芯片我用的是STM32L412,IAP程序参考了L4固件库的IAP例程, COM_StatusTypeDef Ymodem_Receive ( uint32_t *p_size ) { uint32_t i, packet_length, session_done = 0, file_done, errors = 0, session_begin = 0; uint32_t flashdestination, ramsource, filesize; uint8_t *file_ptr; uint8_t file_size[FILE_SIZE_LENGTH], tmp, packets_received; COM_StatusTypeDef result = COM_OK; /* Initialize flashdestination variable */ flashdestination = APPLICATION_ADDRESS; while ((session_done == 0) && (result == COM_OK)) { packets_received = 0; file_done = 0; while ((file_done == 0) && (result == COM_OK)) { switch (ReceivePacket(aPacketData, &packet_length, DOWNLOAD_TIMEOUT)) { case HAL_OK: errors = 0; switch (packet_length) { case 2: /* Abort by sender */ Serial_PutByte(ACK); result = COM_ABORT; break; case 0: /* End of transmission */ Serial_PutByte(ACK); file_done = 1; break; default: /* Normal packet */ if (aPacketData[PACKET_NUMBER_INDEX] != packets_received) { Serial_PutByte(NAK); } else { if (packets_received == 0) { /* File name packet */ if (aPacketData[PACKET_DATA_INDEX] != 0) { /* File name extraction */ i = 0; file_ptr = aPacketData + PACKET_DATA_INDEX; while ( (*file_ptr != 0) && (i < FILE_NAME_LENGTH)) { aFileName[i++] = *file_ptr++; } /* File size extraction */ aFileName[i++] = ' |
