); } break; case MESH_EVENT_FIND_NETWORK: { mesh_event_find_network_t *find_network = (mesh_event_find_network_t *)event_data; Serial.printf("new channel:%d, router BSSID:%02x:%02x:%02x:%02x:%02x:%02xn", find_network->channel, MAC2STR(find_network->router_bssid)); } break; case MESH_EVENT_ROUTER_SWITCH: { mesh_event_router_switch_t *router_switch = (mesh_event_router_switch_t *)event_data; Serial.printf("new router:%s, channel:%d, %02x:%02x:%02x:%02x:%02x:%02xn", router_switch->ssid, router_switch->channel, MAC2STR(router_switch->bssid)); } break; default: Serial.printf("unknown id:%dn", event_id); break; }}void ip_event_handler(void *arg, esp_event_base_t event_base, int32_t event_id, void *event_data){ ip_event_got_ip_t *event = (ip_event_got_ip_t *) event_data; Serial.printf("IP: %d.%d.%d.%dn", IP2STR(&event->ip_info.ip));}#define DEFAULT_MESH_SSID "aaaaaaaaaa" /* Max=30+1 Min=8+1(Base64编码6字节MAC有8位)*/#define DEFAULT_MESH_PASSWORD "bbbbbbbbbb" /* Max=60+1 */#define DEFAULT_MESH_CHANNEL 6#define DEFAULT_MESH_MAX_PLAYER 6#define DEFAULT_MESH_AP_PASSWD "MESH_AP_PASSWORD"#define DEFAULT_MESH_AP_CONNECTIONS 6static const uint8_t MESH_ID[6] = { 0x77, 0x77, 0x77, 0x77, 0x77, 0x77};//static const uint8_t MESH_ID[6] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88};void setup() { // put your setup code here, to run once: Serial.begin(115200); /* 初始化NVS */ nvs_flash_init(); /* 初始化底层TCP/IP堆栈 */ esp_netif_init(); /* 事件初始化*/ esp_event_loop_create_default(); /* 为 Mesh 创建STA和AP模式网络接口(仅保存STA接口供进一步处理),并关闭DHCP服务器和客户端(DHCP客户端只有设备升根节点才启用) */ esp_netif_create_default_wifi_mesh_netifs(&netif_sta, NULL); /* Wi-Fi 初始化 */ wifi_init_config_t config = WIFI_INIT_CONFIG_DEFAULT(); esp_wifi_init(&config); /* 注册 IP 事件处理程序 */ esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &ip_event_handler, NULL); esp_wifi_set_storage(WIFI_STORAGE_FLASH); esp_wifi_start(); /* Mesh 初始化 */ esp_mesh_init(); /* 注册 Mesh 事件处理程序 */ esp_event_handler_register(MESH_EVENT, ESP_EVENT_ANY_ID, &mesh_event_handler, NULL); /* set mesh topology */ esp_mesh_set_topology(CONFIG_MESH_TOPOLOGY); /* 设置 Mesh 最大层 */ esp_mesh_set_max_layer(DEFAULT_MESH_MAX_PLAYER); /* 设置 Mesh 根节点推举百分比(只有达到此阈值才可成为根) */ esp_mesh_set_vote_percentage(1); // ??? esp_mesh_set_xon_qsize(128); #ifdef CONFIG_MESH_ENABLE_PS /* Enable mesh PS function */ esp_mesh_enable_ps(); /* 设置 Mesh AP模式关联过期时间(在AP模式下此时间内未收到某个子节点的任何数据,Mesh将子节点置为不活跃的并分离它) */ esp_mesh_set_ap_assoc_expire(60); /* better to increase the announce interval to avoid too much management traffic, if a small duty cycle is set. */ esp_mesh_set_announce_interval(600, 