使用 python 来驱动 SPI 小屏幕,官方提供有驱动 2.4 寸小屏幕的 demo 代码(链接 https://doc.rvspace.org/VisionFive2/Application_Notes/VisionFive2_AN_P_Using_SPI_LCD/index.html ),我手上有一个 1.8 寸的,使用昉·星光2开发板来驱动它显示图片。
Python 环境准备
先安装一下 python3 和 python3-pip
apt install python3
apt-get install python3-pip
使用 pip 默认源下载较慢,设置一下 pip 的镜像源为中科大源
pip config set global.index-url https:
安装一些支持包
apt install libxml2-dev libxslt-dev
python3 -m pip install requests wget bs4
将下面的代码保存为 install.py 然后使用 python3 install.py 执行
import requests
import wget
import sys
import os
from bs4 import BeautifulSoup
def parse_data(link_addr, class_type, key_str):
req = requests.get(url=link_addr)
req.encoding = "utf-8"
html=req.text
soup = BeautifulSoup(req.text,features="html.parser")
package_version = soup.find(class_type,class_=key_str)
dd = package_version.text.strip()
data = dd.split()
return data
def parse_link(link_addr, class_type, key_str):
html=req.text
search_data = soup.find(class_type,class_=key_str)
search_data_2 = search_data.find("a")
dl_link_get = search_data_2.get("href")
return dl_link_get
def get_dl_addr_page():
link_address = "https://pypi.org/project/VisionFive.gpio/#history"
key_str = "release__version"
class_key = "p"
data_get = parse_data(link_address, class_key, key_str)
latest_version = data_get[0]
dl_addr_page = "https://pypi.org/project/VisionFive.gpio/{}/#files".format(latest_version)
return dl_addr_page
def get_dl_addr_of_latest_version(link_addr):
key_str = "card file__card"
class_key = "div"
addr_get = parse_link(link_addr, class_key, key_str)
return addr_get
def main():
dl_addr_p = get_dl_addr_page()
whl_dl_addr = get_dl_addr_of_latest_version(dl_addr_p)
whl_name = whl_dl_addr.split("/")[-1]
whl_name_suffix = os.path.splitext(whl_name)[-1]
whl_name_prefix = os.path.splitext(whl_name)[0]
whl_name_prefix_no_platform = whl_name_prefix[0: len(whl_name_prefix) - 3]
new_platform = "linux_riscv64"
rename_whl_name = "{}{}{}".format(whl_name_prefix_no_platform, new_platform, whl_name_suffix)
wget.download(whl_dl_addr, out=rename_whl_name)
os.system("pip install " + rename_whl_name)
os.system("rm -rf " + rename_whl_name)
if __name__ == '__main__':
sys.exit(main())
安装两个软件包,这两个软件包用途为后续在屏幕上显示图片用的
pip install pillow numpy
至此,驱动 SPI 小屏幕的基本环境就搭建完成了,下面在官方的代码基础上进行修改
驱动代码编写
这里用的是 1.8 寸的,驱动芯片为 ST7735S,分辨率 128*160 的 SPI 屏幕,将官方的 LCD2inch4_lib.py 修改为如下内容,主要是修改了分辨率、初始化序列和 lcd_clear 函数的实现
import os
import sys
import time
import logging
import VisionFive.spi as spi
import VisionFive.gpio as gpio
import numpy as np
from PIL import Image,ImageDraw,ImageFont
class LCD_dev():
width = 128
height = 160
def __init__(self, rst_pin, dc_pin, dev):
self.rstpin = rst_pin
self.dcpin = dc_pin
self.spidev = dev
spi.getdev(self.spidev)
spi.setmode(40000000, 0, 8)
gpio.setup(self.rstpin, gpio.OUT)
gpio.setup(self.dcpin, gpio.OUT)
def __del__(self):
spi.freedev()
def lcd_reset(self):
gpio.output(self.rstpin, gpio.HIGH)
time.sleep(0.01)
gpio.output(self.rstpin, gpio.LOW)
time.sleep(0.01)
time.sleep(0.01)
def lcd_spisend(self, data):
spi.transfer(data)
def lcd_sendcmd(self, cmd):
gpio.output(self.dcpin, gpio.LOW)
spi.transfer(cmd)
def lcd_senddata(self,data):
gpio.output(self.dcpin, gpio.HIGH)
spi.transfer(data)
def lcd_sendnbytes(self, data):
spi.write(data)
def lcd_init(self):
