目录 外部flash挂载文件系统失败,[I/SFUD] Error: Can't enable write status. Board: AT_START_F437_V1.0 MCU: AT32F437ZMT7 Flash: EN25QH128A-104HIP 原理图:
initialize rti_board_start:0 done initialize rt_hw_qspi_bus_init[D/drv.qspi] qspi1 register success :0 done initialize rt_hw_pin_init:0 done initialize rt_hw_spi_init:0 done \ | / RT - Thread Operating System / | \ 4.1.1 build Nov 3 2022 10:47:58 2006 - 2022 Copyright by RT-Thread team do components initialization. initialize rtu:865) The flash device manufacturer ID is 0x1C, memory type ID is 0x70, capacity ID is 0x18. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:131) Check SFDP header is OK. The reversion is V1.0, NPN is 0. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:173) Check JEDEC basic flash parameter header is OK. The table id is 0, reversion is V1.0, length is 9, parameter table pointer is 0x000030. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:203) JEDEC basic flash parameter table info: [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:204) MSB-LSB 3 2 1 0 [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0001] 0xFF 0xB1 0x20 0xED [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0002] 0x07 0xFF 0xFF 0xFF [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0003] 0x6B 0x00 0xEB 0x5F [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0004] 0xBB 0x04 0x3B 0x08 [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0005] 0xFF 0xFF 0xFF 0xFE [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0006] 0xFF 0x00 0xFF 0xFF [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0007] 0xEB 0x5F 0xFF 0xFF [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0008] 0x52 0x0F 0x20 0x0C [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0009] 0xFF 0x00 0xD8 0x10 [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:215) 4 KB Erase is supported throughout the device. Command is 0x20. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:234) Write granularity is 64 bytes or larger. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:250) Block Protect bits in device's status register are solely volatile. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:255) Flash device requires instruction 50h as the write enable prior to performing a volatile write to the status register. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:271) 3-Byte only addressing. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:305) Capacity is 16777216 Bytes. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:311) Flash device supports 4KB block erase. Command is 0x20. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:311) Flash device supports 32KB block erase. Command is 0x52. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:311) Flash device supports 64KB block erase. Command is 0xD8. [I/SFUD] Find a EON flash chip. Size is 16777216 bytes. [D/SFUD] (/mnt/d/repo/rt-thread/components/drivers/spi/sfud/src/sfud.c:844) Flash device reset success. [I/SFUD] en25qh128 flash device is initialize success. flash already enter qspi mode [I/SFUD] Probe SPI flash en25qh128 by SPI device qspi10 success. flash sfud success :0 done initialize elm_init:0 done initialize finsh_system_init:0 done [390 main] HZ 288000000 [390 mnt_init] mkfs elm [W/time] Cannot find a RTC device! [I/SFUD] Error: Can't enable write status. format error, result=1 [410 mnt_init] mount en25qh128 dfs mount failed msh /> |
1个回答
检查flash的WP引脚
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1033 浏览 0 评论
2877 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9386 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2898 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2302 浏览 1 评论
/9
GMT+8, 2025-12-2 09:33 , Processed in 2.424664 second(s), Total 75, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
664