3300);#else /* Disable mesh PS function */ esp_mesh_disable_ps(); esp_mesh_set_ap_assoc_expire(10);#endif /* Mesh 配置 */ /* 默认启用 Mesh IE 加密 */ mesh_cfg_t cfg; cfg.crypto_funcs = &g_wifi_default_mesh_crypto_funcs; /* Mesh ID */ memcpy((uint8_t *) &cfg.mesh_id, MESH_ID, 6); /* 路由器 */ /* 信道(需与路由器信道匹配)*/ cfg.channel = DEFAULT_MESH_CHANNEL; // 这里为了方便直接填写了要接入WIFI的SSID和密码 cfg.router.ssid_len = strlen(DEFAULT_MESH_SSID); strcpy((char*)cfg.router.ssid, DEFAULT_MESH_SSID); strcpy((char*)cfg.router.password, DEFAULT_MESH_PASSWORD); /* Mesh softAP */ esp_mesh_set_ap_authmode(WIFI_AUTH_WPA2_PSK); cfg.mesh_ap.max_connection = DEFAULT_MESH_AP_CONNECTIONS; strcpy((char*)cfg.mesh_ap.password, DEFAULT_MESH_AP_PASSWD); esp_mesh_set_config(&cfg); /* Mesh 启动 */ esp_mesh_start(); #ifdef CONFIG_MESH_ENABLE_PS /* set the device active duty cycle. (default:10, MESH_PS_DEVICE_DUTY_REQUEST) */ esp_mesh_set_active_duty_cycle(CONFIG_MESH_PS_DEV_DUTY, CONFIG_MESH_PS_DEV_DUTY_TYPE); /* set the network active duty cycle. (default:10, -1, MESH_PS_NETWORK_DUTY_APPLIED_ENTIRE) */ esp_mesh_set_network_duty_cycle(CONFIG_MESH_PS_NWK_DUTY, CONFIG_MESH_PS_NWK_DUTY_DURATION, CONFIG_MESH_PS_NWK_DUTY_RULE);#endif Serial.printf("mesh starts successfully, heap:%d, %s<%d>%s, ps:%dn", esp_get_minimum_free_heap_size(), esp_mesh_is_root_fixed() ? "root fixed" : "root not fixed", esp_mesh_get_topology(), esp_mesh_get_topology() ? "(chain)":"(tree)", esp_mesh_is_ps_enabled()); }void loop() { // put your main code here, to run repeatedly: //delay(10); Serial.println(esp_mesh_get_type()); delay(1000);} 运行结果输出以下内容: setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz mesh starts successfully, heap:106896, root not fixed<0>(tree), ps:0 scan times:60 scan times:60 scan times:60 scan times:60 scan times:60 |
1个回答
要解决ESP MESH各节点无法互联的问题,我们可以按照以下步骤进行排查和解决:
1. 确保硬件连接正确:首先检查两个ESP32开发板的硬件连接是否正确,确保它们都已连接到电源并正常工作。 2. 检查电源电压:确保两个ESP32开发板的电源电压在正常范围内,以避免电源问题导致无法正常工作。 3. 检查代码:检查代码中是否有错误或遗漏,例如是否正确初始化了ESP MESH库,以及是否正确设置了节点的配置参数。 4. 检查日志输出:在代码中添加日志输出,以便在出现问题时能够快速定位问题所在。例如,可以在初始化ESP MESH库后添加日志输出,以确保库已正确初始化。 5. 检查网络配置:确保两个ESP32开发板的网络配置正确,例如SSID和密码是否一致,以及它们是否都使用了相同的信道。 6. 检查Mesh配置:确保两个ESP32开发板的Mesh配置一致,例如Mesh ID、通道等。 7. 检查编译器和IDE设置:确保使用的编译器和IDE设置正确,例如是否选择了正确的目标硬件平台。 8. 尝试更新SDK:如果问题仍然存在,可以尝试更新ESP-IDF SDK到最新版本,以确保使用的是最新的功能和修复。 9. 检查其他干扰因素:检查周围环境是否有其他干扰因素,例如其他无线设备或信号干扰,这可能会影响ESP MESH的通信。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2528浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 14:10 , Processed in 1.285118 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
564
