我正在使用基于 imx6D 的客户板,我们希望在系统上使用 BTRFS 文件系统。
我们在 u-boot 上启用了以下 BTRFS 支持 CONFIG_FS_BTRFS=y CONFIG_CMD_BTRFS=y并在内核下面的配置中。 CONFIG_BTRFS_FS=y 但是在启动设备时,我们遇到了以下故障。您能否帮助我们了解我们在这里缺少的东西? U-Boot 2021.04-g8372631b-dirty (Nov 02 2022 - 11:13:15 +0000) CPU: i.MX6D rev1.6 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 41C Reset cause: POR Model: Freescale i.MX6 Quad SABRE Smart Device Board Board: MX6-CUSTOM DRAM: 1 GiB PMIC: PFUZE100! DEV_ID=0x10 REV_ID=0x21 MMC: FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 3 In: serial Out: serial Err: serial Net: FEC [PRIME] Normal Boot Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc3(part 0) is current device CACHE: Misaligned operation at range [4ef69818, 4ef6a818] CACHE: Misaligned operation at range [4ef69818, 4ef6a818] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef69818 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a818 CACHE: Misaligned operation at range [4ef69818, 4ef6a818] CACHE: Misaligned operation at range [4ef69818, 4ef6a818] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef69818 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a818 Scanning mmc 3:1... CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] CACHE: Misaligned operation at range [4ef694a0, 4ef6a4a0] BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] CACHE: Misaligned operation at range [4ef694f8, 4ef6a4f8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef694f8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a4f8 BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC Card did not respond to voltage select! : -110 Scanning disk mmc@2194000.blk... Disk mmc@2194000.blk not ready Card did not respond to voltage select! : -110 Scanning disk mmc@2198000.blk... Disk mmc@2198000.blk not ready Scanning disk mmc@219c000.blk... BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** Found 5 disks No EFI system partition BootOrder not defined EFI boot manager: Cannot load any image CACHE: Misaligned operation at range [4ef69550, 4ef6a550] CACHE: Misaligned operation at range [4ef69550, 4ef6a550] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef69550 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a550 CACHE: Misaligned operation at range [4ef69550, 4ef6a550] CACHE: Misaligned operation at range [4ef69550, 4ef6a550] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4ef69550 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4ef6a550 BTRFS: superblock checksum mismatch No valid Btrfs found ** Unrecognized filesystem type ** MX6 CUSTOM U-Boot > |
只有小组成员才能发言,加入小组>>
1907个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
36358 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
4395 浏览 0 评论
6050 浏览 1 评论
6763 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
4212 浏览 0 评论
619浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
614浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
606浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
694浏览 2评论
798浏览 2评论
GMT+8, 2024-11-22 17:03 , Processed in 0.953973 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
