跑lv_demo_widgets时遇到 Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
dump PC指向.../components/lvgl/src/core/lv_disp.c:150 lv_demo_benchmark也遇到同样的问题,只是最后指向的位置不同。 请问是否有人遇到过同样的问题? esp-idf: v5.0.1 lvgl: 8.3.11 ------------------------------------------------------------------------------------------------------------------------------------------------ Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled. Core 0 register dump: PC : 0x42015d62 PS : 0x00060530 A0 : 0x8200dd2e A1 : 0x3fcf35a0 0x42015d62: lv_disp_get_theme at D:/WorkSpace/Espressif/LVGL_ESP32S3/components/lvgl/src/core/lv_disp.c:150 A2 : 0x00000000 A3 : 0x3c05621c A4 : 0x3c056224 A5 : 0x000001e2 A6 : 0x3c05621c A7 : 0x0000000c A8 : 0x82015d60 A9 : 0x3fcf3580 A10 : 0x00000000 A11 : 0x3c05621c A12 : 0x3c056224 A13 : 0x3fcf35a0 A14 : 0x3fcf3580 A15 : 0x0000000c SAR : 0x00000004 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000008 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xfffffffe Backtrace: 0x42015d5f:0x3fcf35a0 0x4200dd2b:0x3fcf35c0 0x4200dd75:0x3fcf35e0 0x42015bde:0x3fcf3600 0x42007fc3:0x3fcf3620 0x42042d77:0x3fcf3640 0x4037d701:0x3fcf3670 0x42015d5f: lv_disp_get_theme at D:/WorkSpace/Espressif/LVGL_ESP32S3/components/lvgl/src/core/lv_disp.c:148 (discriminator 1) 0x4200dd2b: lv_theme_get_from_obj at D:/WorkSpace/Espressif/LVGL_ESP32S3/components/lvgl/src/core/lv_theme.c:40 (discriminator 4) 0x4200dd75: lv_theme_get_color_primary at D:/WorkSpace/Espressif/LVGL_ESP32S3/components/lvgl/src/core/lv_theme.c:102 0x42015bde: lv_demo_widgets at D:/WorkSpace/Espressif/LVGL_ESP32S3/components/lvgl/demos/widgets/lv_demo_widgets.c:162 0x42007fc3: app_main at D:/WorkSpace/Espressif/LVGL_ESP32S3/main/main.c:26 0x42042d77: main_task at D:/Espressif_IDF/Espressif/frameworks/esp-idf-v5.0.1/components/freertos/FreeRTOS-Kernel/portable/port_common.c:131 (discriminator 2) 0x4037d701: vPortTaskWrapper at D:/Espressif_IDF/Espressif/frameworks/esp-idf-v5.0.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:154 ------------------------------------------------------------------------------------------------------------------------------------------------ |
1个回答
遇到LoadProhibited问题时,可以尝试以下步骤来解决:
1. 检查代码:首先检查你的代码,确保没有错误的指针访问或非法内存操作。这可能会导致程序崩溃并触发LoadProhibited异常。 2. 更新ESP-IDF和LVGL版本:确保你使用的ESP-IDF和LVGL版本是最新的,或者至少是兼容的。你提到的ESP-IDF版本是v5.0.1,而LVGL版本是8.3.11。可以尝试更新到最新版本,看看问题是否得到解决。 3. 检查配置:检查你的项目配置,确保所有必要的组件和库都已正确配置。这包括检查makefile或CMakeLists.txt文件,确保所有依赖项都已正确链接。 4. 调试:使用调试工具(如GDB)逐步执行代码,观察在触发LoadProhibited异常之前发生了什么。这可以帮助你找到导致问题的具体代码行。 5. 查看错误日志:检查ESP-IDF的错误日志,看看是否有其他有用的信息可以帮助你诊断问题。 6. 搜索类似问题:在互联网上搜索类似问题,看看是否有其他人遇到过类似的问题,并找到了解决方案。你可以在ESP-IDF和LVGL的GitHub仓库、论坛或其他社区中查找相关信息。 7. 寻求帮助:如果你尝试了以上所有方法仍然无法解决问题,可以考虑在相关社区(如ESP-IDF论坛或LVGL论坛)发帖寻求帮助。在发帖时,请提供尽可能多的详细信息,包括错误日志、代码片段和配置信息,以便其他人能够更好地帮助你。 希望这些建议能帮助你解决LoadProhibited问题。 |
只有小组成员才能发言,加入小组>>
441浏览 6评论
373浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
353浏览 5评论
357浏览 4评论
335浏览 4评论
GMT+8, 2024-9-9 23:44 , Processed in 0.798275 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