self.lcd_reset()
self.lcd_sendcmd(0x11)
self.lcd_sendcmd(0x09)
self.lcd_senddata(0x00)
self.lcd_sendcmd(0xB1)
self.lcd_senddata(0x05)
self.lcd_senddata(0x3C)
self.lcd_sendcmd(0xB2)
self.lcd_sendcmd(0xB3)
self.lcd_sendcmd(0xB4)
self.lcd_senddata(0x03)
self.lcd_sendcmd(0xC0)
self.lcd_senddata(0x28)
self.lcd_senddata(0x08)
self.lcd_senddata(0x04)
self.lcd_sendcmd(0xC1)
self.lcd_senddata(0XC0)
self.lcd_sendcmd(0xC2)
self.lcd_senddata(0x0D)
self.lcd_sendcmd(0xC3)
self.lcd_senddata(0x8D)
self.lcd_senddata(0x2A)
self.lcd_sendcmd(0xC4)
self.lcd_senddata(0xEE)
self.lcd_sendcmd(0xC5)
self.lcd_senddata(0x1A)
self.lcd_sendcmd(0x36)
self.lcd_sendcmd(0xE0)
self.lcd_senddata(0x22)
self.lcd_senddata(0x07)
self.lcd_senddata(0x0A)
self.lcd_senddata(0x2E)
self.lcd_senddata(0x30)
self.lcd_senddata(0x25)
self.lcd_senddata(0x26)
self.lcd_senddata(0x3A)
self.lcd_senddata(0x01)
self.lcd_senddata(0x13)
self.lcd_sendcmd(0xE1)
self.lcd_senddata(0x16)
self.lcd_senddata(0x06)
self.lcd_senddata(0x2D)
self.lcd_senddata(0x23)
self.lcd_senddata(0x27)
self.lcd_senddata(0x3B)
self.lcd_sendcmd(0x3A)
self.lcd_sendcmd(0x29)
def lcd_setPos(self, Xstart, Ystart, Xend, Yend):
self.lcd_sendcmd(0x2a)
self.lcd_senddata((Xstart + 2) >>8)
self.lcd_senddata((Xstart + 2) & 0xff)
self.lcd_senddata((Xend + 1) >> 8)
self.lcd_senddata((Xend + 1) & 0xff)
self.lcd_sendcmd(0x2b)
self.lcd_senddata((Ystart + 1) >>8)
self.lcd_senddata((Ystart + 1) & 0xff)
self.lcd_senddata((Yend + 2) >> 8)
self.lcd_senddata((Yend + 2) & 0xff)
self.lcd_sendcmd(0x2C)
def lcd_clear(self, color):
pix = np.zeros((self.height, self.width, 2), dtype = np.uint8)
pix[...,[0]] = color >> 8
pix[...,[1]] = color
pix = pix.flatten().tolist()
self.lcd_setPos(0, 0, self.width, self.height)
self.lcd_sendnbytes(pix)
def lcd_ShowImage(self, Image, Xstart, Ystart):
imwidth, imheight = Image.size
img = np.asarray(Image)
pix = np.zeros((imheight, imwidth, 2), dtype = np.uint8)
pix[...,[0]] = np.add(np.bitwise_and(img[...,[0]],0xF8),np.right_shift(img[...,[1]],5))
pix[...,[1]] = np.add(np.bitwise_and(np.left_shift(img[...,[1]],3),0xE0), np.right_shift(img[...,[2]],3))
编写应用代码来调用前文的驱动相关的代码,实现
Please make sure the 2.4inch LCD Moudle is connected to the correct pins.
The following table describes how to connect the 2.4inch LCD Module to the 40-pin header.
__2.4inch LCD Module___Pin Number_____Pin Name
VCC 17 3.3 V Power
GND 39 GND
DIN 19 SPI MOSI
CLK 23 SPI SCLK
CS 24 SPI CE0
DC 40 GPIO44
RST 11 GPIO42
BL 18 GPIO51
import os
import sys
import time
import logging
sys.path.append("..")
import VisionFive.boardtype as board_t
import LCD_dev
Demo modification ans new function description
I. add the clear() function to fill LCD screen with white
II. give a hexadecimal value of white
III. cycle through multiple pictures
RED = 0xf800
BLUE = 0x001f
GREEN = 0x07e0
BLACK = 0x0000
def main():
print('-----------lcd demo-------------')
vf_t = board_t.boardtype()
SPI_DEVICE = "/dev/spidev1.0"
disp = LCD_dev.LCD_dev(11, 40, SPI_DEVICE)
disp.lcd_init()
disp.lcd_clear(BLACK)
image = Image.open('./rvspace.jpg')
disp.lcd_ShowImage(image, 50, 0)
time.sleep(1)
while True:
time.sleep(1)
disp.lcd_clear(RED)
time.sleep(1)
disp.lcd_clear(BLUE)
time.sleep(1)
disp.lcd_clear(GREEN)
if __name__=="__main__":
main()
