使用STM32的SPI进行模块通讯,能够正常读取ID寄存器,电源控制寄存器复位默认值为0x01,写入0x00后再次读取值还是0x01,查看电源是稳定正常的,求解答这种奇怪的问题。以下是我用逻辑分析仪抓取到的数据波形,以及代码:
这里是抓取到的读取ID寄存器的数据波形 这里是写入电源控制寄存器的值0x00 读取到的电源控制寄存器与温度寄存器的值 以下是代码 /* 函数功能:初始化ADXL355模块 参 数:无 返 回 值:无 */ void ADXL355_Init(void) { SPIx_Init(SPI_2); //STM_SPI1_Init(); GPIO_InitTypeDef GPIO_InitStructure; //开启PA和PC口时钟 RCC_AHBPeriphClockCmd(ADXL355_CSN_GPIO_CLK | ADXL355_DRDY_GPIO_CLK, ENABLE); GPIO_Structinit( GPIO_InitStructure); //CS和电源引脚初始化配置 //GPIO_InitStructure.GPIO_Pin = ADXL355_CSN_PIN | ADXL355_PWR_PIN; GPIO_InitStructure.GPIO_Pin = ADXL355_CSN_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(ADXL355_CSN_GPIO_PORT, GPIO_InitStructure); ADXL355_CS_HIGH(); //取消片选信号 //DRDY,INT1,INT2引脚初始化配置 PC6 PC7 PC8 //GPIO_InitStructure.GPIO_Pin = ADXL355_DRDY_PIN | ADXL355_INT2_PIN | ADXL355_INT1_PIN; GPIO_InitStructure.GPIO_Pin = ADXL355_DRDY_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_Init(ADXL355_DRDY_GPIO_PORT, GPIO_InitStructure); ADXL355_Reset(); //复位传感器 delay_ms(10); uint8_t devID ; uint8_t memsID; uint8_t pritID; uint8_t revID; ReadDevID( devID, memsID, pritID, revID); //读取传感器ID printf("devID: %0x, memsID: %0x,pritID: %0x, revID: %0xrn",devID, memsID, pritID, revID); /*配置传感器寄存器参数*/ ADXL355_RegConfig(); /* todo: 配置外部中断PC6 PC7 对应中断线2 PC8 对应中断线3 */ // NVIC_InitTypeDef NVIC_InitStructure; // EXTI_InitTypeDef EXTI_InitStructure; // NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3); // /* Enable the GPIOB Interrupt */ // // NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn; // NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; // NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; // NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // NVIC_Init( NVIC_InitStructure); // // // SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource6); // EXTI_StructInit( EXTI_InitStructure);//将各个参数清零 // // EXTI_InitStructure.EXTI_Line = EXTI_Line6; // EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; // EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising; // EXTI_InitStructure.EXTI_LineCmd = ENABLE; //开中断 // EXTI_Init( EXTI_InitStructure); // delay_ms(10); ADXL355_Reset(); //复位传感器 delay_ms(1000); //进入测量模式 ADXL355_SetPowerMode(ADXL355_MEASMODE); delay_ms(10); //ADXL355_PWR_LOW(); //关闭电源输出 } /* 函数功能:adxl355 向寄存器写数据函数 参 数:unsigned char addr, 需要写入的字节地址 unsigned char *data 需要写入的数据 返 回 值:无 */ void WriteReg_ADXL355(uint8_t addr, uint8_t data) { ADXL355_CS_LOW(); //片选信号 STM_SPI2_WriteRead(addr<<1 | 0x00); STM_SPI2_WriteRead(data); ADXL355_CS_HIGH(); //取消片选信号 } /* 函数功能:从adxl355中读取单字节数据 参 数:unsigned char addr, 需要读取的寄存器地址 unsigned char *pdata 读取到的数据返回值指针 返 回 值:无 */ void ReadReg_ADXL355(uint8_t addr, uint8_t *pdata) { ADXL355_CS_LOW(); //片选信号 STM_SPI2_WriteRead(addr<<1 |0x01); *pdata = STM_SPI2_WriteRead(0); ADXL355_CS_HIGH(); //取消片选信号 } /* 函数功能:从adxl355中读取多字节数据 参 数:unsigned uint8_t *addr, 需要读取的寄存器地址 unsigned uint8_t *pdata 读取到的数据返回值指针 int bytes 需要读取的字节数 返 回 值:无 */ void ReadRegs_ADXL355(uint8_t addr, uint8_t *pdata, int