IDF版本v4.3-rc
直接烧入Homekit Lightbulb例程之后报错: E (410) esp_image: Image length 1665504 doesn't fit in partition length 1638400 为了解决这个问题,我将partitions_hap.csv的内容修改为: [Codebox] # Name, Type, SubType, Offset, Size, Flags # Note: Firmware partition offset needs to be 64K aligned, initial 36K (9 sectors) are reserved for bootloader and partition table sec_cert, 0x3F, ,0xd000, 0x3000, , # Never mark this as an encrypted partition nvs, data, nvs, 0x10000, 0x6000, otadata, data, ota, , 0x2000 phy_init, data, phy, , 0x1000, ota_0, app, ota_0, 0x20000, 1792K, ota_1, app, ota_1, , 1792K, factory_nvs, data, nvs, 0x3a0000, 0x6000 nvs_keys, data, nvs_keys,0x3a6000, 0x1000 [/Codebox] 再次编译下载后,依然报错无法正常运行 [Codebox] ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0xc (RTC_SW_CPU_RST),boot:0xc (SPI_FAST_FLASH_BOOT) Saved PC:0x40383e58 0x40383e58: esp_restart_noos at /Users/mephisto/esp/esp-idf/components/esp32c3/system_api_esp32c3.c:137 (discriminator 1) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x1778 load:0x403ce000,len:0x8d4 load:0x403d0000,len:0x293c entry 0x403ce000 I (35) boot: ESP-IDF v4.3-rc 2nd stage bootloader I (35) boot: compile time 15:00:03 I (35) boot: chip revision: 3 I (37) boot.esp32c3: SPI Speed : 80MHz I (42) boot.esp32c3: SPI Mode : DIO I (46) boot.esp32c3: SPI Flash Size : 4MB I (51) boot: Enabling RNG early entropy source... I (57) boot: Partition Table: I (60) boot: ## Label Usage Type ST Offset Length I (67) boot: 0 sec_cert unknown 3f 00 0000d000 00003000 I (75) boot: 1 nvs WiFi data 01 02 00010000 00006000 I (82) boot: 2 otadata OTA data 01 00 00016000 00002000 I (90) boot: 3 phy_init RF data 01 01 00018000 00001000 I (97) boot: 4 ota_0 OTA app 00 10 00020000 001c0000 I (105) boot: 5 ota_1 OTA app 00 11 001e0000 001c0�ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x1778 load:0x403ce000,len:0x8d4 load:0x403d0000,len:0x293c entry 0x403ce000 I (30) boot: ESP-IDF v4.3-rc 2nd stage bootloader I (30) boot: compile time 15:00:03 I (30) boot: chip revision: 3 I (32) boot.esp32c3: SPI Speed : 80MHz I (37) boot.esp32c3: SPI Mode : DIO I (41) boot.esp32c3: SPI Flash Size : 4MB I (46) boot: Enabling RNG early entropy source... I (52) boot: Partition Table: I (55) boot: ## Label Usage Type ST Offset Length I (62) boot: 0 sec_cert unknown 3f 00 0000d000 00003000 I (70) boot: 1 nvs WiFi data 01 02 00010000 00006000 I (77) boot: 2 otadata OTA data 01 00 00016000 00002000 I (85) boot: 3 phy_init RF data 01 01 00018000 00001000 I (92) boot: 4 ota_0 OTA app 00 10 00020000 001c0000 I (100) boot: 5 ota_1 OTA app 00 11 001e0000 001c0000 I (107) boot: 6 factory_nvs WiFi data 01 02 003a0000 00006000 I (115) boot: 7 nvs_keys NVS keys 01 04 003a6000 00001000 I (122) boot: End of partition table I (127) esp_image: segment 0: paddr=00020020 vaddr=3c140020 size=46a04h (289284) map I (180) esp_image: segment 1: paddr=00066a2c vaddr=3fc8da00 size=045f0h ( 17904) load I (184) esp_image: segment 2: paddr=0006b024 vaddr=40380000 size=04ff4h ( 20468) load I (190) esp_image: segment 3: paddr=00070020 vaddr=42000020 size=13e0dch (1302748) map I (398) esp_image: segment 4: paddr=001ae104 vaddr=40384ff4 size=0889ch ( 34972) load I (405) esp_image: segment 5: paddr=001b69a8 vaddr=50000000 size=00010h ( 16) load I (409) boot: Loaded app from partition at offset 0x20000 I (410) boot: Disabling RNG early