环境:windows下esp_adf v2.3+esp_idf v4.4 + vscode
在vscode里面编译成功但是,有编译警告如下,然后下载到开发板ESP32-LyraT v4.3运行后出现错误提示! 是不是adf v2.3不能支持idf v4.4 [97/97] cmd.exe /C "cd /D C:Espressifvoipbuildbootloaderesp-idfesptool_py && c:Espressifpython_envidf4.4_py3.8_envScriptspython.exe C:/Espressif/frameworks/esp-idf-v4.4/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 C:/Espressif/voip/build/bootloader/bootloader.bin" Bootloader binary size 0x6990 bytes. 0x670 bytes (6%) free. [1007/1175] Building C object esp-idf/audio_sal/CMakeFiles/__idf_audio_sal.dir/audio_thread.c.obj C:/Espressif/esp-adf/components/audio_sal/audio_thread.c: In function 'audio_thread_create': C:/Espressif/esp-adf/components/audio_sal/audio_thread.c:71:64: warning: passing argument 2 of 'xTaskCreateRestrictedPinnedToCore' from incompatible pointer type [-Wincompatible-pointer-types] if (xTaskCreateRestrictedPinnedToCore(&xRegParameters, (xTaskHandle)p_handle, core_id) != pdPASS) { ^~~~~~~~~~~~~~~~~~~~~ C:/Espressif/esp-adf/components/audio_sal/audio_thread.c:36:130: note: expected 'struct tskTaskControlBlock **' but argument is of type 'struct tskTaskControlBlock *' BaseType_t __attribute__((weak)) xTaskCreateRestrictedPinnedToCore(const TaskParameters_t *const pxTaskDefinition, TaskHandle_t *pxCreatedTask, const BaseType_t xCoreID) ~~~~~~~~~~~~~~^~~~~~~~~~~~~ C:/Espressif/esp-adf/components/audio_sal/audio_thread.c:76:72: warning: passing argument 6 of 'xTaskCreatePinnedToCore' from incompatible pointer type [-Wincompatible-pointer-types] if (xTaskCreatePinnedToCore(main_func, name, stack, arg, prio, (xTaskHandle)p_handle, core_id) != pdPASS) { ^~~~~~~~~~~~~~~~~~~~~ In file included from C:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/freertos/queue.h:41, from C:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/freertos/semphr.h:34, from C:/Espressif/esp-adf/components/audio_sal/audio_thread.c:26: C:/Espressif/frameworks/esp-idf-v4.4/components/freertos/include/freertos/task.h:350:62: note: expected 'struct tskTaskControlBlock ** const' but argument is of type 'struct tskTaskControlBlock *' TaskHandle_t * const pvCreatedTask, ~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~ [1174/1175] Generating binary image from built executable 下载到开发板ESP32-LyraT v4.3运行后出现错误提示 I (0) cpu_start: App cpu up. I (972) spiram: SPI SRAM memory test OK I (980) cpu_start: Pro cpu start user code I (981) cpu_start: cpu freq: 240000000 I (981) cpu_start: Application information: I (983) cpu_start: Project name: voip_app I (988) cpu_start: App version: 1 I (993) cpu_start: Compile time: Feb 15 2022 16:57:42 I (999) cpu_start: ELF file SHA256: 1f1c68a047361ceb... I (1005) cpu_start: ESP-IDF: v4.4-dirty I (1010) heap_init: Initializing. RAM available for dynamic allocation: I (1017) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1024) heap_init: At 3FFB4FE8 len 0002B018 (172 KiB): DRAM I (1030) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (1036) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1043) heap_init: At 40094400 len 0000BC00 (47 KiB): IRAM I (1049) spiram: Adding pool of 4084K of external SPI memory to heap allocator I (1058) spi_flash: detected chip: gd I (1061) spi_flash: flash io: qio I (1066) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (1076) spiram: Reserving pool of 18K of internal memory for DMA/internal allocations I (1106) VOIP_EXAMPLE: [1.0] Initialize peripherals management I (1106) VOIP_EXAMPLE: [1.1] Initialize and start peripherals I (1116) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 I (1126) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 I (1126) VOIP_EXAMPLE: [1.2] Create and start input key service W (1146) PERIPH_TOUCH: _touch_init I (1146) VOIP_EXAMPLE: [ 1.3 ] Create display service instance I (1156) VOIP_EXAMPLE: [ 2 ] Start codec chip I (1156) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 E (1166) gpio: gpio_install_isr_service(449): GPIO isr service already installed I (1196) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 I (1196) ES8388_DRIVER: init,out:02, in:00 I (1206) AUDIO_HAL: Codec mode is 3, Ctrl:1 I (1206) VOIP_EXAMPLE: [ 3 ] Initialize tone player I (1216) AUDIO_THREAD: The media_task task allocate stack on external memory E (1216) MEDIA_OS: Not found right xTaskCreateRestrictedPinnedToCore. Please enter IDF-PATH with "cd $IDF_PATH" and apply the IDF patch with "git apply $ADF_PATH/idf_patches/idf_v3.3_freertos.patch" first E (1236) AUDIO_THREAD: Error creating RestrictedPinnedToCore media_task E (1246) ESP_AUDIO_CTRL: Error create media_task E (1246) PLAYER_INT_TONE: audio_player_int_tone.c:44 (audio_player_int_tone_init): Memory exhausted I (1256) VOIP_EXAMPLE: [ 4 ] Create Wi-Fi service instance E (1266) DISPATCHER: exe first list: 0x0 I (1286) DISPATCHER: dispatcher_event_task is running... E (1286) WIFI_SSID_MANAGER: Fail to get configuration from nvs flash I (1286) AUDIO_THREAD: The wifi_serv task allocate stack on external memory E (1296) MEDIA_OS: Not found right xTaskCreateRestrictedPinnedToCore. Please enter IDF-PATH with "cd $IDF_PATH" and apply the IDF patch with "git apply $ADF_PATH/idf_patches/idf_v3.3_freertos.patch" first E (1306) AUDIO_THREAD: Error creating RestrictedPinnedToCore wifi_serv E (1326) PERIPH_SERVICE: Create task failed on periph_service_create E (1326) WIFI_SERV: wifi_service.c:686 (wifi_service_create): Memory exhausted E (1356) WIFI_SERV: wifi_service.c:518 (wifi_service_register_setting_handle): Got NULL Pointer E (1356) WIFI_SERV: wifi_service.c:576 (wifi_service_set_sta_info): Got NULL Pointer E (1356) WIFI_SERV: wifi_service.c:560 (wifi_service_connect): Got NULL Pointer |
只有小组成员才能发言,加入小组>>
321浏览 6评论
279浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
265浏览 5评论
274浏览 4评论
253浏览 4评论
GMT+8, 2024-7-5 13:19 , Processed in 0.627485 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
