开发板 : ESP32-S3-DevKitC-1 v1.1 R8N32版本 采购于官方淘宝店,预计使用半年左右。
软件环境 IDF 4.4.2+VSCODE 最近在测试程序的是有一直出现莫名其妙的问题。今天使用flash_encryption 这个测试用例。我在spi_flash_read接口测试前加上了spi_flash_write测试,想把值再次写入一下。下面是测试结果,使用esp_partition_read和spi_flash_read接口读取出来的全是0xFF。麻烦官方给看下是怎么回事吧。是新版本的问题,还是我硬件的问题。 为了方便定位问题,我把efuse也读取出来贴出来了。 --------------------------------------------------efuse 值----------------------------------------------------------------------- Connecting.... Detecting chip type... ESP32-S3 espefuse.py v3.3.2-dev === Run "summary" command === EFUSE_NAME (Block) Description = [Meaningful Value] [Readable/Writeable] (Hex Value) ---------------------------------------------------------------------------------------- Config fuses: DIS_ICACHE (BLOCK0) Disables ICache = False R/W (0b0) DIS_DCACHE (BLOCK0) Disables DCache = False R/W (0b0) DIS_DOWNLOAD_ICACHE (BLOCK0) Disables Icache when SoC is in Download mode = False R/W (0b0) DIS_DOWNLOAD_DCACHE (BLOCK0) Disables Dcache when SoC is in Download mode = False R/W (0b0) DIS_FORCE_DOWNLOAD (BLOCK0) Disables forcing chip into Download mode = False R/W (0b0) DIS_CAN (BLOCK0) Disables the TWAI Controller hardware = False R/W (0b0) DIS_APP_CPU (BLOCK0) Disables APP CPU = False R/W (0b0) FLASH_TPUW (BLOCK0) Configures flash startup delay after SoC power-up, = 0 R/W (0x0) unit is (ms/2). When the value is 15, delay is 7. 5 ms DIS_DIRECT_BOOT (BLOCK0) Disables direct boot mode = False R/W (0b0) DIS_USB_SERIAL_JTAG_ROM_PRINT (BLOCK0) Disables USB-Serial-JTAG ROM printing = False R/W (0b0) FLASH_ECC_MODE (BLOCK0) Configures the ECC mode for SPI flash = 16-byte to 18-byte mode R/W (0b0) DIS_USB_SERIAL_JTAG_DOWNLOAD_MODE (BLOCK0) Disables USB-Serial-JTAG download feature in UART = False R/W (0b0) download boot mode UART_PRINT_CONTROL (BLOCK0) Sets the default UART boot message output mode = Enabled R/W (0b00) FLASH_TYPE (BLOCK0) Selects SPI flash type = 8 data lines R/W (0b1) FLASH_PAGE_SIZE (BLOCK0) Sets the size of flash page = 0 R/W (0b00) FLASH_ECC_EN (BLOCK0) Enables ECC in Flash boot mode = False R/W (0b0) FORCE_SEND_RESUME (BLOCK0) Forces ROM code to send an SPI flash resume comman = False R/W (0b0) d during SPI boot DIS_USB_OTG_DOWNLOAD_MODE (BLOCK0) Disables USB-OTG download feature in UART download = True R/W (0b1) boot mode BLOCK_USR_DATA (BLOCK3) User data = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W Efuse fuses: WR_DIS (BLOCK0) Disables programming of individual eFuses = 0 R/W (0x00000000) RD_DIS (BLOCK0) Disables software reading from BLOCK4-10 = 0 R/W (0b0000000) Identity fuses: SECURE_VERSION (BLOCK0) Secure version (used by ESP-IDF anti-rollback feat = 0 R/W (0x0000) ure) MAC (BLOCK1) Factory MAC Address = 7c:df:a1:e1:10:c4 (OK) R/W WAFER_VERSION (BLOCK1) WAFER version = 1 R/W (0b001) PKG_VERSION (BLOCK1) ??? Package version = ESP32-S3 R/W (0x0) BLOCK1_VERSION (BLOCK1) ??? BLOCK1 efuse version = 1 R/W (0b001) OPTIONAL_UNIQUE_ID (BLOCK2) ??? Optional unique 128-bit ID = 49 58 74 f6 88 43 ba b7 e2 13 04 5f cd de 0c eb R/W BLOCK2_VERSION (BLOCK2) ??? Version of BLOCK2 = 3 R/W (0b011) CUSTOM_MAC (BLOCK3) Custom MAC Address = 00:00:00:00:00:00 (OK) R/W Security fuses: SOFT_DIS_JTAG (BLOCK0) Software disables JTAG by programming odd number o = 0 R/W (0b000) f 1 bit(s). JTAG can be re-enabled via HMAC periph eral