I (772) spi_flash: flash io: qio
I (772) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (785) example_asr_keywords: Initialize SR wn handle Quantized wakeNet5: wakeNet5_v1_hilexin_5_0.95_0.90, mode:0 (Oct 14 2020 16:26:17) I (798) example_asr_keywords: keywords: hilexin (index = 1) Fail: index is out of range, the min index is 1, the max index is 1I (804) example_asr_keywords: keywords_num = 1, threshold = 0.000000, sample_rate = 16000, chunksize = 480, sizeof_uint16 = 2 WARNING: Sample length must less than 5000ms in the SINGLE_RECOGNITION mode SINGLE_RECOGNITION: 2_0 MN1_4; core: 0; (May 15 2020 14:50:27) SHIFT: 8, 12, 17, 17, 19, 17, 6, 16, 15, 14, I (847) example_asr_keywords: keywords_num = 166 , sample_rate = 16000, chunksize = 480, sizeof_uint16 = 2 I (848) example_asr_keywords: [ 1 ] Start codec chip I (1355) example_asr_keywords: [ 2.0 ] Create audio pipeline for recording I (1355) example_asr_keywords: [ 2.1 ] Create i2s stream to read audio data from codec chip I (1376) example_asr_keywords: [ 2.3 ] Create raw to receive data I (1376) example_asr_keywords: [ 3 ] Register all elements to audio pipeline I (1380) example_asr_keywords: [ 4 ] Link elements together [codec_chip]-->i2s_stream-->raw-->[SR] W (1491) I2C_BUS: i2c_bus_create:53: I2C bus has been already created, [port:0] ----------------------------- ESP Audio Platform ----------------------------- | | | ESP_AUDIO-v1.7.0-31-g5b8f999-3072767-09be8fe | | Compile date: Oct 14 2021-11:00:34 | ------------------------------------------------------------------------------ I (1556) example_asr_keywords: esp_audio instance is:0x3ffce8f0 I (1556) example_asr_keywords: [ 5 ] Start audio_pipeline |
只有小组成员才能发言,加入小组>>
503浏览 6评论
416浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
400浏览 5评论
401浏览 4评论
374浏览 4评论
GMT+8, 2024-10-20 01:45 , Processed in 0.923587 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
