使用的是esp32-s2-kaluga-1板子,自己焊接了一个USB口到板上,使用了官方的教程“esp-iot-solutionexamplesusbhostusb_camera_lcd_display”,插入USB摄像头的时候,串口提示如下:
[17:49:02.142]收←◆[0;32mI (7451217) UVC_STREAM: line 353 HCD_PORT_EVENT_CONNECTION[0m [0;32mI (7451217) UVC_STREAM: Resetting Port[0m [17:49:02.206]收←◆[0;32mI (7451277) UVC_STREAM: Setting Port FIFO[0m [0;32mI (7451277) UVC_STREAM: Getting Port Speed[0m [0;32mI (7451277) UVC_STREAM: Port speed = 1[0m [0;32mI (7451277) UVC_STREAM: USB Speed: full-speed[0m D (7451277) UVC_STREAM: urb alloced[0m [0;32mI (7451287) UVC_STREAM: Set Device Addr = 1[0m D (7451287) UVC_STREAM: Got expected pipe_handle and event[0m [0;32mI (7451297) UVC_STREAM: Set Device Addr Done[0m D (7451297) UVC_STREAM: urb free[0m D (7451307) UVC_STREAM: urb alloced[0m [0;32mI (7451307) UVC_STREAM: Set Device Configuration = 1[0m D (7451307) UVC_STREAM: Got expected pipe_handle and event[0m [0;32mI (7451317) UVC_STREAM: Set Device Configuration Done[0m D (7451327) UVC_STREAM: urb free[0m D (7451327) UVC_STREAM: urb alloced[0m [0;32mI (7451327) UVC_STREAM: SET_CUR Probe[0m D (7451337) UVC_STREAM: Got expected pipe_handle and event[0m [0;32mI (7451337) UVC_STREAM: SET_CUR Probe Done[0m [0;32mI (7451347) UVC_STREAM: GET_CUR Probe[0m D (7451347) UVC_STREAM: Got expected pipe_handle and event[0m bmHint: 0201 bFormatIndex: 0 bFrameIndex: 0 dwFrameInterval: 400000 wKeyFrameRate: 3 wPFrameRate: 256 wCompQuality: 3 wCompWindowSize: 50688 wDelay: 0 dwMaxVideoFrameSize: 2047 dwMaxPayloadTransferSize: 1025 dwClockFrequency: 0 bmFramingInfo: 0 bPreferredVersion: 0 bMinVersion: 0 bMaxVersion: 0 bInterfaceNumber: 0 [0;32mI (7451387) UVC_STREAM: GET_CUR Probe Done, actual_num_bytes:64[0m [0;32mI (7451387) UVC_STREAM: SET_CUR COMMIT[0m D (7451397) UVC_STREAM: Got expected pipe_handle and event[0m [0;32mI (7451397) UVC_STREAM: SET_CUR COMMIT Done[0m D (7451407) UVC_STREAM: urb free[0m D (7451407) UVC_STREAM: urb alloced[0m [0;32mI (7451407) UVC_STREAM: Set Device Interface = 1, Alt = 1[0m D (7451417) UVC_STREAM: Got expected pipe_handle and event[0m [0;32mI (7451427) UVC_STREAM: Set Device Interface Done[0m D (7451427) UVC_STREAM: urb free[0m [0;32mI (7451427) UVC_STREAM: Sample processing task started[0m [17:49:02.413]收←◆[0;32mI (7451487) UVC_STREAM: Camera Start Streaming[0m D (7451487) UVC_STREAM: urb context update[0m D (7451487) UVC_STREAM: urb context update[0m D (7451487) UVC_STREAM: urb context update[0m D (7451487) UVC_STREAM: urb context update[0m [0;33mW (7451507) UVC_STREAM: line 657 Pipe: iso HCD_PIPE_EVENT_ERROR_OVERFLOW[0m 代码里设置的参数是320*240,对应的index为4,摄像头在linux下使用`lsusb -v`查看参数如下: VideoStreaming Interface Descriptor: bLength 30 bDescriptorType 36 bDescriptorSubtype 5 (FRAME_UNCOMPRESSED) bFrameIndex 4 bmCapabilities 0x00 Still image unsupported wWidth 320 wHeight 240 dwMinBitRate 3840000 dwMaxBitRate 3840000 dwMaxVideoFrameBufferSize 153600 dwDefaultFrameInterval 400000 bFrameIntervalType 1 dwFrameInterval( 0) 400000 代码里使用的参数如下图: |
1个回答
根据您提供的信息,您在ESP32-S2-Kaluga-1开发板上焊接了一个USB接口,并使用了官方教程“esp-iot-solution-examples/usbhost/usb_camera_lcd_display”。在插入USB摄像头时,串口提示了一些信息。为了解决您的问题,我们可以按照以下步骤进行排查:
1. 检查焊接质量:首先,确保您焊接的USB接口与ESP32-S2-Kaluga-1开发板的连接是正确的,没有虚焊或短路现象。 2. 检查电源:USB摄像头需要稳定的电源供应。请确保您的开发板电源稳定,并且摄像头的电源需求得到满足。 3. 检查摄像头兼容性:确保您使用的USB摄像头与ESP32-S2-Kaluga-1开发板兼容。有些摄像头可能需要特定的驱动程序或固件支持。 4. 检查串口日志:从您提供的串口日志来看,摄像头已经连接到开发板,并且开发板正在尝试与摄像头建立连接。但是,没有足够的信息来判断摄像头是否成功连接。请检查完整的串口日志,看看是否有任何错误或警告信息。 5. 检查代码和配置:确保您的代码和配置文件与官方教程一致,没有遗漏或错误的地方。 6. 尝试其他摄像头:如果可能的话,尝试使用其他USB摄像头,看看问题是否仍然存在。这可以帮助您确定问题是否与特定的摄像头有关。 7. 更新固件和库:确保您的ESP32-S2-Kaluga-1开发板固件和相关库是最新的。有时,固件或库的更新可能解决一些兼容性或功能问题。 通过以上步骤,您应该能够找到导致USB摄像头出错的原因,并采取相应的解决措施。 |
只有小组成员才能发言,加入小组>>
528浏览 6评论
438浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
425浏览 5评论
423浏览 4评论
399浏览 4评论
GMT+8, 2024-11-9 10:05 , Processed in 0.613750 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
