电子发烧友论坛|
在大多数情况下,我无法让 LPSPI 在 RT1024 上正常工作。
更新:问题是由于下面解释的令人讨厌的 LPSPI 驱动程序错误造成的。 最好的问候,戴夫 [size=\"5\"]背景 LPSPI 总线上有 4 个不同的传感器 4。尝试通过从每个传感器读取芯片 ID 来验证操作。 一个传感器 (ND120) 我可以正确读取,因此引脚配置、时钟、硬件似乎都可以。 我只能使用“连续模式”操作其他 3 个传感器,这在这种情况下不是我需要的。 [size=\"5\"]代码 这是操作 AOK 的 ND120 代码: typedef struct { // normal read is just 32-bit pressure and temperature int16_t pressure; int16_t temperature; // extended data read (beyond 4 bytes/32 bits) should get the following: char model[8]; uint32_t serialNumber; char softwareVersion[6]; char fill[2]; // because LPSPI API requires multiple of 4 bytes; don\'t know why... } ND120_output_T; typedef struct { uint8_t mode; uint8_t rate; // ToDo: ND120: ND120_control_T ctor to assemble fields of mode and rate } ND120_control_T; void test_ND120() { lpspi_master_config_t ND120_LPSPI_MasterConfig = { .baudRate = 150000U, /*!< Baud Rate for LPSPI. 6uS cycle = 166,666Hz */ .bitsPerFrame = 8 * sizeof(ND120_output_T),/*!< Bits per frame, minimum 8, maximum 4096.*/ // Clock SPI mode \'00\' (CPOL = CPHA = 0) .cpol = kLPSPI_ClockPolarityActiveLow,/*!< Clock polarity. */ .cpha = kLPSPI_ClockPhaseSecondEdge, /*!< Clock phase. */ .direction = kLPSPI_MsbFirst,/*!< MSB or LSB data shift direction. */ .pcsToSckDelayInNanoSec = 110000,/*!< PCS to SCK delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range. spec: 100us */ .lastSckToPcsDelayInNanoSec = 20000, /*!< Last SCK to PCS delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range. spec: 20us */ .betweenTransferDelayInNanoSec = 0, /*!< After the SCK delay time with nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range.*/ .whichPcs = kLPSPI_Pcs0, /*!< Desired Peripheral Chip Select (PCS) - over-ridden in transfer API */ .pcsActiveHighOrLow = kLPSPI_PcsActiveLow, /*!< Desired PCS active high or low */ .pinCfg = kLPSPI_SdiInSdoOut,/*!< Configures which pins are used for input and output data during single bit transfers.*/ .dataOutConfig = kLpspiDataOutRetained, /*!< Configures if the output data is tristated * between accesses (LPSPI_PCS is negated). */ /*guess*/.enableInputDelay = false, /*!< Enable master to sample the input data on a delayed SCK. This can help improve slave setup time. Refer to device data sheet for specific time length. */ }; LPSPI_MasterInit(LPSPI4, &ND120_LPSPI_MasterConfig, BOARD_BOOTCLOCKRUN_LPSPI_CLK_ROOT); // enables clock and LPSI module ND120_control_T ctrl = { .mode = 0, .rate = 0, }; ND120_output_T result; memset(&result,0,sizeof(result)); lpspi_transfer_t t1 = { .txData = (uint8_t*)&ctrl, /*!< Send buffer. */ .rxData = (uint8_t*)&result, /*!< Receive buffer. */ .dataSize = sizeof(result), /*!< Transfer bytes. */ /*!< Transfer transfer configuration flags. Set from _lpspi_transfer_config_flag_for_master if the transfer is used for master or _lpspi_transfer_config_flag_for_slave enumeration if the transfer is used for slave.