电子发烧友论坛|
我正在尝试增加 rpmsg lite 的缓冲区大小,因为我无法在 M 和 A 内核之间实现更高的传输速率(我需要大约 200kBytes/s,达到大约 90kBytes/s)。 imx_rpmsg.c 驱动程序, 并使用来自 SDK_2_12_1_MIMX8MM6xxxKZ 的 M4 上的 rpmsg 运行 FreeRTOS 在 Linux 端,imx_rpmsg.c 中的缓冲区值在这里: #define RPMSG_NUM_BUFS (512) #define RPMSG_BUF_SIZE (512) #define RPMSG_BUFS_SPACE (RPMSG_NUM_BUFS * RPMSG_BUF_SIZE) #define RPMSG_VRING_ALIGN (4096) #define RPMSG_RING_SIZE ((DIV_ROUND_UP(vring_size(RPMSG_NUM_BUFS / 2, RPMSG_VRING_ALIGN), PAGE_SIZE)) * PAGE_SIZE)然后我在 imx_rpmsg_tty.c 旁边: /* this needs to be less then (RPMSG_BUF_SIZE - sizeof(struct rpmsg_hdr)) */ #define RPMSG_MAX_SIZE 256在 virtio_rpmsg_bus.c 里面: /* * We're allocating buffers of 512 bytes each for communications. The * number of buffers will be computed from the number of buffers supported * by the vring, upto a maximum of 512 buffers (256 in each direction). * * Each buffer will have 16 bytes for the msg header and 496 bytes for * the payload. * * This will utilize a maximum total space of 256KB for the buffers. * * We might also want to add support for user-provided buffers in time. * This will allow bigger buffer size flexibility, and can also be used * to achieve zero-copy messaging. * * Note that these numbers are purely a decision of this driver - we * can change this without changing anything in the firmware of the remote * processor. */ #define MAX_RPMSG_NUM_BUFS (512) #define MAX_RPMSG_BUF_SIZE (512)在 M4 端,有 rpmsg_config.h : //! @def RL_BUFFER_PAYLOAD_SIZE //! //! Size of the buffer payload, it must be equal to (240, 496, 1008, ...) //! [2^n - 16]. Ensure the same value is defined on both sides of rpmsg //! communication. The default value is 496U. #define RL_BUFFER_PAYLOAD_SIZE (496U) //! @def RL_BUFFER_COUNT //! //! Number of the buffers, it must be power of two (2, 4, ...). //! The default value is 2U. //! Note this value defines the buffer count for one direction of the rpmsg //! communication only, i.e. if the default value of 2 is used //! in rpmsg_config.h files for the master and the remote side, 4 buffers //! in total are created in the shared memory. #define RL_BUFFER_COUNT (256) 我发现命名系统令人困惑,因为缓冲区计数有时指整个环形缓冲区,有时指一半(tx 或 rx 一半)。由于我为设备树中的环形缓冲区分配了 128kb 的内存,如果我将缓冲区大小加倍,我也会将缓冲区计数分成两半(512x512 到 1024x256 等)。 我的第一个测试显示:更改 linux 端没有任何作用,M4 仍然收到 496 字节的 hello world 消息。一旦我更改了 M4 端的 rpmsg_config.h,即使只是将缓冲区数量减半至 128,也不再收到 hello world 消息并且驱动程序无法正常工作。 我发现了许多类似的主题,但它们似乎都没有解决,或者使用的是旧版本的 rpmsg,因此无法直接应用解决方案。此线程中报告了相同的问题 ,但未解决。 |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1208浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-2 06:39 , Processed in 0.714063 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
553
