嗨,我正在启动我们自己的董事会。
U-boot 不稳定,每次都卡在不同的地方。 这是3个卡住的日志 1.卡在DRAM INFO U-Boot 2020.04-脏(2022 年 11 月 1 日 - 18:09:02 +0900) SoC:LS1046AE Rev1.0 (0x87070010) 时钟配置: CPU0(A72):1600 MHz CPU1(A72):1600 MHz CPU2(A72):1600 MHz CPU3(A72):1600 MHz 总线:600 MHz DDR:1600 MT/s FMAN: 900 MHz Reset Configuration Word (RCW): 00000000: 0c100010 12000000 00000000 00000000 00000010: 10405577 40a00016 40000000 c1000000 00000020: 00200000 00000000 00000000 0003affc 00000030: 20004504 04201101 00000096 00000001 Model: LS1046A FRWY Board Board: LS1046AFRWY, Rev: B, boot from QSPI SD1_CLK1 = 100.00MHZ,SD1_CLK2 = 100.00MHZ DRAM:7.9 GiB(DDR4,64 位,CL=11,ECC 关闭)2.坚持“同步中止”处理程序 U-Boot 2020.04-dirty (Nov 01 2022 - 18:09:02 +0900) SoC:LS1046AE Rev1.0 (0x87070010) 时钟配置: CPU0(A72):1600 MHz CPU1(A72):1600 MHz CPU2(A72): 1600 MHz CPU3(A72):1600 MHz Bus: 600 MHz DDR: 1600 MT/s FMAN: 900 MHz Reset Configuration Word (RCW): 00000000: 0c100010 12000000 00000000 00000000 00000010: 10405577 40a00016 40000000 c1000000 00000020: 00200000 00000000 00000000 0003affc 00000030: 20004504 04201101 00000096 00000001 型号:LS1046A FRWY 电路板电路板:LS1046AFRWY,修订版:B,从 QSPI SD1_CLK1 = 100.00MHZ,SD1_CLK2 = 100.00MHZ 启动DRAM:7.9 GiB(DDR4,SERDES CL11 关闭)使用协议 1 : 4160 (0x1040) 使用 SERDES2 协议:21879 (0x5577) NAND:fsl_ifc_chip_init:地址不匹配任何芯片选择 0 MiB MMC:FSL_SDHC:0 EEPROM:读取失败。 In: serial Out: serial Err: serial Net: Invalid SerDes protocol 0x1040 for LS1046AFRWY unrecognized JEDEC id bytes: ef, 60, 18 "Synchronous Abort" handler, esr 0x96000004 elr: 000000008204a6a4 lr : 000000008204a68c (reloc) elr: 00000000fbd786a4 lr : 00000000fbd7868c x0 : f2a12001d2808001 x1 : 0000000000001070 x2 : 00000000fbdc8000 x3 : 0000000000001071 x4 : 00000000fbc2b880 x5 : 00000000fbc2bd60 x6 : 00000000fbdc83f0 x7 : 00000000fbdc8400 x8 : 00000000fbc43ad0 x9 : 0000000000000008 x10: 0000000000000010 x11: 00000000fbc26f8c x12: 0000000000001238 x13: 0000000000001174 x14: 00000000fbc26fdc x15: 0000000000000002 x16: 0000000000000000 x17: 0000000000000000 x18: 00000000fbc29dc0 x19: 00000000fbc33ad0 x20: f2a12001d2808001 x21: 0000000001a00000 x22: 0000000000000000 x23: 0000000000000000 x24: 0000000000000000 x25: 0000000000000000 x26: 0000000000000000 x27:0000000000000000 x28:0000000000000000 x29:00000000fbc27200 代码:90000200 91089c00 9400b6f5 17ffffd7 (f940settingc400) 重置 CPU ... 重置3. 卡在案例 2 的同一个地方,但使用不同的同步处理程序。 这应该被视为 DDR 设置问题吗? |
只有小组成员才能发言,加入小组>>
1906个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
36358 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
4393 浏览 0 评论
6047 浏览 1 评论
6762 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
4210 浏览 0 评论
619浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
614浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
605浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
694浏览 2评论
796浏览 2评论
GMT+8, 2024-11-21 22:54 , Processed in 1.036344 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
