我在使用 ESP-Prog 在自定义 PCB 上闪存 ESP32-S3-WROOM-1u 时遇到了一个奇怪的问题。当 ESP-prog 串行接头上的 TX 线连接到 ESP32 的 RX0 引脚时,串行输出停止。在 VSCODE 中使用 platformio,串行监视器在 TX0 (ESP32) -> TX (ESP-prog) 或 RX0 (ESP32) -> RX (ESP-prog) 时从 ESP32 接收以下输出:
代码:全选 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x3 (RTC_SW_SYS_RST),boot:0x9 (SPI_FAST_FLASH_BOOT) Saved PC:0x403cdc76 SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3808,len:0x1660 load:0x403c9700,len:0xbcc load:0x403cc700,len:0x2fac entry 0x403c9954 I (29) boot: ESP-IDF 4.4.4 2nd stage bootloader I (29) boot: compile time 20:42:44 I (29) boot: chip revision: v0.1 I (31) boot_comm: chip revision: 1, min. bootloader chip revision: 0 I (38) boot.esp32s3: Boot SPI Speed : 80MHz I (43) boot.esp32s3: SPI Mode : DIO I (47) boot.esp32s3: SPI Flash Size : 16MB I (52) boot: Enabling RNG early entropy source... I (58) boot: Partition Table: I (61) boot: ## Label Usage Type ST Offset Length I (68) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (76) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (83) boot: 2 factory factory app 00 00 00010000 00100000 I (91) boot: End of partition table I (95) boot_comm: chip revision: 1, min. application chip revision: 0 I (102) esp_image: segment 0: paddr=00010020 vaddr=3c060020 size=20a24h (133668) map I (135) esp_image: segment 1: paddr=00030a4c vaddr=3fc92ed0 size=02c34h ( 11316) load I (137) esp_image: segment 2: paddr=00033688 vaddr=40374000 size=0c990h ( 51600) load E (152) esp_image: invalid segment length 0xffffffff E (152) boot: Factory app partition is not bootable E (152) boot: No bootable app partitions in the partition table 在此配置中,如果启动按钮已修复并按下重置按钮,模块将检测到处于下载模式: 代码:全选 ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x3 (DOWNLOAD(USB/UART0)) waiting for download PLATFORM: Espressif 32 (6.1.0) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM) HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa) PACKAGES: - framework-espidf @ 3.50001.0 (5.0.1) - tool-cmake @ 3.16.4 - tool-esptoolpy @ 1.40500.0 (4.5.0) - tool-idf @ 1.0.1 - tool-mconf @ 1.4060000.20190628 (406.0.0) - tool-mkfatfs @ 2.0.1 - tool-mklittlefs @ 1.203.210628 (2.3) - tool-mkspiffs @ 2.230.0 (2.30) - tool-ninja @ 1.9.0 - tool-openocd-esp32 @ 2.1100.20220706 (11.0) - toolchain-esp32ulp @ 1.23500.220830 (2.35.0) - toolchain-riscv32-esp @ 11.2.0+2022r1 - toolchain-xtensa-esp32s3 @ 11.2.0+2022r1 Reading CMake configuration... LDF: Library Dependency Finder -> LDF Modes: Finder ~ chain, Compatibility ~ soft Found 0 compatible libraries Scanning dependencies... No dependencies Building in release mode Retrieving maximum program size .pio\build\esp32-s3-devkitc-1\firmware.elf Checking size .pio\build\esp32-s3-devkitc-1\firmware.elf Advanced Memory Usage is available via "PlatformIO Home > Project Inspect" RAM: [ ] 3.5% (used 11552 bytes from 327680 bytes) Flash: [== ] 19.2% (used 201345 bytes from 1048576 bytes) Configuring upload protocol... AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa CURRENT: upload_protocol = esptool Looking for upload port... Using manually specified: COM9 Uploading .pio\build\esp32-s3-devkitc-1\firmware.bin esptool.py v4.5 Serial port COM9 Connecting...................................... A fatal error occurred: Failed to connect to ESP32-S3: Download mode successfully detected, but getting no sync reply: The serial TX path seems to be down. |
只有小组成员才能发言,加入小组>>
1875个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
36222 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
4320 浏览 0 评论
5947 浏览 1 评论
6691 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
4141 浏览 0 评论
563浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
555浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
547浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
630浏览 2评论
693浏览 2评论
GMT+8, 2024-9-29 22:47 , Processed in 0.951623 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
