环境
soc: s32g399ardb3 网络设备: aux0sl (pfeslave) 现象描述 我从嵌入式 Linux ssh PC(ubuntu)。但是认证之后,无法启动shell。 通过 `tcpdump` 日志,我发现 tcp 数据 pkgs(包括 ack pkgs)在验证后无法发送到 PC。 但是在认证之前,数据pkgs可以从s32g发送到PC,反之亦然。 日志 网络设备信息 # after boot kernel, aux0sl isn't up, i have to up it manually root@s32g399ardb3:~# ifconfig aux0sl 192.168.123.120 root@s32g399ardb3:~# ifconfig aux0sl: flags=4163 mtu 1500 inet 192.168.123.120 netmask 255.255.255.0 broadcast 192.168.123.255 inet6 fe80::204:9fff:febe:ff80 prefixlen 64 scopeid 0x20 ether 00:04:9f:be:ff:80 txqueuelen 1000 (Ethernet) RX packets 7811 bytes 524882 (512.5 KiB) RX errors 0 dropped 7376 overruns 0 frame 0 TX packets 19 bytes 1532 (1.4 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device memory 0x46000000-46ffffff ssh 日志 root@s32g399ardb3:~# ssh -v cg@192.168.123.111 OpenSSH_8.3p1, OpenSSL 1.1.1k 25 Mar 2021 debug1: Reading configuration data /etc/ssh/ssh_config debug1: /etc/ssh/ssh_config line 20: Applying options for * debug1: Authenticator provider $SSH_SK_PROVIDER did not resolve; disabling debug1: Connecting to 192.168.123.111 [192.168.123.111] port 22. debug1: Connection established. ... ... ... debug1: Local version string SSH-2.0-OpenSSH_8.3 debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6p1 Ubuntu-4ubuntu0.7 debug1: match: OpenSSH_7.6p1 Ubuntu-4ubuntu0.7 pat OpenSSH_7.0*,OpenSSH_7.1*,OpenSSH_7.2*,OpenSSH_7.3*,OpenSSH_7.4*,OpenSSH_7.5*,OpenSSH_7.6*,OpenSSH_7.7* compat 0x04000002 debug1: Authenticating to 192.168.123.111:22 as 'cg' debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received ... ... ... debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: ecdsa-sha2-nistp256 SHA256:EZwQIrHaRi521tPos2AwwtISifFnRSWkJUMaa4fMxUU debug1: Host '192.168.123.111' is known and matches the ECDSA host key. debug1: Found key in /home/root/.ssh/known_hosts:2 debug1: rekey out after 134217728 blocks debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug1: SSH2_MSG_NEWKEYS received debug1: rekey in after 134217728 blocks ... ... ... debug1: SSH2_MSG_EXT_INFO received debug1: kex_input_ext_info: server-sig-algs= debug1: SSH2_MSG_SERVICE_ACCEPT received debug1: Authentications that can continue: publickey,password debug1: Next authentication method: publickey ... ... ... debug1: Next authentication method: password cg@192.168.123.111's password: debug1: Authentication succeeded (password). Authenticated to 192.168.123.111 ([192.168.123.111]:22). debug1: channel 0: new [client-session] debug1: Requesting no-more-sessions@openssh.com debug1: Entering interactive session. debug1: pledge: exec debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0 debug1: X11 forwarding requested but DISPLAY not set tcpdump 日志 root@s32g399ardb3:~# tcpdump -i aux0sl -n host 192.168.123.111 & root@s32g399ardb3:~# ssh cg@192.168.123.111 17:26:35.072053 ARP, Request who-has 192.168.123.111 tell 192.168.123.1, length 46 17:26:39.961413 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [S], seq 326276919, win 64240, options [mss 1460,sackOK,TS val 3645630678 ecr 0,nop,wscale 7], length 0 17:26:39.962103 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [S.], seq 1923967336, ack 326276920, win 65160, options [mss 1460,sackOK,TS val 3682564497 ecr 3645630678,nop,wscale 7], length 0 17:26:39.962180 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 1, win 502, options [nop,nop,TS val 3645630679 ecr 3682564497], length 0 17:26:39.963144 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1:22, ack 1, win 502, options [nop,nop,TS val 3645630680 ecr 3682564497], length 21 17:26:39.963537 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [.], ack 22, win 509, options [nop,nop,TS val 3682564498 ecr 3645630680], length 0 17:26:39.965709 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 1:42, ack 22, win 509, options [nop,nop,TS val 3682564500 ecr 3645630680], length 41 17:26:39.965731 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 42, win 502, options [nop,nop,TS val 3645630682 ecr 3682564500], length 0 17:26:39.966446 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 42:1122, ack 22, win 509, options [nop,nop,TS val 3682564501 ecr 3645630682], length 1080 17:26:39.966465 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 1122, win 501, options [nop,nop,TS val 3645630683 ecr 3682564501], length 0 17:26:39.967380 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], seq 22:1470, ack 1122, win 501, options [nop,nop,TS val 3645630684 ecr 3682564501], length 1448 17:26:39.967398 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1470:1534, ack 1122, win 501, options [nop,nop,TS val 