我正在使用带有 LVGL 的 ESP32 项目。起点是https://github.com/espressif/esp-dev-ki ... ello_world项目。我想添加 WiFi 接入点功能,但似乎没有足够的可用内存。减小 LVGL 的缓冲区大小,或将其移至 PSRAM 可解决该问题。但这使得显示极其缓慢。我打印了 lvgl 分配的数量、可用内存和 largest_free_block 以确定是否应该有足够的可用内存。“largest free”在调用 esp_wifi_init() 之前打印出来。
我不明白为什么没有足够的可用内存... 代码:全选 allocating = 48000 bytes heap free = 2162366 largest free = 2064384 I (2245) wifi:wifi driver task: 3fffbabc, prio:23, stack:6656, core=0 I (2245) system_api: Base MAC address is not set I (2245) system_api: read default base MAC address from EFUSE I (2248) wifi:wifi firmware version: 6567a16 I (2248) wifi:wifi certification version: v7.0 I (2249) wifi:config NVS flash: enabled I (2249) wifi:config nano formating: disabled I (2249) wifi:Init data frame dynamic rx buffer num: 32 I (2249) wifi:Init management frame dynamic rx buffer num: 32 I (2249) wifi:Init management short buffer num: 32 I (2250) wifi:Init static tx buffer num: 16 I (2251) wifi:Init tx cache buffer num: 32 I (2251) wifi:Init static rx buffer size: 1600 W (2251) wifi:malloc buffer fail I (2251) wifi:Init static rx buffer num: 6 I (2251) wifi:Init dynamic rx buffer num: 32 E (2252) wifi:Expected to init 10 rx buffer, actual is 6 I (2252) wifi:Deinit lldesc rx mblock:0 I (2252) wifi:Deinit lldesc rx mblock:0 I (2253) wifi:Deinit lldesc rx mblock:0 I (2253) wifi:Deinit lldesc rx mblock:0 I (2254) wifi_init: rx ba win: 6 I (2254) wifi_init: tcpip mbox: 32 I (2254) wifi_init: udp mbox: 6 I (2254) wifi_init: tcp mbox: 6 I (2254) wifi_init: tcp tx win: 5744 I (2254) wifi_init: tcp rx win: 5744 I (2255) wifi_init: tcp mss: 1440 I (2255) wifi_init: WiFi/LWIP prefer SPIRAM I (2255) wifi_init: WiFi IRAM OP enabled I (2255) wifi_init: WiFi RX IRAM OP enabled ESP_ERROR_CHECK failed: esp_err_t 0x101 (ESP_ERR_NO_MEM) at 0x4002e4fc 0x4002e4fc: _esp_error_check_failed at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_err.c:42 file: "./components/levelz-ap/levelz-ap.cpp" line 43 func: CLevelzAp::CLevelzAp(const char*, const char*) expression: esp_wifi_init(&cfg) abort() was called at PC 0x4002e4ff on core 0 0x4002e4ff: _esp_error_check_failed at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_err.c:43 Backtrace: 0x40025b32:0x3ffd5700 0x4002e509:0x3ffd5720 0x40035ede:0x3ffd5740 0x4002e4ff:0x3ffd57b0 0x40087dbd:0x3ffd57d0 0x4008794e:0x3ffd5960 0x4011c4db:0x3ffd5980 0x40031045:0x3ffd59a0 0x40025b32: panic_abort at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/panic.c:408 0x4002e509: esp_system_abort at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_system.c:137 0x40035ede: abort at C:/Espressif/frameworks/esp-idf-v4.4.4/components/newlib/abort.c:46 0x4002e4ff: _esp_error_check_failed at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_err.c:43 0x40087dbd: CLevelzAp::CLevelzAp(char const*, char const*) at C:/Users/Luc/websites/harmonic-design/levelz-touch/components/levelz-ap/levelz-ap.cpp:43 (discriminator 1) 0x4008794e: app_main at C:/Users/Luc/websites/harmonic-design/levelz-touch/main/main.cpp:44 0x4011c4db: main_task at C:/Espressif/frameworks/esp-idf-v4.4.4/components/freertos/port/port_common.c:141 (discriminator 2) 0x40031045: vPortTaskWrapper at C:/Espressif/frameworks/esp-idf-v4.4.4/components/freertos/port/xtensa/port.c:142 ELF file SHA256: 03268c16eaf653df CPU halted. |
相关推荐 |
只有小组成员才能发言,加入小组>>
1932个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
36419 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
4831 浏览 1 评论
6103 浏览 1 评论
6815 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
4247 浏览 0 评论
642浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
639浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
640浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
727浏览 2评论
840浏览 2评论
GMT+8, 2024-12-21 15:09 , Processed in 1.250670 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