bytes) { ADXL355_CS_LOW(); //片选信号 STM_SPI2_WriteRead(addr); int i = 0; for(i = 0; i< bytes; i++) { *pdata = STM_SPI2_WriteRead(0); pdata ++; } ADXL355_CS_HIGH(); //取消片选信号 } /* 函数功能:读取设备ID,MEMSID,当前版本ID,历史版本ID 0xAD 0x1D 0xED 0x00 参 数:uint8_t *devID, 设备ID指针 uint8_t *memsID, MEMSID指针 uint8_t *pritID, 当前版本ID指针 uint8_t *revID 历史版本ID指针 返 回 值:无 */ void ReadDevID(uint8_t *devID, uint8_t *memsID, uint8_t *pritID, uint8_t *revID) { ReadReg_ADXL355(XL355_DEVID_AD, devID); ReadReg_ADXL355(XL355_DEVID_MST, memsID); ReadReg_ADXL355(XL355_PARTID, pritID); ReadReg_ADXL355(XL355_REVID, revID); } /* 函数功能:复位adxl355设备 参 数:无 返 回 值:无 */ void ADXL355_Reset(void) { WriteReg_ADXL355(XL355_RESET, ADXL355_REST); } /* 函数功能:设置adxl355电源工作模式 参 数:uint8_t mode 需要设置的工作模式 选择 ADXL355_STANDBY 待机模式 ADXL355_MEASMODE 测量模式 以上两种参数其中一种 返 回 值:无 */ void ADXL355_SetPowerMode(uint8_t mode) { WriteReg_ADXL355(XL355_POWER_CTL, mode); } /* 函数功能:配置adxl355寄存器 参 数:无 返 回 值:无 */ void ADXL355_RegConfig(void) { uint8_t setvalue = 0x00; /* 设置滤波寄存器输出速率 关闭高通滤波使能,设置低通滤波输出范围125 Hz and 31.25 Hz */ setvalue = ADXL355_HPF_CORNER_OFF|ADXL355_LPF_125; WriteReg_ADXL355(XL355_FILTER, setvalue); delay_ms(1); /* 选择中断极性和测量范围 高电平产生中断,2g测量范围 */ setvalue = (0x01 << 6)|(0x01<<0); WriteReg_ADXL355(XL355_RANGE, setvalue); delay_ms(1); /* 配置FIFO中存储样本数量 */ // setvalue = 0x60; //FIFO中最大存储96条样本数据 // WriteReg_ADXL355(XL355_FIFO_SAMPLES, setvalue); // /* 活动检测功能关闭 */ //默认关闭活动使能,阈值,和活动检测计数值 /* 开启FIFO_FULL和RDY中断使能位 */ //FIFO_FULL在INT2引脚上生成中断信号,RDY在INT1引脚上生成中断信号 // setvalue = ADXL355_INT_FULL_EN2|ADXL355_INT_RDY_EN1; // WriteReg_ADXL355(XL355_INT_MAP, setvalue); /* 外部同步功能默认关闭 */ /* 开启自测功能 */ // setvalue = ADXL355_ST2_TEST | ADXL355_ST1_TEST; // WriteReg_ADXL355(XL355_SELF_TEST, setvalue); // delay_ms(1); // //关闭自测功能,开始正常工作 // setvalue = 0x00; // WriteReg_ADXL355(XL355_SELF_TEST, setvalue); } /* 函数功能:读取adxl355寄存器温度数据 参 数:无 返 回 值:读取到的值 */ float ADXL355_Temperature(void) { short Temp = 0; uint8_t tempH = 0; uint8_t tempL = 0; ReadReg_ADXL355(XL355_TEMP2, tempH); ReadReg_ADXL355(XL355_TEMP1, tempL); Temp = (short)(tempH 0x0F) << 8 | tempL; float Temperature = (float)((Temp - ADXL355_TEMP_BIAS)/ADXL355_TEMP_SLOPE + 25); return Temperature; } /* 函数功能:转换adxl355角度数据 参 数:需要转换的加速度值 返 回 值: 有符号整型角度值 */ int ADXL355_Acceleration_Data_Conversion (uint32_t ui32SensorData) { int volatile i32Conversion = 0; ui32SensorData = (ui32SensorData >> 4); ui32SensorData = (ui32SensorData 0x000FFFFF); if((ui32SensorData 0x00080000) == 0x00080000){ i32Conversion = (ui32SensorData | 0xFFF00000); } else{ i32Conversion = ui32SensorData; } return i32Conversion; } /* 函数功能:读取adxl355角度寄存器数据 参 数:无 返 回 值:-1 失败 1 成功 */ int ADXL355_XYZ_AXIS(int *Xangle, int *Yangle, int *Zangle) { uint8_t angleH = 0; uint8_t angleM = 0; uint8_t angleL = 0; uint8_t state = 0; int i =0; do { ReadReg_ADXL355(XL355_STATUS, state);//读取状态寄存器 i ++; }while(!