电子发烧友论坛|
我正在尝试采用下面的草图与我的 WeMos D1 mini 和众所周知的旋转编码器 KY-040 一起使用,但由于某种原因它不起作用,但相同的草图在 Arduino Uno 上运行良好(与不同的引脚分配)。
有人能告诉我草图有什么问题吗? 谢谢你! 代码:全选const int PinA = 14; // Used for generating interrupts using CLK signal const int PinB = 12; // Used for reading DT signal const int PinSW = 13; // Used for the push button switch int lCnt = 0; // Keep track of last rotary value volatile int vPos = 0; // Updated by the ISR (Interrupt Service Routine) void isr_event () { static unsigned long lIsrTmr = 0; // Last Interrupt time unsigned long IsrTmr = millis(); // Interrupt time // If interrupts come faster than 5ms, assume it's a bounce and ignore if (IsrTmr - lIsrTmr > 5) { if (digitalRead(PinB) == LOW) { vPos++ ; // Could be +5 or +10 } else { vPos-- ; // Could be -5 or -10 } // Restrict value from 0 to +100 vPos = min(10, max(0, vPos)); // Keep track of when we were here last (no more than every 5ms) lIsrTmr = IsrTmr; } } void setup() { Serial.begin(9600); // Rotary pulses are INPUTs pinMode(PinA, INPUT); pinMode(PinB, INPUT); pinMode(PinSW, INPUT_PULLUP); // Switch is floating so use the in-built PULLUP so we don't need a resistor attachInterrupt(digitalPinToInterrupt(PinA), isr_event, LOW); // Attach the routine to service the interrupts Serial.println(F("Starting...")); // Ready to go! } void loop() { // Is someone pressing the rotary switch? if ((!digitalRead(PinSW))) { vPos = 0; while (!digitalRead(PinSW)) delay(10); } // If the current rotary switch position has changed then update everything if (vPos != lCnt) { // Write out to serial monitor the value and direction Serial.println(vPos); // Keep track of this new value lCnt = vPos ; } } |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 07:33 , Processed in 0.606041 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
739
