去除android正在启动弹窗 开机以后,设备会有一个android is starting的弹框,该界面就是FallbackHome。
FallbackHome机制是为了在系统还没有解锁前先进入Setting中的android正在启动弹窗 的页面等系统完全解锁后,然后进入默认Launcher但是弹窗也会影响产品效果,所以最后去掉这个弹窗不显示在桌面壁纸,直接进入Launcher。 1、延长开机动画 在解锁后直接进去Launcher 在WindowManagerService.java中,注释掉退出开机动画的逻辑,延时开机动画 路径:frameworks/base/services/core/java/com/android/server/wm/WindowManagerService.java private void performEnableScreen() { synchronized (mGlobalLock) { if (DEBUG_BOOT) Slog.i(TAG_WM, "performEnableScreen: mDisplayEnabled=" + mDisplayEnabled + " mForceDisplayEnabled=" + mForceDisplayEnabled + " mShowingBootMessages=" + mShowingBootMessages + " mSystemBooted=" + mSystemBooted + " mOnlyCore=" + mOnlyCore, new RuntimeException("here").fillInStackTrace()); if (mDisplayEnabled) { return; } if (!mSystemBooted && !mShowingBootMessages) { return; } if (!mShowingBootMessages && !mPolicy.canDismissBootAnimation()) { return; } // Don't enable the screen until all existing windows have been drawn. if (!mForceDisplayEnabled // TODO(multidisplay): Expand to all displays? && getDefaultDisplayContentLocked().checkWaitingForWindows()) { return; } //在这里处理播放完开机动画后是否退出开机动画,所以注释掉 //phoebe add for Extend Animation at ActivityRecord.java onWindowsDrawn start /*if (!mBootAnimationStopped) { Trace.asyncTraceBegin(TRACE_TAG_WINDOW_MANAGER, "Stop bootanim", 0); // stop boot animation // formerly we would just kill the process, but we now ask it to exit so it // can choose where to stop the animation. SystemProperties.set("service.bootanim.exit", "1"); mBootAnimationStopped = true; } if (!mForceDisplayEnabled && !checkBootAnimationCompleteLocked()) { if (DEBUG_BOOT) Slog.i(TAG_WM, "performEnableScreen: Waiting for anim complete"); return; } try { IBinder surfaceFlinger = ServiceManager.getService("SurfaceFlinger"); if (surfaceFlinger != null) { Slog.i(TAG_WM, "******* TELLING SURFACE FLINGER WE ARE BOOTED!"); Parcel data = Parcel.obtain(); data.writeInterfaceToken("android.ui.ISurfaceComposer"); surfaceFlinger.transact(IBinder.FIRST_CALL_TRANSACTION, // BOOT_FINISHED data, null, 0); data.recycle(); } } catch (RemoteException ex) { Slog.e(TAG_WM, "Boot completed: SurfaceFlinger is dead!"); }*/ //phoebe add for Extend Animation at ActivityRecord.java onWindowsDrawn end EventLog.writeEvent(EventLogTags.WM_BOOT_ANIMATION_DONE, SystemClock.uptimeMillis()); Trace.asyncTraceEnd(TRACE_TAG_WINDOW_MANAGER, "Stop bootanim", 0); mDisplayEnabled = true; if (DEBUG_SCREEN_ON || DEBUG_BOOT) Slog.i(TAG_WM, "******************** ENABLING SCREEN!"); // Enable input dispatch. mInputManagerCallback.setEventDispatchingLw(mEventDispatchingEnabled); } try { mActivityManager.bootAnimationComplete(); } catch (RemoteException e) { } mPolicy.enableScreenAfterBoot(); // Make sure the last requested orientation has been applied. updateRotationUnchecked(false, false); } 2、解锁结束后退出开机动画在ActivityRecord中onWindowsDrawn( 退出动画 开启系统手势触摸功能) 路径:frameworks/base/services/core/java/com/android/server/wm/ActivityRecord.java /** Called when the windows associated app window container are drawn. */ public void onWindowsDrawn(boolean drawn, long timestamp) { synchronized (mAtmService.mGlobalLock) { mDrawn = drawn; if (!drawn) { return; } final WindowingModeTransitionInfoSnapshot info = mStackSupervisor .getActivityMetricsLogger().notifyWindowsDrawn(getWindowingMode(), timestamp); final int windowsDrawnDelayMs = info != null ? info.windowsDrawnDelayMs : INVALID_DELAY; final @LaunchState int launchState = info != null ? info.getLaunchState() : -1; mStackSupervisor.reportActivityLaunchedLocked(false /* timeout */, this, windowsDrawnDelayMs, launchState); mStackSupervisor.stopWaitingForActivityVisible(this); finishLaunchTickingLocked(); if (task != null) { task.hasBeenVisible = true; } //解锁后退出开机动画 // phoebe add for exit bootanim start if (isHomeIntent(intent) && shortComponentName != null && !shortComponentName.contains("FallbackHome")) { SystemProperties.set("service.bootanim.exit", "1"); android.util.Log.e("ActivityRecord", "real home....." + shortComponentName); try { IBinder surfaceFlinger = ServiceManager.getService("SurfaceFlinger"); if (surfaceFlinger != null) { Slog.i(TAG_WM, "******* TELLING SURFACE FLINGER WE ARE BOOTED!"); Parcel data = Parcel.obtain(); data.writeInterfaceToken("android.ui.ISurfaceComposer"); surfaceFlinger.transact(IBinder.FIRST_CALL_TRANSACTION, // BOOT_FINISHED data, null, 0); data.recycle(); } } catch (RemoteException ex) { Slog.e(TAG, "Boot completed: SurfaceFlinger is dead!"); } } // phoebe add for exit bootanim end //modify for performance begin Bundle b = new Bundle(); b.putLong(ProcessInfo.KEY_LAUNCH_TIME, (long)windowsDrawnDelayMs); b.putBoolean(ProcessInfo.KEY_FULLSCREEN, (task != null && task.mFullscreen)); mAtmService.notifyActivityStateChange(this.intent, ProcessInfo.ACTIVITY_STATE_LAUNCHDONE, b); //modify for performance end } } 3、去掉Settings 的Android 正在启动… 弹窗 //packages\apps\Settings\src\com\android\settings\FallbackHome.java private final Runnable mProgressTimeoutRunnable = () -> { //phoebe add for remove android is starting tips // View v = getLayoutInflater().inflate( // R.layout.fallback_home_finishing_boot, null /* root */); // setContentView(v); // v.setAlpha(0f); // v.animate() // .alpha(1f) // .setDuration(500) // .setInterpolator(AnimationUtils.loadInterpolator( // this, android.R.interpolator.fast_out_slow_in)) // .start(); getWindow().addFlags(LayoutParams.FLAG_KEEP_SCREEN_ON); }; 重新编译烧录即可! -END- |
基于米尔MYC-LR3576开发板的实时视频识别系统设计与实现
220 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的深入学习之阻塞I/O与非阻塞I/O
453 浏览 0 评论
大神们,想知道你们都用什么ide编程调试器? Arduino IDE?还是 e2studio ?还有其他吗?哪个好用呢
555 浏览 0 评论
854 浏览 0 评论
825 浏览 0 评论
/9
GMT+8, 2025-12-2 23:16 , Processed in 0.586505 second(s), Total 65, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
