I (0) cpu_start: App cpu up.
I (1292) spiram: SPI SRAM memory test OK I (1300) cpu_start: Pro cpu start user code I (1300) cpu_start: cpu freq: 240000000 I (1300) cpu_start: Application information: I (1303) cpu_start: Project name: element_wav_amr_sdcard I (1309) cpu_start: App version: 1 I (1314) cpu_start: Compile time: Jun 22 2022 09:37:30 I (1320) cpu_start: ELF file SHA256: 76ce9430975198cb... I (1326) cpu_start: ESP-IDF: v4.4-dirty I (1332) heap_init: Initializing. RAM available for dynamic allocation: I (1339) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1345) heap_init: At 3FFB32E8 len 0002CD18 (179 KiB): DRAM I (1351) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (1357) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1364) heap_init: At 40094EC4 len 0000B13C (44 KiB): IRAM I (1371) spiram: Adding pool of 4095K of external SPI memory to heap allocator I (1379) spi_flash: detected chip: gd I (1383) spi_flash: flash io: dio I (1388) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (1397) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations I (1407) ELEMENT_REC_WAV_AMR_SDCARD: [1.0] Mount sdcard I (1917) ELEMENT_REC_WAV_AMR_SDCARD: [2.0] Start codec chip W (1937) I2C_BUS: i2c_bus_create:57: I2C bus has been already created, [port:0] I (1947) ELEMENT_REC_WAV_AMR_SDCARD: [3.0] Create i2s stream to read audio data from codec chip I (1947) ELEMENT_REC_WAV_AMR_SDCARD: [3.1] Create wav encoder to encode wav format I (1957) ELEMENT_REC_WAV_AMR_SDCARD: [3.2] Create fatfs stream to write data to sdcard I (1967) ELEMENT_REC_WAV_AMR_SDCARD: [3.3] Create a ringbuffer and insert it between i2s_stream_reader and wav_encoder I (1977) ELEMENT_REC_WAV_AMR_SDCARD: [3.4] Create a ringbuffer and insert it between wav_encoder and wav_fatfs_stream_writer I (1987) ELEMENT_REC_WAV_AMR_SDCARD: [3.5] Set up uri (file as fatfs_stream, wav as wav encoder) I (1997) ELEMENT_REC_WAV_AMR_SDCARD: [4.0] Create amr encoder to encode wav format I (2007) ELEMENT_REC_WAV_AMR_SDCARD: [4.1] Create fatfs stream to write data to sdcard I (2007) ELEMENT_REC_WAV_AMR_SDCARD: [4.2] Create a ringbuffer and insert it between i2s_stream_reader and wav_encoder I (2027) ELEMENT_REC_WAV_AMR_SDCARD: [4.3] Create a ringbuffer and insert it between wav_encoder and wav_fatfs_stream_writer I (2037) ELEMENT_REC_WAV_AMR_SDCARD: [4.4] Set up uri (file as fatfs_stream, wav as wav encoder) I (2047) ELEMENT_REC_WAV_AMR_SDCARD: [5.0] Set callback function for audio_elements I (2057) ELEMENT_REC_WAV_AMR_SDCARD: [6.0] Set up event listener I (2057) ELEMENT_REC_WAV_AMR_SDCARD: [7.0] Listening event from peripherals I (2067) ELEMENT_REC_WAV_AMR_SDCARD: [8.0] Start audio elements E (2077) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore. Please enter IDF-PATH with "cd $IDF_PATH" and apply the IDF patch with "git apply $ADF_PATH/idf_patches/idf_v4.4_freertos.patch" first E (2097) AUDIO_THREAD: Error creating RestrictedPinnedToCore wav I (2097) ELEMENT_REC_WAV_AMR_SDCARD: Audio event 8 from wav element I (2107) ELEMENT_REC_WAV_AMR_SDCARD: Some other event = 1 E (2117) AUDIO_ELEMENT: [wav] audio_thread_create failed E (2117) AUDIO_THREAD: Not found right xTaskCreateRestrictedPinnedToCore. Please enter IDF-PATH with "cd $IDF_PATH" and apply the IDF patch with "git apply $ADF_PATH/idf_patches/idf_v4.4_freertos.patch" first E (2137) AUDIO_THREAD: Error creating RestrictedPinnedToCore amr I (2147) ELEMENT_REC_WAV_AMR_SDCARD: Audio event 8 from amr element I (2147) ELEMENT_REC_WAV_AMR_SDCARD: Some other event = 1 E (2157) AUDIO_ELEMENT: [amr] audio_thread_create failed W (2167) AUDIO_ELEMENT: [iis-0x3f8073a4] RESUME timeout I (2167) ELEMENT_REC_WAV_AMR_SDCARD: Audio event 8 from iis element W (2167) AUDIO_ELEMENT: [wav] Element has not create when AUDIO_ELEMENT_RESUME I (2177) ELEMENT_REC_WAV_AMR_SDCARD: AEL_STATUS_STATE_RUNNING W (2187) AUDIO_ELEMENT: [amr] Element has not create when AUDIO_ELEMENT_RESUME W (2197) AUDIO_ELEMENT: [file-0x3f808914] RESUME timeout |
只有小组成员才能发言,加入小组>>
475浏览 6评论
399浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
380浏览 5评论
385浏览 4评论
361浏览 4评论
GMT+8, 2024-10-1 18:17 , Processed in 0.637487 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
