我们正在使用 imx8mm 和我们的定制板,加载了 Android 11。还添加了 ov5640 相机支持。
csi_mclk: csi-mclk { 兼容=“脉宽调制时钟”; #clock-cells = <0>; 时钟频率 = <20000000>; 时钟输出名称=“csi_mclk”; pwms = <&pwm4 0 50>; /* 1 / 50 纳秒 = 20 兆赫 */ }; &i2c4c { ov5640-mipi1@3c { AVDD 供应 = <®_ldo3>; DOVDD 供应 = <®_vref_1v8>; DVDD 供应 = <®_vref_3v3>; 时钟 = <&csi_mclk>; 时钟名称=“xclk”; compatible = "ovti,ov5640_mipisubdev"; csi_id = <0>; mclk = <20000000>; mipi_csi; pinctrl-名称=“默认”; pinctrl-0 = <&pinctrl_i2c4_ov5640_mipi>; powerdown-gpios = GP_OV5640_MIPI_POWER_DOWN; reg = <0x3c>; 重置-gpios = GP_OV5640_MIPI_RESET; 状态=“好的”; 港口 { ov5640_mipi1_ep:端点{ 远程端点 = <&mipi1_ov5640_ep>; }; }; }; }; &mipi_csi_1 { #address-cells = <1>; #size-cells = <0>; 状态=“好的”; 港口 { mipi1_ov5640_ep: 端点@1 { 远程端点 = <&ov5640_mipi1_ep>; 数据通道=<2>; csis-hs-settle = <13>; csis-clk-settle = <2>; csis-wclk; }; csi1_mipi_ep: 端点@2 { 远程端点 = <&csi1_ep>; }; }; }; &csi1_bridge { fsl,mipi 模式; 状态=“好的”; 港口 { csi1_ep:端点{ 远程端点 = <&csi1_mipi_ep>; }; }; }; 我们在使用 ov5640 捕获 5mp 图像时遇到问题。我们观察到在单击捕捉按钮与图像捕捉发生之间有 1 秒的延迟。因此,我们得到的框架与我们想要的不同。 10-11 11:15:08.384 2933 2933 D CAM_LcyLocProvider: No location received yet. 10-11 11:15:08.401 2933 3005 D CAM_CommandExecutor: Executing command: PictureTakerCommand{command=com.android.camera.one.v2.photo.SimpleImageCaptureCommand@1c64da7} START 10-11 11:15:08.411 2933 2933 V CAM_CameraActivity: onSessionQueued: camera_session://google.com/4c388a54-1251-4620-beed-53eaa1b909a5 10-11 11:15:08.414 2933 2933 V CAM_FilmstripView: suggesting item bounds: 640x886 10-11 11:15:08.415 2933 2933 V CAM_FilmstripView: getRecycledView, recycled=false 10-11 11:15:08.419 2933 2933 V CAM_FilmstripView: recycleView 10-11 11:15:08.421 2933 2933 I CAM_FilmstripView: [ViewItem:0] mData.renderThumbnail() 10-11 11:15:08.422 2933 2933 D CAM_FilmstripView: onFilmstripItemInserted() 10-11 11:15:08.447 415 452 I gralloc_driver: is_supported check descriptor name=ImageReader-2592x1944f100m15-2933-0, width=8388608, height=1, droid_format=BLOB, usage=CAMERA_OUTPUT|CPU_READ_OFTEN|GPU_RE 10-11 11:15:08.482 412 1813 I CameraDeviceSessionHwlImpl: PickConfigStream: previewIdx 1, callbackIdx -1, stillcapIdx 0, recordIdx -1, intent 2 10-11 11:15:08.482 412 1813 I CameraDeviceSessionHwlImpl: choose stream index 0 as config stream ---------diff-------- 10-11 11:15:08.482 412 1813 I MMAPStream: onDeviceStopLocked 10-11 11:15:08.484 412 1813 I MMAPStream: onDeviceConfigureLocked 10-11 11:15:08.484 412 1813 I MMAPStream: onDeviceConfigureLocked, Width * Height 2592 x 1944 format YUYV, fps: 30, capturemode 5 ---------------------- 10-11 11:15:08.940 412 1813 I VideoStream: postConfigure, set omit frames 2 for 2592x1944 ---------diff-------- 10-11 11:15:08.940 412 1813 I MMAPStream: onDeviceStartLocked 10-11 11:15:08.954 412 1813 I MMAPStream: onDeviceStartLocked, register buffer, phy 0x94200000, virt 0xf5733b42a000, size 10077696 10-11 11:15:08.960 412 1813 I MMAPStream: onDeviceStartLocked, register buffer, phy 0x94c00000, virt 0xf5733aa8d000, size 10077696 10-11 11:15:08.960 412 1813 I MMAPStream: onDeviceStartLocked VIDIOC_QBUF phy:0x94200000 10-11 11:15:08.960 412 1813 I MMAPStream: onDeviceStartLocked VIDIOC_QBUF phy:0x94c00000 ---------------------- 10-11 11:15:08.997 585 1298 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4 10-11 11:15:08.998 585 1011 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4 10-11 11:15:08.999 429 2714 D AF::TrackHandle: OpPlayAudio: track:63 usage:13 not muted 10-11 11:15:09.001 2933 2933 I AudioTrack: createTrack_l(0): AUDIO_OUTPUT_FLAG_FAST successful; frameCount 0 -> 20073 10-11 11:15:09.001 585 1011 I system_server: oneway function results will be