电子发烧友论坛|
在这里,我试图将数据从 nodeMCU 发送到两条路线“/tempData”和“/updateValues”。我尝试了下面的代码,但它不起作用。任何帮助将不胜感激。
代码:全选// For WiFI Connectivity #include // for temperature #include int pinDHT22 = 2; SimpleDHT22 dht22(pinDHT22); // WiFi SSID const char* ssid = "ssid"; // WiFi Password const char* password = "password"; // Enter Server-URL here const char* host = "server_url"; void setup() { Serial.begin(74880); Serial.println(); Serial.println(); Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP()); } void loop() { float temperature = 0; float humidity = 0; int err = SimpleDHTErrSuccess; if ((err = dht22.read2(&temperature, &humidity, NULL)) != SimpleDHTErrSuccess) { //Check for connection error Serial.print("Read DHT22 failed, err="); Serial.println(err);delay(2000); return; } Serial.print("connecting to "); Serial.println(host); // Use WiFiClient class to create TCP connections WiFiClient client; const int httpPort = 80; if (!client.connect(host, httpPort)) { Serial.println("connection failed"); return; } // We now create a URI for the request String url = "/"; Serial.print("Temperature: "); Serial.print((float)temperature); Serial.println(" *C, "); Serial.print("Requesting URL: "); Serial.println(url); // Location Coordinates (hard coded) when GPS module not in use String loc = "del"; // Package-ID of the package being trasported String id = "H103"; String data = ("Temperature=" + String(((float)temperature)) + "&packageID=" + id + "&Location=" + loc); Serial.print("Requesting POST: "); // HTTP FORMAT // Send request to the server: client.println("POST /tempData HTTP/1.1"); client.println("Host: server_url"); client.println("Accept: */*"); client.println("Content-Type: application/x-www-form-urlencoded"); client.print("Content-Length: "); client.println(data.length()); client.println(); client.print(data); // This will send the request to the server Serial.print("Requesting POST: "); // HTTP FORMAT // Send request to the server: client.println("POST /updateValues HTTP/1.1"); client.println("Host: server_url"); client.println("Accept: */*"); client.println("Content-Type: application/x-www-form-urlencoded"); client.print("Content-Length: "); client.println(data.length()); client.println(); client.print(data); // This will send the request to the server unsigned long timeout = millis(); while (client.available() == 0) { if (millis() - timeout > 5000) { Serial.println(">>> Client Timeout !"); client.stop(); return; } } // Read all the lines of the reply from server and print them to Serial while(client.available()){ String line = client.readStringUntil('r'); Serial.print(line); } Serial.println(); Serial.println("closing connection"); } |
只有小组成员才能发言,加入小组>>
442 浏览 0 评论
967 浏览 0 评论
1694 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1349 浏览 1 评论
1246 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1270浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
936浏览 3评论
2368浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2555浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1063浏览 2评论
/9
GMT+8, 2025-12-8 08:51 , Processed in 0.805017 second(s), Total 74, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
25187
