ESP32-WROOM-32D模组,上传bootloader.bin到 0x1000,partition-table.bin到 0x8000,hello_world.bin到 0x10000之后,总是反复打印以下信息,请大家帮助分析一下,是哪个地方出错了。
Rebooting... [0;32mI (12) boot: ESP-IDF v4.4 2nd stage bootloader[0m [0;32mI (12) boot: compile time 20:52:46[0m [0;32mI (12) boot: chip revision: 1[0m [0;32mI (14) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m [0;32mI (21) boot.esp32: SPI Speed : 40MHz[0m [0;32mI (25) boot.esp32: SPI Mode : DIO[0m [0;32mI (30) boot.esp32: SPI Flash Size : 4MB[0m [0;32mI (35) boot: Enabling RNG early entropy source...[0m [0;32mI (40) boot: Partition Table:[0m [0;32mI (44) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (51) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m [0;32mI (58) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (66) boot: 2 factory factory app 00 00 00010000 00100000[0m [0;32mI (73) boot: End of partition table[0m [0;32mI (77) boot_comm: chip revision: 1, min. application chip revision: 0[0m [0;32mI (84) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=07b64h ( 31588) map[0m [0;32mI (104) esp_image: segment 1: paddr=00017b8c vaddr=3ffb0000 size=02360h ( 9056) load[0m [0;32mI (108) esp_image: segment 2: paddr=00019ef4 vaddr=40080000 size=06124h ( 24868) load[0m [0;32mI (122) esp_image: segment 3: paddr=00020020 vaddr=400d0020 size=14fc4h ( 85956) map[0m [0;32mI (154) esp_image: segment 4: paddr=00034fec vaddr=40086124 size=05040h ( 20544) load[0m [0;32mI (162) esp_image: segment 5: paddr=0003a034 vaddr=50000000 size=00010h ( 16) load[0m [0;32mI (168) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (168) boot: Disabling RNG early entropy source...[0m [0;32mI (185) cpu_start: Pro cpu up.[0m [0;31mE (185) cpu_start: Running on single core variant of a chip, but app is built with multi-core support.[0m [0;31mE (187) cpu_start: Check that CONFIG_FREERTOS_UNICORE is enabled in menuconfig[0m abort() was called at PC 0x400d0d3c on core 0 Backtrace:0x4008181e:0x3ffe3b600x40085051:0x3ffe3b80 0x40089e56:0x3ffe3ba0 0x400d0d3c:0x3ffe3c10 0x40081101:0x3ffe3c40 0x400794d4:0x3ffe3c80 |<-CORRUPTED |
只有小组成员才能发言,加入小组>>
453 浏览 0 评论
975 浏览 0 评论
1700 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1357 浏览 1 评论
1248 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1272浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
941浏览 3评论
2371浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2556浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1066浏览 2评论
/9
GMT+8, 2025-12-9 13:37 , Processed in 0.606237 second(s), Total 38, Slave 31 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
568