dropped but finished with status OK and parcel size 8 10-11 11:15:09.004 585 1011 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4 10-11 11:15:09.005 406 1238 W audio_hw_primary: ret -32, pcm write 768 error wait error: hw 0xdec0 app 0xe4c0 avail 0x0 10-11 11:15:09.005 406 1238 W audio_hw_primary: : Broken pipe ---------diff-------- 10-11 11:15:09.147 412 2997 I MMAPStream: onFrameAcquireLocked omit frame 10-11 11:15:09.214 412 2997 I MMAPStream: onFrameAcquireLocked omit frame ---------------------- 10-11 11:15:09.348 412 2997 E CameraUtils: Error: getSizeByForamtRes format 0x21 not supported 10-11 11:15:09.349 412 2997 E JpegBuilder: Invalid GPS coordinate 10-11 11:15:09.349 412 2997 E JpegBuilder: Invalid GPS coordinate 10-11 11:15:09.349 412 2997 E CameraMetadata: Get: error reading tag 10-11 11:15:09.349 412 2997 E CameraMetadata: Get: error reading tag 10-11 11:15:09.548 412 2997 I CameraDeviceSessionHwlImpl: processJpegBuffer, dstbuf size 8388608, 10119168, jpeg_size 3550669, max jpeg size 8388608 10-11 11:15:09.553 412 412 I CameraDeviceSessionHwlImpl: PickConfigStream: previewIdx 1, callbackIdx -1, stillcapIdx 0, recordIdx -1, intent 1 10-11 11:15:09.553 412 412 I CameraDeviceSessionHwlImpl: choose stream index 1 as config stream ---------diff--------- 10-11 11:15:09.554 412 412 I MMAPStream: onDeviceStopLocked 10-11 11:15:09.560 412 412 I MMAPStream: onDeviceConfigureLocked 10-11 11:15:09.560 412 412 I MMAPStream: onDeviceConfigureLocked, Width * Height 640 x 480 format YUYV, fps: 30, capturemode 0 ----------------------- 10-11 11:15:09.561 2933 2933 V CAM_CaptureModule: AF status is state:INACTIVE ---------diff--------- 10-11 11:15:09.760 412 412 I MMAPStream: onDeviceStartLocked 10-11 11:15:09.766 412 412 I MMAPStream: onDeviceStartLocked, register buffer, phy 0x8e600000, virt 0xf5734bf70000, size 614400 10-11 11:15:09.767 412 412 I MMAPStream: onDeviceStartLocked, register buffer, phy 0x8ea00000, virt 0xf57348069000, size 614400 10-11 11:15:09.768 412 412 I MMAPStream: onDeviceStartLocked, register buffer, phy 0x8eb00000, virt 0xf57347fd3000, size 614400 10-11 11:15:09.768 412 412 I MMAPStream: onDeviceStartLocked VIDIOC_QBUF phy:0x8e600000 10-11 11:15:09.768 412 412 I MMAPStream: onDeviceStartLocked VIDIOC_QBUF phy:0x8ea00000 10-11 11:15:09.768 412 412 I MMAPStream: onDeviceStartLocked VIDIOC_QBUF phy:0x8eb00000 ----------------------- 10-11 11:15:09.807 2933 3005 D CAM_ProcessingSvcMgr: Task added. Queue size now: 1 10-11 11:15:09.810 585 1011 W ActivityManager: Unable to start service Intent { cmp=com.android.camera2/com.android.camera.processing.ProcessingService } U=0: not found 10-11 11:15:09.811 2933 3005 V CAM_ImageBackend: Received an opened image: 1/0 10-11 11:15:09.811 2933 3005 V CAM_ImageBackend: Setting an image reference count of 1 Total refs = 1 10-11 11:15:09.813 2933 3005 D CAM_CommandExecutor: Executing command: PictureTakerCommand{command=com.android.camera.one.v2.photo.SimpleImageCaptureCommand@1c64da7} END 10-11 11:15:09.838 2933 3013 V CAM_ImageBackend: Ref release. Total refs = 0 10-11 11:15:09.839 2933 3013 V CAM_ImageBackend: Ref release close. 