HARD_DIS_JTAG (BLOCK0) Hardware disables JTAG permanently = False R/W (0b0) DIS_DOWNLOAD_MANUAL_ENCRYPT (BLOCK0) Disables flash encryption when in download boot mo = False R/W (0b0) des SPI_BOOT_CRYPT_CNT (BLOCK0) Enables encryption and decryption, when an SPI boo = Disable R/W (0b000) t mode is set. Enabled when 1 or 3 bits are set,di sabled otherwise SECURE_BOOT_KEY_REVOKE0 (BLOCK0) Revokes use of secure boot key digest 0 = False R/W (0b0) SECURE_BOOT_KEY_REVOKE1 (BLOCK0) Revokes use of secure boot key digest 1 = False R/W (0b0) SECURE_BOOT_KEY_REVOKE2 (BLOCK0) Revokes use of secure boot key digest 2 = False R/W (0b0) KEY_PURPOSE_0 (BLOCK0) KEY0 purpose = USER R/W (0x0) KEY_PURPOSE_1 (BLOCK0) KEY1 purpose = USER R/W (0x0) KEY_PURPOSE_2 (BLOCK0) KEY2 purpose = USER R/W (0x0) KEY_PURPOSE_3 (BLOCK0) KEY3 purpose = USER R/W (0x0) KEY_PURPOSE_4 (BLOCK0) KEY4 purpose = USER R/W (0x0) KEY_PURPOSE_5 (BLOCK0) KEY5 purpose = USER R/W (0x0) SECURE_BOOT_EN (BLOCK0) Enables secure boot = False R/W (0b0) SECURE_BOOT_AGGRESSIVE_REVOKE (BLOCK0) Enables aggressive secure boot key revocation mode = False R/W (0b0) STRAP_JTAG_SEL (BLOCK0) Enable selection between usb_to_jtagor pad_to_jtag = False R/W (0b0) through GPIO3 DIS_DOWNLOAD_MODE (BLOCK0) Disables all Download boot modes = False R/W (0b0) ENABLE_SECURITY_DOWNLOAD (BLOCK0) Enables secure UART download mode (read/write flas = False R/W (0b0) h only) BLOCK_KEY0 (BLOCK4) Purpose: USER Encryption key0 or user data = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W BLOCK_KEY1 (BLOCK5) Purpose: USER Encryption key1 or user data = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W BLOCK_KEY2 (BLOCK6) Purpose: USER Encryption key2 or user data = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W BLOCK_KEY3 (BLOCK7) Purpose: USER Encryption key3 or user data = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W BLOCK_KEY4 (BLOCK8) Purpose: USER Encryption key4 or user data = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W BLOCK_KEY5 (BLOCK9) Purpose: USER Encryption key5 or user data = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W BLOCK_SYS_DATA2 (BLOCK10) System data (part 2) = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W Spi_Pad_Config fuses: SPI_PAD_CONFIG_CLK (BLOCK1) SPI CLK pad = 0 R/W (0b000000) SPI_PAD_CONFIG_Q (BLOCK1) SPI Q (D1) pad = 0 R/W (0b000000) SPI_PAD_CONFIG_D (BLOCK1) SPI D (D0) pad = 0 R/W (0b000000) SPI_PAD_CONFIG_CS (BLOCK1) SPI CS pad = 0 R/W (0b000000) SPI_PAD_CONFIG_HD (BLOCK1) SPI HD (D3) pad = 0 R/W (0b000000) SPI_PAD_CONFIG_WP (BLOCK1) SPI WP (D2) pad = 0 R/W (0b000000) SPI_PAD_CONFIG_DQS (BLOCK1) SPI DQS pad = 0 R/W (0b000000) SPI_PAD_CONFIG_D4 (BLOCK1) SPI D4 pad = 0 R/W (0b000000) SPI_PAD_CONFIG_D5 (BLOCK1) SPI D5 pad = 0 R/W (0b000000) SPI_PAD_CONFIG_D6 (BLOCK1) SPI D6 pad = 0 R/W (0b000000) SPI_PAD_CONFIG_D7 (BLOCK1) SPI D7 pad = 0 R/W (0b000000) Usb Config fuses: DIS_USB (BLOCK0) Disables the USB OTG hardware = False R/W (0b0) USB_EXCHG_PINS (BLOCK0) Exchanges USB D+ and D- pins = False R/W (0b0) EXT_PHY_ENABLE (BLOCK0) Enables external USB PHY = False R/W (0b0) BTLC_GPIO_ENABLE (BLOCK0) Enables BTLC GPIO = 0 R/W (0b00) DIS_USB_JTAG (BLOCK0) Disable usb_serial_jtag-to-jtag function = False R/W (0b0) DIS_USB_SERIAL_JTAG (BLOCK0) Disable usb_serial_jtag