3645630684 ecr 3682564501], length 64 17:26:39.968045 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [.], ack 1534, win 499, options [nop,nop,TS val 3682564503 ecr 3645630684], length 0 17:26:39.983024 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1534:1582, ack 1122, win 501, options [nop,nop,TS val 3645630700 ecr 3682564503], length 48 17:26:39.983527 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [.], ack 1582, win 501, options [nop,nop,TS val 3682564518 ecr 3645630700], length 0 17:26:39.986271 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 1122:1574, ack 1582, win 501, options [nop,nop,TS val 3682564521 ecr 3645630700], length 452 17:26:39.986288 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 1574, win 501, options [nop,nop,TS val 3645630703 ecr 3682564521], length 0 17:26:40.003957 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1582:1598, ack 1574, win 501, options [nop,nop,TS val 3645630720 ecr 3682564521], length 16 17:26:40.004534 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [.], ack 1598, win 501, options [nop,nop,TS val 3682564539 ecr 3645630720], length 0 17:26:40.004556 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1598:1642, ack 1574, win 501, options [nop,nop,TS val 3645630721 ecr 3682564539], length 44 17:26:40.004886 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [.], ack 1642, win 501, options [nop,nop,TS val 3682564540 ecr 3645630721], length 0 17:26:40.004977 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 1574:1618, ack 1642, win 501, options [nop,nop,TS val 3682564540 ecr 3645630721], length 44 17:26:40.004994 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 1618, win 501, options [nop,nop,TS val 3645630722 ecr 3682564540], length 0 17:26:40.005062 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1642:1702, ack 1618, win 501, options [nop,nop,TS val 3645630722 ecr 3682564540], length 60 17:26:40.005346 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [.], ack 1702, win 501, options [nop,nop,TS val 3682564540 ecr 3645630722], length 0 17:26:40.005712 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 1618:1670, ack 1702, win 501, options [nop,nop,TS val 3682564540 ecr 3645630722], length 52 17:26:40.052963 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 1670, win 501, options [nop,nop,TS val 3645630770 ecr 3682564540], length 0 cg@192.168.123.111's password: 17:26:42.785073 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1786:1870, ack 1722, win 501, options [nop,nop,TS val 3645633502 ecr 3682564888], length 84 17:26:42.788922 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 1722:1750, ack 1870, win 501, options [nop,nop,TS val 3682567322 ecr 3645633502], length 28 17:26:42.788944 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 1750, win 501, options [nop,nop,TS val 3645633505 ecr 3682567322], length 0 17:26:42.837026 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1870:1982, ack 1750, win 501, options [nop,nop,TS val 3645633554 ecr 3682567322], length 112 17:26:42.871872 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 1750:2250, ack 1982, win 501, options [nop,nop,TS val 3682567405 ecr 3645633554], length 500 17:26:42.871893 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 2250, win 501, options [nop,nop,TS val 3645633588 ecr 3682567405], length 0 17:26:42.872232 IP 192.168.123.111.22 > 192.168.123.120.34874: Flags [P.], seq 2250:2294, ack 1982, win 501, options [nop,nop,TS val 3682567405 ecr 3645633588], length 44 # after here, data pkgs can't be sent out 17:26:42.872251 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [.], ack 2294, win 501, options [nop,nop,TS val 3645633589 ecr 3682567405], length 0 17:26:42.872403 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1982:2358, ack 2294, win 501, options [nop,nop,TS val 3645633589 ecr 3682567405], length 376 17:26:43.080966 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1982:2358, ack 2294, win 501, options [nop,nop,TS val 3645633798 ecr 3682567405], length 376 17:26:43.292969 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1982:2358, ack 2294, win 501, options [nop,nop,TS val 3645634010 ecr 3682567405], length 376 17:26:43.720966 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1982:2358, ack 2294, win 501, options [nop,nop,TS val 3645634438 ecr 3682567405], length 376 17:26:44.584990 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1982:2358, ack 2294, win 501, options [nop,nop,TS val 3645635302 ecr 3682567405], length 376 17:26:46.276975 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1982:2358, ack 2294, win 501, options [nop,nop,TS val 3645636994 ecr 3682567405], length 376 17:26:47.071840 ARP, Request who-has 192.168.123.111 tell 192.168.123.1, length 46 17:26:49.672970 IP 192.168.123.120.34874 > 192.168.123.111.22: Flags [P.], seq 1982:2358, ack 2294, win 501, options [nop,nop,TS val 3645640390 ecr 3682567405], length 376 成功日志 我厌倦了使用 eth0(gmac) 而不是 aux0sl(pfeslave),它可以成功地通过 ssh PC。 