1.由于手工焊接ADE7953不能保证完全可靠,如何验证该芯片通电后正常工作?
1)我已测量过晶振起振 --> ok 2)单片机端询问版本信息没有回应, 采用STM8S103 芯片,程序如下,请各位帮忙看看 void GPIO_Config(void) { /* Initialize I/Os in Output Mode */ GPIO_Init(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GR_GPIO_PINS, GPIO_MODE_OUT_PP_LOW_FAST);//GPIO_MODE_OUT_PP_LOW_FAST GPIO_Init(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_RE_GPIO_PINS, GPIO_MODE_OUT_PP_LOW_FAST);//GPIO_MODE_OUT_PP_LOW_FAST GPIO_Init(RS485_EN_PORT, (GPIO_Pin_TypeDef)RS485_EN_PINS, GPIO_MODE_OUT_PP_HIGH_FAST ); GPIO_Init(SPI_CS_PORT, (GPIO_Pin_TypeDef)SPI_CS_PIN, GPIO_MODE_OUT_PP_HIGH_FAST);//SPI多신튬朞똥왯多신놓迦뺏 GPIO_Init(SPI_GPIO_PORT, (GPIO_Pin_TypeDef)SPI_MISO_PIN, GPIO_MODE_IN_FL_NO_IT); GPIO_Init(SPI_GPIO_PORT, (GPIO_Pin_TypeDef)SPI_MOSI_PIN, GPIO_MODE_OUT_PP_HIGH_FAST); GPIO_Init(SPI_GPIO_PORT, (GPIO_Pin_TypeDef)SPI_CLK_PIN, GPIO_MODE_OUT_PP_HIGH_FAST); } static void CLK_Config(void) { CLK_DeInit(); /* Clock divider to HSI/1 */ //CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV8); /* Configure the Fcpu to DIV1*/ //CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV16); /* Configure the HSI prescaler to the optimal value */ CLK_SYSCLKConfig(CLK_PRESCALER_HSIDIV8); /* Output Fcpu on CLK_CCO pin */ // CLK_CCOConfig(CLK_OUTPUT_MASTER); // CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO, CLK_SOURCE_HSE, DISABLE, CLK_CURRENTCLOCKSTATE_DISABLE); } void SPI_Config(void) { /* SPI configuration */ SPI_DeInit(); /* Initialize SPI in Master mode */ SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_64, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_HIGH, SPI_CLOCKPHASE_2EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_SOFT,(uint8_t)0x07); SPI_Cmd(ENABLE); SET_CS(); } char SPIRead1Byte(unsigned int address) { char readout; unsigned char szTxData[7]; char i; CLR_CS(); szTxData[0] = (char)(address>>8); szTxData[1] = (char)(address); szTxData[2] = 0x80; for(i=0;i<3;i++) { while((SPI->SR SPI_FLAG_TXE) == RESET); SPI_SendData(szTxData[i]); } DummyRd = SPI_ReceiveData(); while((SPI->SR SPI_FLAG_RXNE) == RESET); readout = SPI_ReceiveData(); SET_CS() ; return(readout); } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
/9
GMT+8, 2025-12-2 16:23 , Processed in 0.592384 second(s), Total 72, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3565