10-11 11:15:09.839 2933 3014 E ion : ioctl c0044901 failed with code -1: Inappropriate ioctl for device 10-11 11:15:09.841 2933 3014 V CAM_ImageBackend: Release of image occurred. Good fun. Total Images Open/Closed = 1/1 10-11 11:15:09.894 2933 2933 V CAM_CaptureModule: AF status is state:PASSIVE_SCAN 10-11 11:15:09.895 2933 2933 V CAM_FocusController: Running showPassiveFocusAtCenter() 10-11 11:15:09.896 2933 2933 I CAM_FocusRingView: Computing center via preview size. 10-11 11:15:09.949 0 0 W healthd : battery l=100 v=4404 t=20.0 h=2 st=5 c=1 chg=a 10-11 11:15:10.040 2933 2952 D CompatibilityChangeReporter: Compat change id reported: 150939131; UID 10098; state: DISABLED 10-11 11:15:10.041 2933 2981 V CAM_CameraDataAdapter: updating media metadata with photos newer than id: 76 10-11 11:15:10.053 1302 2414 W SQLiteQueryBuilder: Allowing abusive custom column: LIKE 10-11 11:15:10.054 1302 2414 W SQLiteQueryBuilder: Allowing abusive custom column: AND 10-11 11:15:10.054 1302 2414 W SQLiteQueryBuilder: Allowing abusive custom column: DESC 10-11 11:15:10.066 2933 2981 W CAM_PhotoDataFact: Zero dimension in ContentResolver for /storage/emulated/0/DCIM/Camera/IMG_20221011_111508.jpg:0x0 10-11 11:15:10.069 2933 2981 D skia : --- Failed to create image decoder with message 'unimplemented' 10-11 11:15:10.090 2933 2981 W CAM_PhotoDataFact: Dimension decode failed for /storage/emulated/0/DCIM/Camera/IMG_20221011_111508.jpg 10-11 11:15:10.130 1302 2414 W SQLiteQueryBuilder: Allowing abusive custom column: AND 10-11 11:15:10.130 1302 2414 W SQLiteQueryBuilder: Allowing abusive custom column: IN 10-11 11:15:10.168 2933 3013 D StrictMode: StrictMode policy violation: android.os.strictmode.ContentUriWithoutPermissionViolation: content://media/external/images/media/77 exposed beyond app through Int? 10-11 11:15:10.168 2933 3013 D StrictMode: at android.os.StrictMode.onContentUriWithoutPermission(StrictMode.java:2149) 10-11 11:15:10.168 2933 3013 D StrictMode: at android.net.Uri.checkContentUriWithoutPermission(Uri.java:2403) 10-11 11:15:10.168 2933 3013 D StrictMode: at android.content.Intent.prepareToLeaveProcess(Intent.java:11164) 10-11 11:15:10.168 2933 3013 D StrictMode: at android.content.Intent.prepareToLeaveProcess(Intent.java:11104) 10-11 11:15:10.168 2933 3013 D StrictMode: at android.app.ContextImpl.sendBroadcast(ContextImpl.java:1114) 10-11 11:15:10.168 2933 3013 D StrictMode: at android.content.ContextWrapper.sendBroadcast(ContextWrapper.java:468) 10-11 11:15:10.168 2933 3013 D StrictMode: at com.android.camera.util.CameraUtil.broadcastNewPicture(CameraUtil.java:749) 10-11 11:15:10.168 2933 3013 D StrictMode: at com.android.camera.session.PlaceholderManager.finishPlaceholder(PlaceholderManager.java:140) 10-11 11:15:10.168 2933 3013 D StrictMode: at com.android.camera.session.CaptureSessionImpl.saveAndFinish(CaptureSessionImpl.java:322) 10-11 11:15:10.168 2933 3013 D StrictMode: at com.android.camera.processing.imagebackend.TaskCompressImageToJpeg.run(TaskCompressImageToJpeg.java:344) 10-11 11:15:10.168 2933 3013 D StrictMode: at com.android.camera.processing.imagebackend.ImageBackend$TaskDoneWrapper.run(ImageBackend.java:829) 10-11 11:15:10.168 2933 3013 D StrictMode: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167) 10-11 11:15:10.168 2933 3013 D StrictMode: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641) 10-11 11:15:10.168 2933 3013 D StrictMode: at java.lang.Thread.run(Thread.java:923) 10-11 11:15:10.168 2933 3013 D StrictMode: at com.android.camera.async.AndroidPriorityThread.run(AndroidPriorityThread.java:26) 10-11 11:15:10.181 2933 3013 D StrictMode: StrictMode policy violation: android.os.strictmode.ContentUriWithoutPermissionViolation: content://media/external/images/media/77 exposed beyond app through Int? 10-11 11:15:10.181 2933 3013 D StrictMode: at android.os.StrictMode.onContentUriWithoutPermission(StrictMode.java:2149) 10-11 11:15:10.181 2933 3013 D StrictMode: at android.net.Uri.checkContentUriWithoutPermission(Uri.java:2403) 10-11 11:15:10.181 2933 3013 D StrictMode: at android.content.Intent.prepareToLeaveProcess(Intent.java:11164) 