电子发烧友论坛|
init.lua
wifi.setmode(wifi.STAtiON) wifi.sta.config("SSID","password") 打印(wifi.sta.getip()) tmr.alarm(0, 60000, 1, function() dofile( "speak.lua") end ) speak.lua conn=net.createConnection(net.TCP, 0) conn:on("receive", function(conn, payload) print(payload) end) conn:connect(80,' 184.106.153.149') conn:send("GET /update?key=yourKEY&field1=16 HTTP/1.1\r\n") conn:send("Host: api.thingspeak.com\r\n") conn:send( "接受:*/*\r\n") conn:send("User-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n") conn: send("\r\n" ) 从 BS18B20 发送温度到 thingspeak.com speak.lua pin = 9 ow.setup(pin) count = 0 repeat count = count + 1 addr = ow.reset_search(pin) addr = ow.search(pin) tmr.wdclr() until((addr ~= nil) or (count > 100)) if (addr == nil) then print("No more addresses.") else print(addr:byte(1,8)) crc = ow.crc8( string.sub(addr,1,7)) if (crc == addr:byte(8)) then if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28))然后 print("Device is a DS18S20 family device.") --repeat ow.reset(pin) ow.select(pin, addr) ow.write(pin, 0x44, 1) tmr.delay(1000000) present = ow.reset(pin) ow.select(pin, addr) ow.write(pin,0xBE,1) print("P=".. present) data = nil data = string.char(ow.read(pin)) for i = 1, 8 do data = data .. string.char(ow.read(pin)) end print(data:byte(1, 9)) crc = ow.crc8(string.sub(data,1,8)) print("CRC="..crc) if (crc == data:byte(9)) then t = (data:byte( 1) + 数据:字节 (2) * 256) * 625 t1 = t / 1000 t2 = t % 1000 print("Temperature= "..t1..""..t2.." Centigrade") end tmr.wdclr() --until false else print("设备系列未被识别。") end else print(" CRC 无效!”) end end conn=net.createConnection(net.TCP, 0) conn:on("receive", function(conn, payload) print(payload) end) conn:connect(80,'184.106. 153.149') conn:send("GET /update?key=Yourey&field1="..t1..""..t2.." HTTP/1.1\r\n") conn:send("Host: api.thingspeak .com\r\n") conn:send("接受: */*\r\n") conn:send("User-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n") 连接:发送(“\r\n”) |
只有小组成员才能发言,加入小组>>
448 浏览 0 评论
971 浏览 0 评论
1695 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1349 浏览 1 评论
1246 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1270浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
936浏览 3评论
2368浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2555浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1064浏览 2评论
/9
GMT+8, 2025-12-8 14:08 , Processed in 0.698399 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3320
