我正在尝试使用本指南来融合我们的 LS1017A 。我已经为 TA_PROG_SFP 提供了 1.8V,我正在尝试使用以下命令使用 fuse_fip.bin 对 OTPMK 和 SRKH 进行编程。不幸的是,我总是收到以下错误。fuse_fip.bin 有问题吗?
Model: MBLS1028A starterkit DRAM: 958 MiB (DDR4, 32-bit, CL=11, ECC on) caam_jr: caam not found Initialized clockgen Using SERDES1 Protocol: 60248 (0xeb58) PCIe2: pcie@3500000 Root Complex: no link Core: 40 devices, 20 uclasses, devicetree: separate WDT: Started watchdog@c000000 with servicing (60s timeout) WDT: Started watchdog@c010000 with servicing (60s timeout) MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from SPIFlash... SF: Detected mx66u51235f with page size 256 Bytes, erase size 64 KiB, total 64 MiB *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial SEC0: RNG instantiated Net: Warning: enetc-0 (eth0) using random MAC address - 82:e5:78:5e:a0:4d eth0: enetc-0 [PRIME] Warning: enetc-1 (eth1) using random MAC address - 4a:ed:d9:50:d0:c2 , eth1: enetc-1 Warning: enetc-2 (eth2) using random MAC address - 92:e6:66:05:46:85 , eth2: enetc-2, eth3: swp0, eth4: swp1, eth5: swp2, eth6: swp3 Hit any key to stop autoboot: 0 => load mmc 0 $loadaddr fuse_fip.bin 224 bytes read in 5 ms (43 KiB/s) => protect off 64880000 +$filesize => erase 64880000 +$filesize => cp.b $loadaddr 64880000 $filesize "Synchronous Abort" handler, esr 0x96000045 elr: 0000000082077888 lr : 000000008201371c (reloc) elr: 00000000b7b6d888 lr : 00000000b7b0971c x0 : 0000000064880000 x1 : 0000000092000000 x2 : 00000000000000e0 x3 : 0000000000000000 x4 : 12345678aa640001 x5 : 0000000000000000 x6 : 00000000b7b7d09e x7 : 0000000000000044 x8 : 0000000000000010 x9 : 0000000000000008 x10: 0000000000000000 x11: 00000000b78fa708 x12: 0000000000000000 x13: 0000000000000200 x14: 00000000b78ea340 x15: 0000000000000020 x16: 00000000b7b09688 x17: 0000000000000000 x18: 00000000b78f1da0 x19: 0000000000000001 x20: 00000000b78f7350 x21: 0000000064880000 x22: 0000000092000000 x23: 0000000000000000 x24: 0000000000000000 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 00000000b78f68a0 x29: 00000000b78e9eb0 Code: eb03005f 540001c1 d65f03c0 f8636824 (f8236804) Resetting CPU ... ### ERROR ### Please RESET the board ### |
1个回答
可以尝试以下步骤:
1. 确认你的 fuse_fip.bin 文件是否正确。你可以从官方网站或者其他可靠的来源重新下载一份文件,并检查其 MD5 值是否与官方提供的一致。 2. 确认你的编程命令是否正确。你需要特别注意命令中所使用的地址、偏移量等参数,确保它们与你的芯片规格相符。 3. 确认你的硬件连接是否正确。你需要确认 OTPMK 和 SRKH 等相关引脚是否正确连接到了你的处理器上,并且供电电压是否正确。 4. 如果以上步骤都无法解决问题,你可以尝试联系处理器厂家或者技术支持团队,寻求他们的帮助。 总之,正确融合 LS1028A 处理器系列需要你仔细按照官方文档和规格来进行操作,并且对硬件和软件都有一定的专业知识和经验。 |
只有小组成员才能发言,加入小组>>
1688个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
35773 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
3974 浏览 0 评论
5500 浏览 1 评论
6360 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
3848 浏览 0 评论
319浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
280浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
306浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
369浏览 2评论
379浏览 2评论
GMT+8, 2024-4-19 10:35 , Processed in 0.704189 second(s), Total 75, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
