大家好,
我使用的是 S32K1 MCU,我定义了一个输入引脚来检测信号下降沿。 pin_mux.c 剧透 (Highlight to read){ .base = PORTC, .pinPortidx = 8U, .pullConfig = PORT_INTERNAL_PULL_NOT_ENABLED, .driveSelect = PORT_HIGH_DRIVE_STRENGTH, .passiveFilter = false, .mux = PORT_MUX_AS_GPIO, .pinLock = false, .intConfig = PORT_INT_FALLING_EDGE, .clearIntFlag = false, .gpioBase = PTC, .direction = GPIO_INPUT_DIRECTION, .digitalFilter = true, .initValue = 1U, }, {.base = PORTC,.pinPortIdx = 8U,.pullConfig = PORT_INTERNAL_PULL_NOT_ENABLED,.driveSelect = PORT_HIGH_DRIVE_STRENGTH,.passiveFilter = false,.mux = PORT_MUX_AS_GPIO,.pinLock = false,.intConfig = PORT_INT_FALLING_EDGE,.clearIntFlag = false,.gpioBase = PTC,.direction = GPIO_INPUT_DIRECTION,.digitalFilter = true,.initValue = 1U,}, 剧透 (Highlight to read)const port_digital_filter_config_t PTC_filter_Paras={ .clock = PORT_DIGITAL_FILTER_LPO_CLOCK, .width = 5U, }; #define PTC_Filter_Conf ((port_digital_filter_config_t*)&PTC_filter_Paras) static inline void Set_Pin_Interrupt_Filter(void){ PINS_DRV_ConfigDigitalFilter(PORTA, PTA_Filter_Conf); PINS_DRV_ConfigDigitalFilter(PORTC, PTC_Filter_Conf); } const port_digital_filter_config_t PTC_filter_Paras={.clock = PORT_DIGITAL_FILTER_LPO_CLOCK,.width = 5U,};#define PTC_Filter_Conf ((port_digital_filter_config_t*)&PTC_filter_Paras)static inline void Set_Pin_Interrupt_Filter(void){PINS_DRV_ConfigDigitalFilter(PORTA, PTA_Filter_Conf);PINS_DRV_ConfigDigitalFilter(PORTC, PTC_Filter_Conf);} 剧透 (Highlight to read)void PORTC_IRQHandler(void){ FLT_OVP_VBUS_Handler();//Check the PTC8 interrupt enabled or not PINS_DRV_ClearPortIntFlagCmd(PORTC); } void PORTC_IRQHandler(void){FLT_OVP_VBUS_Handler();//Check the PTC8 interrupt enabled or notPINS_DRV_ClearPortIntFlagCmd(PORTC);} 我在 PORTC_IRQHandler 中添加了一个断点。 管脚和管脚过滤器初始化后,然后触发PORTC_IRQHandler(),但我用示波器 测量输入信号一直为高电平,没有下降沿退出。 同时,寄存器数据: PORTC/ISFR,0x4004B0A0,0x00000 1 00 PTC/PDIR,0x400FF090,0x00024 1 30 PTC8/PDIR 为 High 但 PORTC8/ISFR 为 High,这不是预期的动作,如何设置此引脚? |
1个回答
可以在使能中断和注册中断函数之前 先把中断标志清一下 不然好像就是会进一次中断
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37379 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6778 浏览 1 评论
7796 浏览 1 评论
7646 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5074 浏览 0 评论
1559浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1211浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
750浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
737浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
681浏览 1评论
/9
GMT+8, 2025-12-3 06:49 , Processed in 0.425780 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
506
