ESP32在Light sleep模式下无法通过串口唤醒,按照文档该设置的都设置了,网上搜索了半天,找不到任何解决办法,甚至怀疑是不是芯片的BUG了。下面是启动日志,麻烦懂得高手指点一下,不胜感激
ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x9 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x3ac load:0x403c9700,len:0x9b8 load:0x403cc700,len:0x2688 entry 0x403c98c0 [0;32mI (76) spiram: Found 16MBit SPI RAM device[0m [0;32mI (76) spiram: SPI RAM mode: sram 80m[0m [0;32mI (77) spiram: PSRAM initialized, cache is in norESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x9 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x3ac load:0x403c9700,len:0x9b8 load:0x403cc700,len:0x2688 entry 0x403c98c0 [0;32mI (76) spiram: Found 16MBit SPI RAM device[0m [0;32mI (76) spiram: SPI RAM mode: sram 80m[0m [0;32mI (77) spiram: PSRAM initialized, cache is in normal (1-core) mode.[0m [0;32mI (81) cpu_start: Pro cpu up.[0m [0;32mI (85) cpu_start: Starting app cpu, entry point is 0x40375404[0m [0;32mI (0) cpu_start: App cpu up.[0m [0;32mI (321) spiram: SPI SRAM memory test OK[0m [0;32mI (330) cpu_start: Pro cpu start user code[0m [0;32mI (330) cpu_start: cpu freq: 160000000[0m [0;32mI (330) cpu_start: Application information:[0m [0;32mI (333) cpu_start: Project name: DS3[0m [0;32mI (337) cpu_start: App version: 1[0m [0;32mI (342) cpu_start: Compile time: Nov 27 2022 23:59:12[0m [0;32mI (348) cpu_start: ELF file SHA256: 43e6e22afe6fb8c7...[0m [0;32mI (354) cpu_start: ESP-IDF: v4.4.3-dirty[0m [0;32mI (359) heap_init: Initializing. RAM available for dynamic allocation:[0m [0;32mI (366) heap_init: At 3FC97160 len 000525B0 (329 KiB): D/IRAM[0m [0;32mI (373) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM[0m [0;32mI (379) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM[0m [0;32mI (386) heap_init: At 600FE024 len 00001FDC (7 KiB): RTCRAM[0m [0;32mI (392) spiram: Adding pool of 2048K of external SPI memory to heap allocator[0m [0;32mI (400) spi_flash: detected chip: generic[0m [0;32mI (404) spi_flash: flash io: dio[0m [0;33mW (408) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.[0m [0;32mI (422) sleep: Configure to isolate all GPIO pins in sleep state[0m [0;32mI (428) sleep: Enable automatic switching of GPIO sleep configuration[0m [0;32mI (446) pm: Frequency switching config: CPU_MAX: 160, APB_MAX: 80, APB_MIN: 40, Light sleep: DISABLED[0m [0;32mI (447) cpu_start: Starting scheduler on PRO CPU.[0m [0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m [0;32mI (466) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations[0m |
1个回答
根据您提供的信息,您遇到了ESP32-S3在Light sleep模式下无法通过串口唤醒的问题。以下是一些建议和解决方案:
1. 确保您已经正确配置了ESP32-S3的GPIO唤醒源。在Light sleep模式下,ESP32-S3可以通过GPIO唤醒。您需要在进入Light sleep模式之前设置GPIO唤醒源。以下是一个示例代码: ```c #include "driver/gpio.h" void setup_gpio_wakeup() { gpio_config_t io_conf; io_conf.intr_type = GPIO_PIN_INTR_LOW_LEVEL; // 设置GPIO唤醒类型 io_conf.mode = GPIO_MODE_INPUT; io_conf.pin_bit_mask = (1ULL< io_conf.pull_up_en = 1; gpio_config(&io_conf); } ``` 2. 在进入Light sleep模式之前,调用`esp_sleep_enable_gpio_wakeup()`函数以启用GPIO唤醒功能。 ```c void enter_light_sleep() { setup_gpio_wakeup(); // 设置GPIO唤醒源 esp_sleep_enable_gpio_wakeup(); // 启用GPIO唤醒 esp_light_sleep_start(); // 进入Light sleep模式 } ``` 3. 确保您的硬件连接正确。检查您的ESP32-S3开发板和外部设备之间的连接是否正确,确保GPIO唤醒源能够正常工作。 4. 如果问题仍然存在,您可以尝试使用其他唤醒源,例如UART、I2C等。这些唤醒源可能在某些情况下比GPIO唤醒更可靠。 5. 如果您怀疑是芯片的BUG,您可以尝试升级ESP32-S3的固件版本,看看是否有修复这个问题的版本。 6. 最后,您可以在ESP32-S3的官方论坛或社区寻求帮助,看看是否有其他开发者遇到过类似的问题,并找到了解决方案。 希望这些建议能帮助您解决问题。 |
只有小组成员才能发言,加入小组>>
308浏览 6评论
262浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
256浏览 5评论
258浏览 4评论
237浏览 4评论
GMT+8, 2024-6-22 04:40 , Processed in 0.676636 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
