我目前正在尝试确定 Kalanda ( https://github.com/kalanda/esp8266-sniffer ) 的 ESP8266 WifiSniffer 程序是如何工作的。这是源代码:
代码:全选#include extern "C" { #include } #define DATA_LENGTH 112 #define TYPE_MANAGEMENT 0x00 #define TYPE_CONTROL 0x01 #define TYPE_DATA 0x02 #define SUBTYPE_PROBE_REQUEST 0x04 struct RxControl { //THESE HAVE AN EFFECT // signed rssi:8; // signal intensity of packet // unsigned rate:4; // unsigned is_group:1; // unsigned:1; // unsigned legacy_length:12; // if not 11n packet, shows length of packet. NOT THIS // unsigned MCS:7; // if is 11n packet, shows the modulation and code used (range from 0 to 76) // unsigned Smoothing:1; // unsigned Not_Sounding:1; // unsigned:1; // unsigned Aggregation:1; // unsigned STBC:2; // unsigned rxend_state:8; // unsigned ampdu_cnt:8; // unsigned channel:4; //which channel this packet in. //THESE HAVE NO EFFECT // unsigned sig_mode:2; // 0:is 11n packet; 1:is not 11n packet; // unsigned damatch0:1; // unsigned damatch1:1; // unsigned bssidmatch0:1; // unsigned bssidmatch1:1; // unsigned CWB:1; // if is 11n packet, shows if is HT40 packet or not // unsigned HT_length:16;// if is 11n packet, shows length of packet. NOT THIS //unsigned FEC_CODING:1; // if is 11n packet, shows if is LDPC packet or not. //unsigned SGI:1; //unsigned:12; //HAS NO EFFECT }; struct SnifferPacket{ struct RxControl rx_ctrl; //RxControl is just a name, can be named anything (as long as you change other things) uint8_t data[DATA_LENGTH]; //DOES NOT HAVE EFFECT // uint16_t cnt; //THIS HAS NO EFFECT // uint16_t len; //THIS HAS NO EFFECT }; // Declare each custom function (excluding built-in, such as setup and loop) before it will be called. // https://docs.platformio.org/en/latest/faq.html#convert-arduino-file-to-c-manually //static void showMetadata(SnifferPacket *snifferPacket); //static void sniffer_callback(uint8_t *buffer, uint16_t length); static void printDataSpan(uint16_t start, uint16_t size, uint8_t* data); static void getMAC(char *addr, uint8_t* data, uint16_t offset); void channelHop(); /** * Callback for promiscuous mode */ static void sniffer_callback(uint8_t *buffer, uint16_t length) { struct SnifferPacket *snifferPacket; snifferPacket = (struct SnifferPacket*) buffer; Serial.print("buffer size: "); Serial.print(sizeof(buffer)); Serial.print(" length size: "); Serial.print(sizeof(length)); Serial.print(" snifferPacket size: "); Serial.print(sizeof(snifferPacket)); Serial.print(" START OF BUFFER OG: "); for (int i = 0; i < 20; i++){ Serial.print((unsigned int) buffer, BIN); Serial.print(" "); } Serial.print(" END OF BUFFER OG "); showMetadata(snifferPacket); } static void showMetadata(SnifferPacket *snifferPacket) { unsigned int frameControl = ((unsigned int)snifferPacket->data[1] << 8) + snifferPacket->data[0]; uint8_t version = (frameControl & 0b0000000000000011) >> 0; uint8_t frameType = (frameControl & 0b0000000000001100) >> 2; uint8_t frameSubType = (frameControl & 0b0000000011110000) >> 4; uint8_t toDS = (frameControl & 0b0000000100000000) >> 8; uint8_t fromDS = (frameControl & 0b0000001000000000) >> 9; uint8_t moreFragments = (frameControl & 0b0000010000000000) >> 10; uint8_t retry = (frameControl & 0b0000100000000000) >> 11; uint8_t powerMgmt = (frameControl & 0b0001000000000000) >> 12; uint8_t moreData = (frameControl & 0b0010000000000000) >> 13; uint8_t protectedFrame = (frameControl & 0b0100000000000000) >> 14; uint8_t htcOrder = (frameControl & 0b1000000000000000) >> 15; Serial.print(" START OF BUFFER: "); for (int i = 0; i < 20; i++){ Serial.print((unsigned int)snifferPacket->data, BIN); Serial.print(" "); } Serial.print(" END OF BUFFER "); Serial.print(" DATASPAN START: "); printDataSpan; Serial.print(" DATASPAN END "); Serial.print(" frameControl: "); Serial.print(frameControl); Serial.print(" version: "); Serial.print(version); Serial.print(" Type: "); Serial.print(frameType); Serial.print(" frameSubType: "); Serial.print(frameSubType); Serial.print(" toDS: "); Serial.print(toDS); Serial.print(" fromDS: "); Serial.print(fromDS); Serial.print(" moreFragments: "); Serial.print(moreFragments); Serial.print(" retry: "); Serial.print(retry); Serial.print(" powerMgmt: "); Serial.print(powerMgmt); Serial.print(" moreData: "); Serial.print(moreData); Serial.print(" protectedFrame: "); Serial.print(protectedFrame); Serial.print(" htcOrder: "); Serial.print(htcOrder); Serial.print(" Ch: "); Serial.print(wifi_get_channel()); // Serial.print(" rssi: "); // Serial.print(snifferPacket->rx_ctrl.rssi, BIN); // Serial.print(" RSSI: "); // Serial.print(snifferPacket->rx_ctrl.rssi, DEC); //Only look for probe request packets // if (frameType != TYPE_MANAGEMENT || // frameSubType != SUBTYPE_PROBE_REQUEST) // //Serial.println(); // return; // Serial.print(" RSSI: "); // Serial.print(snifferPacket->rx_ctrl.rssi, DEC); Serial.print(" Ch: "); Serial.print(wifi_get_channel()); char addr[] = "00:00:00:00:00:00"; getMAC(addr, snifferPacket->data, 10); Serial.print(" Peer MAC: "); Serial.print(addr); // uint8_t SSID_length = snifferPacket->data[25]; // Serial.print(" SSID: ");printDataSpan // printDataSpan(26, SSID_length, snifferPacket->data); Serial.println(); } static void printDataSpan(uint16_t start, uint16_t size, uint8_t* data) { for(uint16_t x = start; x < DATA_LENGTH && x < start+size; x++) { Serial.print(data[x]); //Serial.write(data[x]); } } static void getMAC(char *addr, uint8_t* data, uint16_t offset) { sprintf(addr, "%02x:%02x:%02x:%02x:%02x:%02x", data[offset+0], data[offset+1], data[offset+2], data[offset+3], data[offset+4], data[offset+5]); } #define CHANNEL_HOP_INTERVAL_MS 100 static os_timer_t channelHop_timer; /** * Callback for channel hoping */ void channelHop() { // hoping channels 1-13 uint8 new_channel = wifi_get_channel() + 1; if (new_channel > 13) { new_channel = 1; } wifi_set_channel(new_channel); } #define DISABLE 0 #define ENABLE 1 void setup() { // set the WiFi chip to "promiscuous" mode aka monitor mode Serial.begin(115200); //delay(10); wifi_set_opmode(STATION_MODE); wifi_set_channel(1); wifi_promiscuous_enable(DISABLE); //delay(10); wifi_set_promiscuous_rx_cb(sniffer_callback); //delay(10); wifi_promiscuous_enable(ENABLE); // setup the channel hoping callback timer //os_timer_disarm(&channelHop_timer); //os_timer_setfn(&channelHop_timer, (os_timer_func_t *) channelHop, NULL); //os_timer_arm(&channelHop_timer, CHANNEL_HOP_INTERVAL_MS, 1); } void loop() { //delay(10); } 我注意到直接来自缓冲区的 Serial.print 输出不同于变量 snifferPacket 的 Serial.print 输出,它被赋予了结构 RxControl 的属性。 当代码配置正常时,原始缓冲区输出 (BUFFER OG) 与 snifferPacket (BUFFER) 输出相比多了 12 个元素。这是一个例子: 代码:全选buffer size: 4 length size: 2 snifferPacket size: 4 START OF BUFFER OG: 10100010 10000 11100110 1010000 0 0 0 0 0 0 1 0 10000000 0 0 0 11111111 11111111 11111111 11111111 END OF BUFFER OG START OF BUFFER: 10000000 0 0 0 11111111 11111111 11111111 11111111 11111111 11111111 11011000 111 10110110 11010 10100010 1000001 11011000 111 10110110 11010 END OF BUFFER DATASPAN START: DATASPAN END frameControl: 128 version: 0 Type: 0 frameSubType: 8 toDS: 0 fromDS: 0 moreFragments: 0 retry: 0 powerMgmt: 0 moreData: 0 protectedFrame: 0 htcOrder: 0 Ch: 1 Ch: 1 Peer MAC: d8:07:b6:1a:a2:41 仅比较两个缓冲区输出: - 缓冲区OG:10100010 10000 11100110 1010000 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 10000000 0 0 0 0 0111111111111111111111111111111111111111111111成识别前 12 个元素的部分1. 10100010 -> RCPI (RSSI),二进制补码格式2. 10000 -> 未知3. 11100110 -> 未知4. 1010000 -> 未知5. 0 -> 未知,但常数6. 0 -> 未知,但常量7。0 -> 未知,但常量8。0 -> 未知,但常量9。0 -> 未知,但常量10。0 -> 未知,但常量 |
只有小组成员才能发言,加入小组>>
508浏览 6评论
425浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
404浏览 5评论
406浏览 4评论
378浏览 4评论
GMT+8, 2024-10-21 13:08 , Processed in 0.720179 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
