例程中使用了IfxMultican_Can_MsgObj_initConfig这个函数,里面设置了int型的messageId ,只能接收messageId的报文。我看到有acceptanceMask这个参数,但既然设置了Id,mask并没办法起作用啊请问大佬们该怎么配置目前用的是TC297的板子,不过不同板子原理应该差不多。
1个回答
在TC297中,可以使用acceptanceMask参数来配置接收多个id的CAN报文。acceptanceMask参数表示匹配接收的报文id的位掩码,只有与mask中的位相匹配的报文才会被接收。
接口函数IfxMultican_Can_MsgObj_initConfig的原型如下: void IfxMultican_Can_MsgObj_initConfig(IfxMultican_Can_MsgObjConfig *config, IfxMultican_Can_Node *node); 其中IfxMultican_Can_MsgObjConfig结构体定义如下: typedef struct { IfxCAN_MsgObjId id; /**< brief Message object Id */ uint32 acceptanceMask; /**< brief Mask for identifier acceptance filtering */ uint32 acceptanceId; /**< brief Message object IDE and Identifier */ IfxMultican_IdleState control; /**< brief Message object configuration - Use to define the expected status of pins if the CAN module is in its inactive state */ IfxMultican_Frame frame; /**< brief CAN frame type */ IfxMultican_IdleState idleState; /**< brief Expected CAN bus state in idle */ IfxMultican_FrameCounterControl frameCntl; /**< brief Frame Counter Control */ IfxMultican_BitSamplePointControlbitSampling bitSampling; /**< brief bit Sampling technique */ IfxMultican_BitSamplePointControl samplePoint; /**< brief Sample Point */ IfxMultican_DataLengthCode dataLengthCode; /**< brief Message object Data length code */ IfxMultican_ExtendedFrameId extendedFrameId; /**< brief Message object extended frame */ IfxMultican_RxMsgProcessControl rxControl; /**< brief Receive message process control */ IfxMultican_TxMsgProcessControl txControl; /**< brief transmit message process control */ IfxMultican_Exte } IfxMultican_Can_MsgObjConfig; 你可以设置acceptanceMask参数为一个非零值,只有接收到的报文id与acceptanceMask进行与运算后的结果等于acceptanceId才会被接收。示例代码如下: ```c IfxMultican_Can_MsgObjConfig msgObjConfig; IfxMultican_Can_MsgObj_initConfig(&msgObjConfig, &canNode); msgObjConfig.id = messageId; // 设置报文id msgObjConfig.acceptanceMask = mask; // 设置mask,用于接收多个id msgObjConfig.acceptanceId = messageId; // 设置接收id IfxMultican_Can_MsgObj_init(&msgObj, &msgObjConfig); // 初始化消息对象 ``` 需要注意的是,以上代码只会接收通过acceptanceMask和acceptanceId指定的报文id,如果要接收多个id,需要配置不同的消息对象,然后分别设置不同的acceptanceId和acceptanceMask。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
《DNESP32S3使用指南-IDF版_V1.6》第三十章 DHT11数字温湿度传感器
122 浏览 0 评论
565 浏览 0 评论
【敏矽微ME32G070开发板免费体验】之原厂2812测试例程解析
772 浏览 0 评论
948 浏览 2 评论
《DNESP32S3使用指南-IDF版_V1.6》第二十六章 INFRARED_RECEPTION实验
658 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
12043 浏览 31 评论
GMT+8, 2024-12-27 02:18 , Processed in 0.503131 second(s), Total 41, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