*/ .configFlags = kLPSPI_MasterPcs0 /*| kLPSPI_MasterPcsContinuous */, }; // Reset ND120 GPIO_PinWrite(BOARD_INITPINS_ND120_RESET_GPIO, BOARD_INITPINS_ND120_RESET_PIN, 0); vTaskDelay(pdMS_TO_TICKS(10)); GPIO_PinWrite(BOARD_INITPINS_ND120_RESET_GPIO, BOARD_INITPINS_ND120_RESET_PIN, 1); vTaskDelay(pdMS_TO_TICKS(100)); // wait for reset to actually complete // ND120 Returns: // {pressure = 5988, temperature = 1, model = \"21DN\\0\\0\\00\", serialNumber = 1163278597, softwareVersion = \"7410\\0\", fill = \"\\0A\"} status_t s1 = LPSPI_MasterTransferBlocking(LPSPI4, &t1); assert(s1 == kStatus_Success); (void)s1; bool connected = memcmp(result.model,\"21DN\",5)==0; assert(connected); (void)connected; // Can we do it twice? status_t s2 = LPSPI_MasterTransferBlocking(LPSPI4, &t1); assert(s2 == kStatus_Success); (void)s2; bool connected2 = memcmp(result.model,\"21DN\",5)==0; assert(connected2); (void)connected2; } 使用“连续模式”,我可以从 3 个 BMP581 传感器读取设备 ID: void test_bmp581() { // first try, using \'continuous CS\', works before or after ND120 test uint8_t t1_ReadChipID[2] = { 0x80 /* read operation */ | /* register */ BMP5_REG_CHIP_ID, 0 // dummy, time for data reply }; uint8_t t1_result[sizeof(t1_ReadChipID)] = {55,66}; lpspi_master_config_t masterConfig = { .baudRate = 10000000U, /*!< Baud Rate for LPSPI. 10MHz (12.5MHz spec) */ .bitsPerFrame = 8, /*!< Bits per frame, minimum 8, maximum 4096.*/ // Clock SPI mode \'11\' (CPOL = CPHA = 1) .cpol = kLPSPI_ClockPolarityActiveLow, /*!< Clock polarity. */ .cpha = kLPSPI_ClockPhaseSecondEdge, /*!< Clock phase. */ .direction = kLPSPI_MsbFirst,/*!< MSB or LSB data shift direction. */ /*guess*/.pcsToSckDelayInNanoSec = 50,/*!< PCS to SCK delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range. ToDo: T_setup_csb MISSING FROM SPECIFICATION. */ .lastSckToPcsDelayInNanoSec = 50, /*!< Last SCK to PCS delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range. T_hold_csb = 40ns spec.*/ .betweenTransferDelayInNanoSec = 0, /*!< After the SCK delay time with nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range.*/ .whichPcs = kLPSPI_Pcs1, /*!< Desired Peripheral Chip Select (PCS) - over-ridden in transfer API */ .pcsActiveHighOrLow = kLPSPI_PcsActiveLow, /*!< Desired PCS active high or low */ .pinCfg = kLPSPI_SdiInSdoOut,/*!< Configures which pins are used for input and output data during single bit transfers.*/ .dataOutConfig = kLpspiDataOutRetained, /*!< Configures if the output data is tristated * between accesses (LPSPI_PCS is negated). */ /*guess*/.enableInputDelay = false, /*!< Enable master to sample the input data on a delayed SCK. This can help improve slave setup time. Refer to device data sheet for specific time length. */ }; LPSPI_MasterInit(LPSPI4, &masterConfig, BOARD_BOOTCLOCKRUN_LPSPI_CLK_ROOT); // enables clock and LPSI module lpspi_transfer_t t1 = { .txData = &t1_ReadChipID[0], /*!< Send buffer. */ .rxData = &t1_result[0], /*!< Receive buffer. */ .dataSize = sizeof(t1_result), /*!< Transfer bytes. */ /*!< Transfer transfer configuration flags. Set from _lpspi_transfer_config_flag_for_master if the transfer is used for master or _lpspi_transfer_config_flag_for_slave enumeration if the transfer is used for slave.