entropy source... I (427) cpu_start: Pro cpu up. I (439) cpu_start: Pro cpu start user code I (440) cpu_start: cpu freq: 160000000 I (440) cpu_start: Application information: I (442) cpu_start: Project name: lightbulb I (447) cpu_start: App version: esp_homekit_release_3.0.r3-38-g I (454) cpu_start: Compile time: Jun 10 2021 14:59:55 I (461) cpu_start: ELF file SHA256: 1a89a731318cf04a... I (466) cpu_start: ESP-IDF: v4.3-rc I (472) heap_init: Initializing. RAM available for dynamic allocation: I (479) heap_init: At 3FC9AE00 len 00025200 (148 KiB): DRAM I (485) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM I (492) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM I (498) spi_flash: detected chip: generic I (503) spi_flash: flash io: dio I (507) sleep: Configure to isolate all GPIO pins in sleep state I (513) sleep: Enable automatic switching of GPIO sleep configuration I (521) cpu_start: Starting scheduler. Keystore initialised Accessory is not Paired with any controller Database initialised. Accessory Device ID: E3:BC:81:CB:BE:91 HAP Initialization succeeded. Version : 4.0-c654909 E (566) ledc: freq_hz=5000 duty_resolution=0 I (566) gpio: GPIO[0]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 I (576) app_hap_setup_payload: -----QR Code for HomeKit----- I (586) app_hap_setup_payload: Scan this QR code from the Home app on iOS █▀▀▀▀▀█ █▀ █▀▀▀▀▀█ █ ███ █ █▀▄▀▀ █ ███ █ █ ▀▀▀ █ ██▀ █ █ ▀▀▀ █ ▀▀▀▀▀▀▀ █ █ ▀ ▀▀▀▀▀▀▀ ▀ ▀███▀ ▄▀ ▄█▄██▀██ ▄ █▄█▄▀▄▀▀▀█▀▄█ ▀ ▄█▄ ▀▀ ▀▀▄▄▀ ▀▄▀▄ ▄▄█▀ █▀▀▀▀▀█ ▄ ▄█▀▄█ █ ▀▄ █ ███ █ █▀█ ▄▀▀█▀ ▀ █ ▀▀▀ █ ▀█▄ █▄ ▄ █▀ ▄ ▀▀▀▀▀▀▀ ▀▀ ▀▀▀ ▀▀ I (656) app_hap_setup_payload: If QR code is not visible, copy paste the below URL in a browser. https://api.qrserver.com/v1/create-qr-c ... 27813XES32 MFi auth not supported. Falling back to HAP_MFI_AUTH_NONE I (686) coexist: coexist rom version 9387209 I (686) pp: pp rom version: 9387209 I (686) net80211: net80211 rom version: 9387209 I (706) wifi:wifi driver task: 3fca65c4, prio:23, stack:6656, core=0 I (706) system_api: Base MAC address is not set I (706) system_api: read default base MAC address from EFUSE I (716) wifi:wifi firmware version: c7d0450 I (716) wifi:wifi certification version: v7.0 I (716) wifi:config NVS flash: enabled I (726) wifi:config nano formating: disabled I (726) wifi:Init data frame dynamic rx buffer num: 32 I (736) wifi:Init management frame dynamic rx buffer num: 32 I (736) wifi:Init management short buffer num: 32 I (746) wifi:Init dynamic tx buffer num: 32 I (746) wifi:Init static tx FG buffer num: 2 I (756) wifi:Init static rx buffer size: 1600 I (756) wifi:Init static rx buffer num: 10 I (756) wifi:Init dynamic rx buffer num: 32 I (766) wifi_init: rx ba win: 6 I (766) wifi_init: tcpip mbox: 32 I (766) wifi_init: udp mbox: 10 I (776) wifi_init: tcp mbox: 6 I (776) wifi_init: tcp tx win: 5744 I (786) wifi_init: tcp rx win: 5744 I (786) wifi_init: tcp mss: 1440 I (786) wifi_init: WiFi IRAM OP enabled I (796) wifi_init: WiFi RX IRAM OP enabled Setup ID: ES32 HAP Main Loop Started mDNS initialised Registering HomeKit web handlers Announcing _hap._tcp mDNS service W (816) BTDM_INIT: esp_bt_mem_release not implemented, return OK I (826) wifi_prov_scheme_ble: BT memory released I (826) app_wifi: Starting provisioning I (836) phy_init: phy_version 500,985899c,Apr 19 2021,16:05:08 I (946) wifi:set rx active