10-11 11:15:10.181 2933 3013 D StrictMode: at android.content.Intent.prepareToLeaveProcess(Intent.java:11104) 10-11 11:15:10.181 2933 3013 D StrictMode: at android.app.ContextImpl.sendBroadcast(ContextImpl.java:1114) 10-11 11:15:10.181 2933 3013 D StrictMode: at android.content.ContextWrapper.sendBroadcast(ContextWrapper.java:468) 10-11 11:15:10.181 2933 3013 D StrictMode: at com.android.camera.util.CameraUtil.broadcastNewPicture(CameraUtil.java:751) 10-11 11:15:10.181 2933 3013 D StrictMode: at com.android.camera.session.PlaceholderManager.finishPlaceholder(PlaceholderManager.java:140) 10-11 11:15:10.181 2933 3013 D StrictMode: at com.android.camera.session.CaptureSessionImpl.saveAndFinish(CaptureSessionImpl.java:322) 10-11 11:15:10.181 2933 3013 D StrictMode: at com.android.camera.processing.imagebackend.TaskCompressImageToJpeg.run(TaskCompressImageToJpeg.java:344) 10-11 11:15:10.181 2933 3013 D StrictMode: at com.android.camera.processing.imagebackend.ImageBackend$TaskDoneWrapper.run(ImageBackend.java:829) 10-11 11:15:10.181 2933 3013 D StrictMode: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167) 10-11 11:15:10.181 2933 3013 D StrictMode: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641) 10-11 11:15:10.181 2933 3013 D StrictMode: at java.lang.Thread.run(Thread.java:923) 10-11 11:15:10.181 2933 3013 D StrictMode: at com.android.camera.async.AndroidPriorityThread.run(AndroidPriorityThread.java:26) 10-11 11:15:10.193 2933 2933 V CAM_CameraActivity: onSessionDone:camera_session://google.com/4c388a54-1251-4620-beed-53eaa1b909a5 10-11 11:15:10.200 1302 1322 W SQLiteQueryBuilder: Allowing abusive custom column: LIKE 10-11 11:15:10.200 1302 1322 W SQLiteQueryBuilder: Allowing abusive custom column: AND 10-11 11:15:10.200 1302 1322 W SQLiteQueryBuilder: Allowing abusive custom column: DESC 10-11 11:15:10.218 585 638 I DropBoxManagerService: add tag=system_app_strictmode isTagEnabled=true flags=0x2 10-11 11:15:10.231 2933 2933 I CAM_FilmstripView: [ViewItem:0] mData.renderTiny() 10-11 11:15:10.233 2933 2933 V CAM_FilmstripView: updateViewItem() - recycling old data item and setting new 10-11 11:15:10.239 2933 2933 D CAM_FilmstripView: updateViewItem(bufferIndex: 2) 10-11 11:15:10.239 2933 2933 D CAM_FilmstripView: updateViewItem() - mIsUserScrolling: false 10-11 11:15:10.240 2933 2933 D CAM_FilmstripView: updateViewItem() - mController.isScrolling() - false 10-11 11:15:10.240 2933 2933 I CAM_FilmstripView: [ViewItem:0] mData.renderThumbnail() 10-11 11:15:10.263 1302 1322 W MediaProvider: Using FUSE for /storage/emulated/0/DCIM/Camera/IMG_20221011_111508.jpg 10-11 11:15:10.266 1302 1347 W SQLiteQueryBuilder: Allowing abusive custom column: AND 10-11 11:15:10.307 1302 1347 W MediaProvider: Using FUSE for /storage/emulated/0/DCIM/Camera/IMG_20221011_111508.jpg 10-11 11:15:10.313 1302 2414 W MediaProvider: Using FUSE for /storage/emulated/0/DCIM/Camera/IMG_20221011_111508.jpg 10-11 11:15:10.326 1302 1347 W MediaProvider: Using FUSE for /storage/emulated/0/DCIM/Camera/IMG_20221011_111508.jpg 但是当我们将捕捉选项更改为 .3mp 时,这种延迟就看不到了。 这个问题的原因可能是什么? |
只有小组成员才能发言,加入小组>>
1931个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
36414 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
4782 浏览 1 评论
6099 浏览 1 评论
6807 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
4243 浏览 0 评论
641浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
637浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
639浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
725浏览 2评论
833浏览 2评论
GMT+8, 2024-12-18 14:05 , Processed in 0.934807 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