造成这两种情况不同的原因是什么? root@s32g399ardb3:~# ssh -v OpenSSH_8.3p1, OpenSSL 1.1.1k 25 Mar 2021 debug1: Reading configuration data /etc/ssh/ssh_config debug1: /etc/ssh/ssh_config line 20: Applying options for * debug1: Authenticator provider $SSH_SK_PROVIDER did not resolve; disabling debug1: Connecting to 192.168.123.111 [192.168.123.111] port 22. debug1: Connection established. debug1: identity file /home/root/.ssh/id_rsa type -1 debug1: identity file /home/root/.ssh/id_rsa-cert type -1 debug1: identity file /home/root/.ssh/id_dsa type -1 debug1: identity file /home/root/.ssh/id_dsa-cert type -1 debug1: identity file /home/root/.ssh/id_ecdsa type -1 debug1: identity file /home/root/.ssh/id_ecdsa-cert type -1 debug1: identity file /home/root/.ssh/id_ecdsa_sk type -1 debug1: identity file /home/root/.ssh/id_ecdsa_sk-cert type -1 debug1: identity file /home/root/.ssh/id_ed25519 type -1 debug1: identity file /home/root/.ssh/id_ed25519-cert type -1 debug1: identity file /home/root/.ssh/id_ed25519_sk type -1 debug1: identity file /home/root/.ssh/id_ed25519_sk-cert type -1 debug1: identity file /home/root/.ssh/id_xmss type -1 debug1: identity file /home/root/.ssh/id_xmss-cert type -1 debug1: Local version string SSH-2.0-OpenSSH_8.3 debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6p1 Ubuntu-4ubuntu0.7 debug1: match: OpenSSH_7.6p1 Ubuntu-4ubuntu0.7 pat OpenSSH_7.0*,OpenSSH_7.1*,OpenSSH_7.2*,OpenSSH_7.3*,OpenSSH_7.4*,OpenSSH_7.5*,OpenSSH_7.6*,OpenSSH_7.7* compat 0x04000002 debug1: Authenticating to 192.168.123.111:22 as 'cg' debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received debug1: kex: algorithm: curve25519-sha256 debug1: kex: host key algorithm: ecdsa-sha2-nistp256 debug1: kex: server->client cipher: MAC: compression: none debug1: kex: client->server cipher: MAC: compression: none debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: ecdsa-sha2-nistp256 SHA256:EZwQIrHaRi521tPos2AwwtISifFnRSWkJUMaa4fMxUU debug1: Host '192.168.123.111' is known and matches the ECDSA host key. debug1: Found key in /home/root/.ssh/known_hosts:2 debug1: rekey out after 134217728 blocks debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug1: SSH2_MSG_NEWKEYS received debug1: rekey in after 134217728 blocks debug1: Will attempt key: /home/root/.ssh/id_rsa debug1: Will attempt key: /home/root/.ssh/id_dsa debug1: Will attempt key: /home/root/.ssh/id_ecdsa debug1: Will attempt key: /home/root/.ssh/id_ecdsa_sk debug1: Will attempt key: /home/root/.ssh/id_ed25519 debug1: Will attempt key: /home/root/.ssh/id_ed25519_sk debug1: Will attempt key: /home/root/.ssh/id_xmss debug1: SSH2_MSG_EXT_INFO received debug1: kex_input_ext_info: server-sig-algs= debug1: SSH2_MSG_SERVICE_ACCEPT received debug1: Authentications that can continue: publickey,password debug1: Next authentication method: publickey debug1: Trying private key: /home/root/.ssh/id_rsa debug1: Trying private key: /home/root/.ssh/id_dsa debug1: Trying private key: /home/root/.ssh/id_ecdsa debug1: Trying private key: /home/root/.ssh/id_ecdsa_sk debug1: Trying private key: /home/root/.ssh/id_ed25519 debug1: Trying private key: /home/root/.ssh/id_ed25519_sk debug1: Trying private key: /home/root/.ssh/id_xmss debug1: Next authentication method: password s password: debug1: Authentication succeeded (password). Authenticated to 192.168.123.111 ([192.168.123.111]:22). debug1: channel 0: new [client-session] debug1: Requesting debug1: Entering interactive session. debug1: pledge: exec debug1: client_input_global_request: rtypewant_reply 0 debug1: X11 forwarding requested but DISPLAY not set Welcome to Kylin V10 SP1 (GNU/Linux 5.4.0-144-generic x86_64) |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37379 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6778 浏览 1 评论
7796 浏览 1 评论
7646 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5074 浏览 0 评论
1559浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1212浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
750浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
738浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
681浏览 1评论
/9
GMT+8, 2025-12-3 15:08 , Processed in 0.684227 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
602
