电子发烧友论坛扫一扫,分享给好友
我直接编译了idf5.0的rgb_panel 工程,为什么会无限重启而且屏幕也不亮呢?报错如下
SPIWP:0xee mode:DIO, clock div:1 load:0x3fce3810,len:0x1684 load:0x403c9700,len:0xbe8 load:0x403cc700,len:0x2e98 entry 0x403c9904 I (24) boot: ESP-IDF v5.0-dirty 2nd stage bootloader I (24) boot: compile time 18:37:07 I (24) boot: chip revision: v0.1 I (26) boot_comm: chip revision: 1, min. bootloader chip revision: 0 I (33) boot.esp32s3: Boot SPI Speed : 80MHz I (38) boot.esp32s3: SPI Mode : DIO I (43) boot.esp32s3: SPI Flash Size : 8MB W (48) boot.esp32s3: PRO CPU has been reset by WDT. W (53) boot.esp32s3: APP CPU has been reset by WDT. I (59) boot: Enabling RNG early entropy source... I (64) boot: Partition Table: I (68) boot: ## Label Usage Type ST Offset Length I (75) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (82) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (90) boot: 2 factory factory app 00 00 00010000 00100000 I (97) boot: End of partition table I (102) boot_comm: chip revision: 1, min. application chip revision: 0 I (109) esp_image: segment 0: paddr=00010020 vaddr=3c050020 size=0eab4h ( 60084) map I (128) esp_image: segment 1: paddr=0001eadc vaddr=3fc93300 size=0153ch ( 5436) load I (130) esp_image: segment 2: paddr=00020020 vaddr=42000020 size=46298h (287384) map I (186) esp_image: segment 3: paddr=000662c0 vaddr=3fc9483c size=01fa0h ( 8096) load I (188) esp_image: segment 4: paddr=00068268 vaddr=40374000 size=0f224h ( 61988) load I (205) esp_image: segment 5: paddr=00077494 vaddr=50000000 size=00010h ( 16) load I (212) boot: Loaded app from partition at offset 0x10000 I (212) boot: Disabling RNG early entropy source... I (225) octal_psram: vendor id : 0x0d (AP) I (226) octal_psram: dev id : 0x02 (generation 3) I (226) octal_psram: density : 0x03 (64 Mbit) I (231) octal_psram: good-die : 0x01 (Pass) I (236) octal_psram: Latency : 0x01 (Fixed) I (241) octal_psram: VCC : 0x01 (3V) I (246) octal_psram: SRF : 0x01 (Fast Refresh) I (252) octal_psram: BurstType : 0x01 (Hybrid Wrap) I (258) octal_psram: BurstLen : 0x01 (32 Byte) I (263) octal_psram: Readlatency : 0x02 (10 cycles@Fixed) I (269) octal_psram: DriveStrength: 0x00 (1/1) W (275) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version. I (285) esp_psram: Found 8MB PSRAM device I (289) esp_psram: Speed: 80MHz I (327) mmu_psram: Instructions copied and mapped to SPIRAM I (334) mmu_psram: Read only data copied and mapped to SPIRAM I (334) cpu_start: Pro cpu up. I (334) cpu_start: Starting app cpu, entry point is 0x403753d4 0x403753d4: call_start_cpu1 at F:/Espressif/frameworks/esp-idf-v5.0/components/esp_system/port/cpu_start.c:142 I (0) cpu_start: App cpu up. I (764) esp_psram: SPI SRAM memory test OK I (773) cpu_start: Pro cpu start user code I (773) cpu_start: cpu freq: 160000000 Hz I (773) cpu_start: Application information: I (776) cpu_start: Project name: rgb_panel I (781) cpu_start: App version: 1 I (785) cpu_start: Compile time: Jan 11 2023 18:36:53 I (791) cpu_start: ELF file SHA256: d704e017bfb27c12... I (797) cpu_start: ESP-IDF: v5.0-dirty I (803) heap_init: Initializing. RAM available for dynamic allocation: I (810) heap_init: At 3FC97758 len 00051FB8 (327 KiB): D/IRAM I (816) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM I (823) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (829) heap_init: At 600FE010 len 00001FF0 (7 KiB): RTCRAM I (835) esp_psram: Adding pool of 7808K of PSRAM memory to heap allocator I (843) spi_flash: detected chip: winbond I (848) spi_flash: flash io: dio I (852) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (872) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations I (872) example: Create semaphores I (882) example: Turn off LCD backlight I (882) gpio: GPIO[46]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 I (892) example: Install RGB LCD panel driver |
只有小组成员才能发言,加入小组>>
460 浏览 0 评论
979 浏览 0 评论
1702 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1358 浏览 1 评论
1249 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1274浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
942浏览 3评论
2372浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2560浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1067浏览 2评论
/9
GMT+8, 2025-12-10 05:04 , Processed in 0.467176 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
928