PTI: 0, rx ack PTI: 12, and default PTI: 1 I (956) wifi:mode : sta (7c:df:a1:87:b1:fc) I (956) wifi:enable tsf I (956) BTDM_INIT: BT controller compile version [501d88d] I (956) coexist: coexist rom version 9387209 I (966) BTDM_INIT: Bluetooth MAC: 7c:df:a1:87:b1:fe E (966) simple_ble: Configuration mismatch. Select BLE Only or BTDM mode from menuconfig E (976) protocomm_ble: simple_ble_start failed w/ error code 0xffffffff E (986) wifi_prov_scheme_ble: Failed to start protocomm BLE service E (996) wifi_prov_mgr: Failed to start service ESP_ERROR_CHECK failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x4038565d 0x4038565d: _esp_error_check_failed at /Users/mephisto/esp/esp-idf/components/esp_common/src/esp_err.c:41 file: "/Users/mephisto/esp/esp-homekit-sdk/examples/common/app_wifi/app_wifi.c" line 421 func: app_wifi_start expression: wifi_prov_mgr_start_provisioning(security, pop, service_name, service_key) abort() was called at PC 0x40385661 on core 0 0x40385661: _esp_error_check_failed at /Users/mephisto/esp/esp-idf/components/esp_common/src/esp_err.c:42 Stack dump detected Core 0 register dump: MEPC : 0x40386524 RA : 0x40386c84 SP : 0x3fca00b0 GP : 0x3fc8e288 0x40386524: panic_abort at /Users/mephisto/esp/esp-idf/components/esp_system/panic.c:367 0x40386c84: rtos_int_enter at /Users/mephisto/esp/esp-idf/components/freertos/port/riscv/portasm.S:35 TP : 0x3fc598fc T0 : 0x37363534 T1 : 0x7271706f T2 : 0x33323130 S0/FP : 0x00000004 S1 : 0x3fca0114 A0 : 0x3fca00dc A1 : 0x3fca0112 A2 : 0x00000000 A3 : 0x3fca0109 A4 : 0x00000001 A5 : 0x3fc9b000 A6 : 0x7a797877 A7 : 0x76757473 S2 : 0x00000000 S3 : 0x00000000 S4 : 0x00000000 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000 S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000 T3 : 0x6e6d6c6b T4 : 0x6a696867 T5 : 0x66656463 T6 : 0x62613938 MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x00000000 0x40380001: _vector_table at ??:? MHARTID : 0x00000000 Backtrace: panic_abort (details=details@entry=0x3fca00dc "abort() was called at PC 0x40385661 on core 0") at /Users/mephisto/esp/esp-idf/components/esp_system/panic.c:367 367 *((int *) 0) = 0; // NOLINT(clang-analyzer-core.NullDereference) should be an invalid operation on targets #0 panic_abort (details=details@entry=0x3fca00dc "abort() was called at PC 0x40385661 on core 0") at /Users/mephisto/esp/esp-idf/components/esp_system/panic.c:367 #1 0x40386c84 in esp_system_abort (details=details@entry=0x3fca00dc "abort() was called at PC 0x40385661 on core 0") at /Users/mephisto/esp/esp-idf/components/esp_system/system_api.c:112 #2 0x4038c456 in abort () at /Users/mephisto/esp/esp-idf/components/newlib/abort.c:46 #3 0x40385664 in _esp_error_check_failed (rc= #4 0x42009240 in app_wifi_start (ticks_to_wait=ticks_to_wait@entry=4294967295) at /Users/mephisto/esp/esp-homekit-sdk/examples/common/app_wifi/app_wifi.c:421 #5 0x420079ba in lightbulb_thread_entry (arg= #6 0x40389480 in vPortEnterCritical () at /Users/mephisto/esp/esp-idf/components/freertos/port/riscv/port.c:130 #7 0x00000000 in ?? () Backtrace stopped: frame did not save the PC ELF file SHA256: 1a89a731318cf04a [/Codebox] 请问这个问题如何解决? 我这边同样的例程把环境修改为ESP32就可以正常运行。这个问题只在ESP32C3上出现。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 08:55 , Processed in 0.647094 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
938