module = False R/W (0b0) USB_PHY_SEL (BLOCK0) Select internal/external PHY for USB OTGand usb_se = False R/W (0b0) rial_jtag Vdd_Spi Config fuses: VDD_SPI_XPD (BLOCK0) The VDD_SPI regulator is powered on = True R/W (0b1) VDD_SPI_TIEH (BLOCK0) The VDD_SPI power supply voltage at reset = Connect to 1.8V LDO R/W (0b0) VDD_SPI_FORCE (BLOCK0) Force using VDD_SPI_XPD and VDD_SPI_TIEH to config = True R/W (0b1) ure VDD_SPI LDO PIN_POWER_SELECTION (BLOCK0) Sets default power supply for GPIO33..37 = VDD_SPI R/W (0b1) Wdt Config fuses: WDT_DELAY_SEL (BLOCK0) Selects RTC WDT timeout threshold at startup = 0 R/W (0b00) Flash voltage (VDD_SPI) set to 1.8V by efuse. -----------------------------------------flash_encryption 例程运行日志----------------------------------- ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x18 (SPI_FAST_FLASH_BOOT) SPIWP:0xee Octal Flash Mode Enabled For OPI Flash, Use Default Flash Boot Mode mode:SLOW_RD, clock div:1 load:0x3fce3808,len:0x1654 load:0x403c9700,len:0xbb8 load:0x403cc700,len:0x2f8c SHA-256 comparison failed: Calculated: 662af6c1b4c9e1dd2de0bb716ec46d8a16cc538f842cb7f75514c5473a538c7e Expected: 405e6d2b4de0d6b8d31281394ef53848dedc9f84bf1d546c666dacda9fbed504 Attempting to boot anyway... entry 0x403c9954 I (50) boot: ESP-IDF v4.4.2-dirty 2nd stage bootloader I (51) boot: compile time 11:45:01 I (51) boot: chip revision: 0 I (53) boot.esp32s3: Boot SPI Speed : 80MHz I (58) boot.esp32s3: SPI Mode : SLOW READ I (63) boot.esp32s3: SPI Flash Size : 16MB I (68) boot: Enabling RNG early entropy source... I (73) boot: Partition Table: I (77) boot: ## Label Usage Type ST Offset Length I (84) boot: 0 nvs WiFi data 01 02 0000a000 00006000 I (91) boot: 1 storage Unknown data 01 ff 00010000 00001000 I (99) boot: 2 factory factory app 00 00 00020000 00100000 I (106) boot: 3 nvs_key NVS keys 01 04 00120000 00001000 I (114) boot: End of partition table I (118) esp_image: segment 0: paddr=00020020 vaddr=3c020020 size=0823ch ( 33340) map I (134) esp_image: segment 1: paddr=00028264 vaddr=3fc90e30 size=0271ch ( 10012) load I (138) esp_image: segment 2: paddr=0002a988 vaddr=40374000 size=05690h ( 22160) load I (150) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=19820h (104480) map I (177) esp_image: segment 4: paddr=00049848 vaddr=40379690 size=0779ch ( 30620) load I (185) esp_image: segment 5: paddr=00050fec vaddr=50000000 size=00010h ( 16) load I (191) boot: Loaded app from partition at offset 0x20000 I (191) boot: Disabling RNG early entropy source... I (205) cpu_start: Pro cpu up. I (206) cpu_start: Starting app cpu, entry point is 0x403750f4 0x403750f4: call_start_cpu1 at D:/software/Espressif/frameworks/esp-idf-v4.4.2/components/esp_system/port/cpu_start.c:160 I (0) cpu_start: App cpu up. I (220) cpu_start: Pro cpu start user code I (220) cpu_start: cpu freq: 160000000 I (220) cpu_start: Application information: I (222) cpu_start: Project name: flash_encryption I (228) cpu_start: App version: 1 I (233) cpu_start: Compile time: Sep 7 2022 11:44:38 I (239) cpu_start: ELF file SHA256: 010dff40c924a7d3... I (245) cpu_start: ESP-IDF: v4.4.2-dirty I (250) heap_init: Initializing. RAM available for dynamic allocation: I (257) heap_init: At 3FC93F60 len 0004C0A0 (304 KiB): D/IRAM I (264) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (270) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (277) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM I (284) spi_flash: detected chip: mxic W (287) spi_flash: Detected flash size > 16 MB, but access beyond 16 MB is not supported for this flash model yet. I (298) spi_flash: flash io: dio W (302) spi_flash: Detected size(32768k) larger than the size in the binary image header(16384k). Using the size in the binary image header. I (316) sleep: Configure to isolate all GPIO pins in sleep state I (323) sleep: Enable automatic switching of GPIO sleep configuration I (330) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. Example to check Flash Encryption status This is esp32s3 chip with 2 CPU core(s), WiFi/BLE, silicon revision 0, 16MB external flash FLASH_CRYPT_CNT eFuse value is 0 Flash encryption feature is disabled Erasing partition "storage" (0x1000 bytes) Writing data with esp_partition_write: I (451) example: 0x3fcf3e10 00 01 02 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f |................| I (451) example: 0x3fcf3e20 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f |................| I (461) example: 0x3fcf3e30 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f | !"#$%&'()*+,-./| I (471) example: 0x3fcf3e40 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f |0123456789:;<=>?| Reading with esp_partition_read: I (481) example: 0x3fcf3dd0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| I (491) example: 0x3fcf3de0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| I (501) example: 0x3fcf3df0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| I (511) example: 0x3fcf3e00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| Reading with spi_flash_write: I (521) example: 0x3fcf3e10 00 01 02 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f |................| I (531) example: 0x3fcf3e20 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f |................| I (541) example: 0x3fcf3e30 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f | !"#$%&'()*+,-./| I (551) example: 0x3fcf3e40 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f |0123456789:;<=>?| Reading with spi_flash_read: I (561) example: 0x3fcf3dd0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| I (571) example: 0x3fcf3de0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| I (581) example: 0x3fcf3df0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| I (591) example: 0x3fcf3e00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| |
1个回答
根据您提供的信息,您的ESP32-S3开发板在使用IDF 4.4.2和VSCODE时遇到了读取flash时出现0xFF的问题。这个问题可能有以下几个原因:
1. **硬件问题**:可能是开发板的flash芯片存在问题,导致读取数据时出现错误。您可以尝试更换一个开发板进行测试,以排除硬件问题。 2. **软件问题**:可能是IDF版本或者VSCODE的问题。您可以尝试升级到最新的IDF版本,或者尝试使用其他IDE(如Espressif的ESP-IDF VSCode Extension)进行测试。 3. **程序问题**:可能是您的程序在写入或读取flash时存在问题。请检查您的代码,确保在写入和读取flash时使用的地址和长度参数是正确的。 4. **Efuse问题**:您提供的efuse信息可能与问题有关。请检查efuse设置,确保flash加密等设置是正确的。 为了进一步定位问题,您可以尝试以下步骤: 1. 确认您的开发板硬件是否正常工作,例如通过测试其他示例程序。 2. 升级IDF版本到最新版本,或者尝试使用其他IDE。 3. 检查您的程序代码,确保在写入和读取flash时使用的参数是正确的。 4. 检查efuse设置,确保flash加密等设置是正确的。 |
只有小组成员才能发言,加入小组>>
474浏览 6评论
397浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
378浏览 5评论
384浏览 4评论
354浏览 4评论
GMT+8, 2024-9-28 19:40 , Processed in 1.249813 second(s), Total 82, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