(state 0x01) i<500); if(i >=500) { *Xangle = 0.00; *Yangle = 0.00; *Zangle = 0.00; return -1; } ReadReg_ADXL355(XL355_XDATA3, angleH); ReadReg_ADXL355(XL355_XDATA2, angleM); ReadReg_ADXL355(XL355_XDATA1, angleL); uint32_t ui32SensorX = ((uint32_t)angleH << 12)|(uint32_t)(angleM << 4) | (angleL 0xF0>>4); *Xangle = ADXL355_Acceleration_Data_Conversion(ui32SensorX); ReadReg_ADXL355(XL355_YDATA3, angleH); ReadReg_ADXL355(XL355_YDATA2, angleM); ReadReg_ADXL355(XL355_YDATA1, angleL); uint32_t ui32SensorY = ((uint32_t)angleH << 12)|(uint32_t)(angleM << 4) | (angleL 0xF0>>4); *Yangle = ADXL355_Acceleration_Data_Conversion(ui32SensorY); ReadReg_ADXL355(XL355_ZDATA3, angleH); ReadReg_ADXL355(XL355_ZDATA2, angleM); ReadReg_ADXL355(XL355_ZDATA1, angleL); uint32_t ui32SensorZ = ((uint32_t)angleH << 12)|(uint32_t)(angleM << 4) | (angleL 0xF0>>4); *Zangle = ADXL355_Acceleration_Data_Conversion(ui32SensorZ); return 0; } /* 函数功能:从FIFO中读取adxl355角度数据 参 数:无 返 回 值:读取到的值 */ int ADXL355_FIFOREAD_AXIS(int *Xangle, int *Yangle, int *Zangle) { int X_angle = 0, Y_angle = 0, Z_angle = 0; uint8_t angleXbuff[3] = {0}; uint8_t angleYbuff[3] = {0}; uint8_t angleZbuff[3] = {0}; int i = 0; do { i ++; } while((!g_Flag_adxl355_int) (i < 500)); if(i >= 500) { *Xangle = 0.00; *Yangle = 0.00; *Zangle = 0.00; return -1; } g_Flag_adxl355_int = 0; //清除中断读取标志位 ReadRegs_ADXL355(XL355_FIFO_DATA, angleXbuff, 3); ReadRegs_ADXL355(XL355_FIFO_DATA, angleYbuff, 3); ReadRegs_ADXL355(XL355_FIFO_DATA, angleZbuff, 3); X_angle = (int)((angleXbuff[0] 0xF0>>4) << 16)|(short)(angleXbuff[1] << 8) | angleXbuff[2]; uint8_t offset_X_H = 0; uint8_t offset_X_L = 0; ReadReg_ADXL355(XL355_OFFSET_X_H, offset_X_H); ReadReg_ADXL355(XL355_OFFSET_X_L, offset_X_L); X_angle = X_angle + ((int)(offset_X_H << 8)|(offset_X_L)); *Xangle = ADXL355_Acceleration_Data_Conversion(X_angle); Y_angle = (int)((angleXbuff[0] 0xF0>>4) << 16)|(short)(angleYbuff[1] << 8) | angleYbuff[2]; uint8_t offset_Y_H = 0; uint8_t offset_Y_L = 0; ReadReg_ADXL355(XL355_OFFSET_Y_H, offset_Y_H); ReadReg_ADXL355(XL355_OFFSET_Y_L, offset_Y_L); Y_angle = Y_angle + ((int)(offset_Y_H << 8)|(offset_Y_L)); *Yangle = ADXL355_Acceleration_Data_Conversion(Y_angle); Z_angle = (int)((angleXbuff[0] 0xF0>>4) << 16)|(short)(angleZbuff[1] << 8) | angleZbuff[2]; uint8_t offset_Z_H = 0; uint8_t offset_Z_L = 0; ReadReg_ADXL355(XL355_OFFSET_Z_H, offset_Z_H); ReadReg_ADXL355(XL355_OFFSET_Z_L, offset_Z_L); Z_angle = Z_angle + ((int)(offset_Z_H << 8)|(offset_Z_L)); *Zangle = ADXL355_Acceleration_Data_Conversion(Z_angle); printf("X_angle = %d, Y_angle = %d, Z_angle = %drn",X_angle, Y_angle, Z_angle); return 0; } /* 外部中断服务函数 */ void EXTI2_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line6) != RESET) { EXTI_ClearFlag(EXTI_Line6); EXTI_ClearITPendingBit(EXTI_Line6); //清中断标志 g_Flag_adxl355_int = 1; } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2323 浏览 1 评论
8114 浏览 0 评论
1934 浏览 0 评论
VL53L5CX #高达 8x8 多区域测距和 63°对角线宽视场 飞行时间多区域测距传感器
17318 浏览 0 评论
【罗姆传感器评估板试用体验连载】罗姆传感器整合进同一个示例程序
21958 浏览 0 评论
浏览过的版块 |
GMT+8, 2024-11-22 07:37 , Processed in 0.549003 second(s), Total 74, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