*/ .configFlags = kLPSPI_MasterPcs1 /* Overridden below anyway: | kLPSPI_MasterPcsContinuous */ , }; // trying to read multiple devices fails, probably because we\'ve got CS confusion from \'continuous\' mode // =================== PCS #1 ======================= t1.configFlags = kLPSPI_MasterPcs1 | kLPSPI_MasterPcsContinuous ; status_t s1 = LPSPI_MasterTransferBlocking(LPSPI4, &t1); assert(s1 == kStatus_Success); printf(\"BMP581-1 id (should be x50): x%x\\n\", t1_result[1]); assert(t1_result[1] == 0x50); } 如果我尝试不使用连续模式(这是这里需要的),我会得到空白结果: void test_bmp581() { uint8_t t1_ReadChipID[2] = { 0x80 /* read operation */ | /* register */ BMP5_REG_CHIP_ID, 0 // dummy, time for data reply }; uint8_t t1_result[sizeof(t1_ReadChipID)] = {55,66}; lpspi_master_config_t masterConfig = { .baudRate = 10000000U, /*!< Baud Rate for LPSPI. 10MHz (12.5MHz spec) */ .bitsPerFrame = 8 * sizeof(t1_result), /*!< Bits per frame, minimum 8, maximum 4096.*/ // Clock SPI mode \'11\' (CPOL = CPHA = 1) .cpol = kLPSPI_ClockPolarityActiveLow, /*!< Clock polarity. */ .cpha = kLPSPI_ClockPhaseSecondEdge, /*!< Clock phase. */ .direction = kLPSPI_MsbFirst,/*!< MSB or LSB data shift direction. */ /*guess*/.pcsToSckDelayInNanoSec = 50, /*!< PCS to SCK delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range. ToDo: T_setup_csb MISSING FROM BOSCH SPECIFICATION. */ .lastSckToPcsDelayInNanoSec = 50, /*!< Last SCK to PCS delay time in nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range. T_hold_csb = 40ns spec.*/ .betweenTransferDelayInNanoSec = 0, /*!< After the SCK delay time with nanoseconds, setting to 0 sets the minimum delay. It sets the boundary value if out of range.*/ .whichPcs = kLPSPI_Pcs1, /*!< Desired Peripheral Chip Select (PCS) - over-ridden in transfer API */ .pcsActiveHighOrLow = kLPSPI_PcsActiveLow, /*!< Desired PCS active high or low */ .pinCfg = kLPSPI_SdiInSdoOut,/*!< Configures which pins are used for input and output data during single bit transfers.*/ .dataOutConfig = kLpspiDataOutRetained, /*!< Configures if the output data is tristated * between accesses (LPSPI_PCS is negated). */ /*guess*/.enableInputDelay = false, /*!< Enable master to sample the input data on a delayed SCK. This can help improve slave setup time. Refer to device data sheet for specific time length. */ }; LPSPI_MasterInit(LPSPI4, &masterConfig, BOARD_BOOTCLOCKRUN_LPSPI_CLK_ROOT); // enables clock and LPSI module lpspi_transfer_t t1 = { .txData = &t1_ReadChipID[0], /*!< Send buffer. */ .rxData = &t1_result[0], /*!< Receive buffer. */ .dataSize = sizeof(t1_result), /*!< Transfer bytes. */ /*!< Transfer transfer configuration flags. Set from _lpspi_transfer_config_flag_for_master if the transfer is used for master or _lpspi_transfer_config_flag_for_slave enumeration if the transfer is used for slave.*/ .configFlags = kLPSPI_MasterPcs1 /* Overridden below anyway: | kLPSPI_MasterPcsContinuous */ , }; // ToDo: BMP581: Bug: reads 0x00 0x00 // =================== PCS #1 ======================= t1.configFlags = kLPSPI_MasterPcs1 /*| kLPSPI_MasterPcsContinuous */; status_t s1 = LPSPI_MasterTransferBlocking(LPSPI4, &t1); assert(s1 == kStatus_Success); assert(t1_result[1] == 0x50); // <<< Fails here } |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1208浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-2 06:37 , Processed in 0.666246 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
395
