RTStudio 2.0.0 安装PlatformIO 5.0.3.12未检测到PlatformIO可执行环境,配置环境失败,请重新安装? 按照提示重启环境后也无法解决问题。 |
6个回答
按照您的方法试过了,但还是安装不上,依旧提示拒绝访问。
看起来是 C:\\Users\\Administrator\\.platformio\\penv\\Scripts\\platformio.exe 文件在运行中,导致studio 的安装程序无法删除该文件 安装platformio 环境。
可以尝试的方法: 关闭可能调用platformio.exe 的应用,包含其他platformio 开发环境,比如vscode 手工删除C:\\Users\\Administrator\\.platformio\\penv\ 文件夹 |
感谢回答,按照您说的方式操作了一下。在下载一个文件的时候卡住了(147kb大小的文件),后来我在VSCode上能成功安装PlatformIO了。应该就是您说的问题造成的。非常感谢!
这是今天的log TRY org.eclipse.launchbar.core 2 0 2020-12-24 09:57:48.328 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2020-12-24 09:57:48.328 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.project.ui 4 0 2020-12-24 09:57:58.352 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2020-12-24 09:57:58.362 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:01:34.914 !MESSAGE The platformIO installation process is being executed, it may take more than 10 minutes, please be patient... !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:01:35.504 !MESSAGE rt_studio_version: 2.0.0 !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:01:35.724 !MESSAGE Long path support has enabled !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:01:35.734 !MESSAGE ************* Copy and install platformio packages (Step 1/2) *************** !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:01:35.734 !MESSAGE Copying packages... !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:04:06.426 !MESSAGE Copying platforms... !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:04:16.867 !MESSAGE Copying other files... !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:04:16.877 !MESSAGE Copying python environment... !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:05:49.788 !MESSAGE ************* Create platformio environment (Step 2/2) *************** !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:05:52.872 !MESSAGE Installer version: 0.3.5 !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:05:52.874 !MESSAGE Platform: Windows-10 !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:05:52.875 !MESSAGE Python version: 3.7.7 (tags/v3.7.7:d7c567b08f, Mar 10 2020, 10:41:24) [MSC v.1900 64 bit (AMD64)] !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:05:52.876 !MESSAGE Python path: C:\\Users\\Administrator\\.platformio\\.rt_studio\\python377x64\\python.exe !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:02.929 !MESSAGE Creating a virtual environment at C:\\Users\\Administrator\\.platformio\\penv !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:25.764 !MESSAGE Updating Python package manager (PIP) in a virtual environment !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:25.765 !MESSAGE C:/Users/Administrator/.platformio/.rt_studio/python377x64/lib/site-packages/pioinstaller/../../../.rt_global !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:25.766 !MESSAGE cn !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:25.767 !MESSAGE C:\\Users\\Administrator\\.platformio\\.rt_studio\\python377x64\\lib\\site-packages\\pioinstaller\\get-pip.py !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:25.768 !MESSAGE Virtual environment has been successfully created! !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:25.769 !MESSAGE Installing PlatformIO Core !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:27.292 !MESSAGE Looking in indexes !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:27.304 !MESSAGE Collecting platformio !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:28.117 !MESSAGE Downloading (213kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:41.183 !MESSAGE Collecting bottle<0.13 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:06:42.070 !MESSAGE Downloading (89kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:08.260 !MESSAGE Collecting click!=7.1,!=7.1.1,<8,>=5 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:09.432 !MESSAGE Downloading(82kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:14.589 !MESSAGE Collecting colorama (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:15.841 !MESSAGE Downloading !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:15.930 !MESSAGE Collecting pyserial!=3.3,<4,>=3 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:16.297 !MESSAGE Downloading(90kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:17.392 !MESSAGE Collecting requests<3,>=2.4.0 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:18.586 !MESSAGE Downloading (61kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:19.776 !MESSAGE Collecting semantic_version<3,>=2.8.1 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:20.421 !MESSAGE Downloadingl !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:20.517 !MESSAGE Collecting tabulate<1,>=0.8.3 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:20.855 !MESSAGE Downloading !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:22.123 !MESSAGE Collecting pyelftools<1,>=0.25 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:22.471 !MESSAGE Downloading (151kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:25.985 !MESSAGE Collecting marshmallow>=2 (from platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:28.871 !MESSAGE Downloading (46kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:33.275 !MESSAGE Collecting chardet<5,>=3.0.2 (from requests<3,>=2.4.0->platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:45.884 !MESSAGE Downloading (178kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:47.828 !MESSAGE Collecting urllib3<1.27,>=1.21.1 (from requests<3,>=2.4.0->platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:48.276 !MESSAGE Downloading (136kB) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:07:58.085 !MESSAGE Collecting certifi>=2017.4.17 (from requests<3,>=2.4.0->platformio) !ENTRY org.rt-thread.studio.common.ui 1 0 2020-12-24 10:08:20.759 !MESSAGE Downloading (147kB) !SESSION 2020-12-24 11:21:26.802 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
583 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
2207 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1227 浏览 0 评论
1776 浏览 0 评论
1462 浏览 0 评论
74794 浏览 21 评论
GMT+8, 2024-12-22 16:12 , Processed in 0.976383 second(s), Total 80, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
