大家好,这里是 LUA 菜鸟。
我已经为 SHT-11 编写了一个模块,请随意使用它并对其发表评论。 附件是有关如何使用它的模块和示例脚本。 干杯! SHT-11模块: 代码:全选local moduleName = ... local M = {} _G[moduleName] = M --table module local table = table --bit module local bit = bit --timer module local tmr = tmr --gpio module local gpio = gpio -- local environoment setfenv(1, M) local function set_sck(v) if (v == 1) then gpio.write(sck, gpio.HIGH) else gpio.write(sck, gpio.LOW) end end local function set_data(v) if (v == 1) then gpio.mode(data, gpio.INPUT) else gpio.write(data, gpio.LOW) gpio.mode(data, gpio.OUTPUT) end end local function start() set_data(1) set_sck(0) tmr.delay(1) set_sck(1) tmr.delay(1) set_data(0) tmr.delay(1) set_sck(0) tmr.delay(1) set_sck(1) tmr.delay(1) set_data(1) tmr.delay(1) set_sck(0) end local function reset() set_data(1) set_sck(0) for i = 0, 8 do set_sck(1) tmr.delay(1) set_sck(0) tmr.delay(1) end start() end local function write(v) local c = v local ret for i = 0, 7 do if (bit.band(c, 0x80) ~= 0) then set_data(1) else set_data(0) end c = bit.lshift(c, 1) set_sck(1) tmr.delay(1) set_sck(0) tmr.delay(1) end set_data(1) set_sck(1) tmr.delay(1) ret = gpio.read(data) set_sck(0) return ret end local function read(ack) local c = 0 set_data(1) for i = 0, 7 do c = bit.lshift(c, 1) set_sck(1) tmr.delay(1) c = bit.bor(c, gpio.read(data)) set_sck(0) tmr.delay(1) end if (ack == 1) then set_data(0) end set_sck(1) tmr.delay(1) set_sck(0) set_data(1) return c end function M.init(s, d) sck = s data = d gpio.mode(data, gpio.INPUT); gpio.mode(sck, gpio.OUTPUT); end function M.read_measurements() reset() start() --TODO: add ACK check write(0x03) set_data(1) --TODO: add timeout for i = 0, 65536 do if (gpio.read(data) == 0) then break end end t0 = read(1) t1 = read(1) --TODO: add crc checking t_crc = read(0) t = bit.lshift(t0, 8); t = bit.bor(t, t1) --t = t - 4010 --for 5V t = t - 3970 --for 3.5V start() write(0x05) set_data(1) --TODO: add timeout for i = 0, 65536 do if (gpio.read(data) == 0) then break end end h0 = read(1) h1 = read(1) --TODO: add crc checking h_crc = read(0) h = bit.lshift(h0, 8); h = bit.bor(h, h1) --compensation magic part 1 rh = 268 * h rh = rh / 256 rh = -rh rh = rh + 24052 rh = rh * h rh = rh - 1341391 rh = rh / 65536 --compensation magic part 2 rh_true = 52 * h rh_true = 6554 + rh_true rh_true = rh_true * (t - 2500) / 100 rh_true = rh_true / 65536 rh_true = rh_true + rh return t, rh_true end return M 使用示例: 代码:全选sht = require("sht11") --clock on GPIO4, data on GPIO12 sht.init(2, 6) t, h = sht.read_measurements() print("Temp: " .. t / 100 .. "." .. t % 100) print("Hum: " .. h / 10 .. "." .. h % 10 .. " %") |
只有小组成员才能发言,加入小组>>
478浏览 6评论
400浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
380浏览 5评论
385浏览 4评论
361浏览 4评论
GMT+8, 2024-10-2 19:34 , Processed in 0.779192 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
