I (29) boot: ESP-IDF v4.4-dirty 2nd stage bootloader
I (29) boot: compile time 17:08:59 I (29) boot: chip revision: 0 I (31) boot.esp32s3: Boot SPI Speed : 80MHz I (36) boot.esp32s3: SPI Mode : DIO I (41) boot.esp32s3: SPI Flash Size : 16MB I (46) boot: Enabling RNG early entropy source... I (51) boot: Partition Table: I (55) boot: ## Label Usage Type ST Offset Length I (62) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (69) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (77) boot: 2 factory factory app 00 00 00010000 00177000 I (84) boot: End of partition table I (88) esp_image: segment 0: paddr=00010020 vaddr=3c0d0020 size=2cb5ch (183132) map I (130) esp_image: segment 1: paddr=0003cb84 vaddr=3fc953d0 size=03494h ( 13460) load I (133) esp_image: segment 2: paddr=00040020 vaddr=42000020 size=cc680h (837248) map I (286) esp_image: segment 3: paddr=0010c6a8 vaddr=3fc98864 size=0131ch ( 4892) load I (287) esp_image: segment 4: paddr=0010d9cc vaddr=40374000 size=113c4h ( 70596) load I (307) esp_image: segment 5: paddr=0011ed98 vaddr=50000000 size=00010h ( 16) load I (314) boot: Loaded app from partition at offset 0x10000 I (314) boot: Disabling RNG early entropy source... I (327) cpu_start: Pro cpu up. I (327) cpu_start: Starting app cpu, entry point is 0x40375204 0x40375204: call_start_cpu1 at D:/ESP32_IDF/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156 I (306) cpu_start: App cpu up. I (341) cpu_start: Pro cpu start user code I (341) cpu_start: cpu freq: 160000000 I (341) cpu_start: Application information: I (344) cpu_start: Project name: tumblevd I (349) cpu_start: App version: V04.00.05 I (354) cpu_start: Compile time: Nov 24 2022 17:08:47 I (360) cpu_start: ELF file SHA256: f0a567c278e805f4... I (366) cpu_start: ESP-IDF: v4.4-dirty I (372) heap_init: Initializing. RAM available for dynamic allocation: I (379) heap_init: At 3FCA0158 len 0003FEA8 (255 KiB): D/IRAM I (385) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (392) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (399) spi_flash: detected chip: gd I (402) spi_flash: flash io: dio I (407) sleep: Configure to isolate all GPIO pins in sleep state I (413) sleep: Enable automatic switching of GPIO sleep configuration I (420) coexist: coexist rom version e7ae62f I (425) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (687) system_api: Base MAC address is not set I (687) system_api: read default base MAC address from EFUSE I (687) main: Tumblevd/68B6B322610E/TX I (687) main: Tumblevd/68B6B322610E/RX W (697) BT_INIT: esp_bt_controller_mem_release not implemented, return OK I (697) BT_INIT: BT controller compile version [6881869] I (707) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 然后WIFI 连接不上 |
1个回答
从您提供的ESP32-S3上电后的日志信息来看,这是ESP32-S3在启动过程中的一系列正常日志输出。但是,您没有提供关于报错的具体信息,所以我无法确定导致报错的具体原因。
根据您提供的日志信息,以下是一些可能的原因: 1. **启动加载程序(Bootloader)问题**:如果Bootloader损坏或不兼容,可能会导致启动失败。但是,从您的日志来看,Bootloader似乎正常运行。 2. **分区表问题**:如果分区表损坏或配置不正确,可能会导致启动失败。您的日志中提到了Partition Table,但没有具体的错误信息。 3. **SPI Flash问题**:如果SPI Flash存在问题,如损坏或读写错误,可能会导致启动失败。您的日志显示SPI Flash大小为16MB,但未提及错误。 4. **随机数生成器(RNG)问题**:如果RNG早期熵源出现问题,可能会影响系统的安全性,但通常不会导致启动失败。 5. **硬件问题**:如果ESP32-S3硬件存在问题,如电源不稳定、连接问题等,可能会导致启动失败。 6. **软件问题**:如果烧录的应用程序存在问题,如代码错误、内存泄漏等,可能会导致启动失败。 为了进一步诊断问题,您可以: - **检查错误信息**:如果您的设备在启动过程中报错,请提供完整的错误信息,以便更准确地诊断问题。 - **检查硬件连接**:确保ESP32-S3的硬件连接正确,电源稳定。 - **检查SPI Flash**:使用专业的工具检查SPI Flash的健康状况。 - **更新固件和软件**:确保您的ESP-IDF版本是最新的,或者至少是与您的硬件兼容的版本。 - **烧录新的分区表和应用程序**:尝试烧录新的分区表和应用程序,以排除软件问题。 如果您能提供更多关于报错的详细信息,我将能够提供更具体的帮助。 |
只有小组成员才能发言,加入小组>>
308浏览 6评论
262浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
256浏览 5评论
258浏览 4评论
237浏览 4评论
GMT+8, 2024-6-22 04:39 , Processed in 0.687925 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
