电子发烧友论坛|
最近开发一个项目有一个需求,需要BLE gatt client + BT HFP AG 共存
我写了一个demo,参考examplesbluetoothbluedroidclassic_bthfp_ag and examplesbluetoothbluedroidblegatt_client 首先hfp ag连接耳机,成功。 然后开始gatt client扫描,扫一会就出现了panic 串口log如下: rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:7100 ho 0 tail 12 room 4 load:0x40078000,len:14292 load:0x40080400,len:3688 0x40080400: _init at ??:? entry 0x40080678 I (29) boot: ESP-IDF v4.3-dirty 2nd stage bootloader I (29) boot: compile time 15:17:17 I (29) boot: chip revision: 3 I (32) boot_comm: chip revision: 3, min. bootloader chip revision: 0 I (40) boot.esp32: SPI Speed : 40MHz I (44) boot.esp32: SPI Mode : DIO I (49) boot.esp32: SPI Flash Size : 2MB I (53) boot: Enabling RNG early entropy source... I (58) boot: Partition Table: I (62) boot: ## Label Usage Type ST Offset Length I (69) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (77) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (84) boot: 2 factory factory app 00 00 00010000 00100000 I (92) boot: End of partition table I (96) boot_comm: chip revision: 3, min. application chip revision: 0 I (103) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=2a77ch (173948) map I (177) esp_image: segment 1: paddr=0003a7a4 vaddr=3ffbdb60 size=040d8h ( 16600) load I (184) esp_image: segment 2: paddr=0003e884 vaddr=40080000 size=01794h ( 6036) load I (187) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=a2d88h (667016) map I (443) esp_image: segment 4: paddr=000e2db0 vaddr=40081794 size=164b0h ( 91312) load I (482) esp_image: segment 5: paddr=000f9268 vaddr=50000000 size=00010h ( 16) load I (495) boot: Loaded app from partition at offset 0x10000 I (495) boot: Disabling RNG early entropy source... I (507) cpu_start: Pro cpu up. I (507) cpu_start: Starting app cpu, entry point is 0x400813cc 0x400813cc: call_start_cpu1 at /home/liupeng/WorkSpace/espressif/esp/esp-idf/components/esp_system/port/cpu_start.c:141 I (0) cpu_start: App cpu up. I (524) cpu_start: Pro cpu start user code I (524) cpu_start: cpu freq: 160000000 I (524) cpu_start: Application information: I (528) cpu_start: Project name: bt_ble_coex I (533) cpu_start: App version: v4.3-dirty I (539) cpu_start: Compile time: Aug 24 2021 15:17:17 I (545) cpu_start: ELF file SHA256: 2ba164595fb42e8d... I (551) cpu_start: ESP-IDF: v4.3-dirty I (556) heap_init: Initializing. RAM available for dynamic allocation: I (563) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM I (569) heap_init: At 3FFB6BF8 len 00001408 (5 KiB): DRAM I (575) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM I (581) heap_init: At 3FFC9C00 len 00016400 (89 KiB): DRAM I (588) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (594) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (600) heap_init: At 40097C44 len 000083BC (32 KiB): IRAM I (608) spi_flash: detected chip: gd I (611) spi_flash: flash io: dio W (615) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (629) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (639) BT_APP_HF: [app_main] app main start.... I (689) BTDM_INIT: BT controller compile version [1342a48] I (689) system_api: Base MAC address is not set I (689) system_api: read default base MAC address from EFUSE I (699) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07 E (1419) BT_BTC: btc_hf_cb_handler: Invalid index -1 I (1429) gpio: GPIO[19]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 I (1429) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 I (1439) gpio: GPIO[22]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 Type 'help' to get the list of commands. Use UP/DOWN arrows to navigate through command history. Press TAB when typing command name to auto-complete. ================================================== | Steps to test hfp_ag | | | | 1. Print 'help' to gain overview of commands | | 2. Setup a service level connection | | 3. Run hfp_ag to test | | | ================================================= I (1689) BT_APP_HF: ble_gattc_init in. I (1699) APP_GATTC: REG_EVT I (1699) APP_GATTC: scan param set complete hfp_ag> hfp_ag> W (7539) BT_APPL: new conn_srvc id:5, app_id:0 I (7539) BT_APP_HF: APP HFP event: CONNECTION_STATE_EVT I (7539) BT_APP_HF: --connection state CONNECTED, peer feats 0x0, chld_feats 0x0 I (7609) BT_APP_HF: APP HFP event: CIND_RESPONSE_EVT I (7609) BT_APP_HF: --CIND Start. I (7639) BT_APP_HF: APP HFP event: CONNECTION_STATE_EVT I (7639) BT_APP_HF: --connection state SLC_CONNECTED, peer feats 0x3f, chld_feats 0x4013 I (7659) BT_APP_HF: APP HFP event: NREC_RESPONSE_EVT I (7659) BT_APP_HF: --NREC status is: NREC DISABLE. I (7669) BT_APP_HF: APP HFP event: VOLUME_CONTROL_EVT I (7669) BT_APP_HF: --Volume Target: SPEAKER, Volume 13 I (7719) BT_APP_HF: APP HFP event: UNKNOW_AT_CMD I (7719) BT_APP_HF: --UNKOW AT CMD: +XAPL=0000-0000-0100,7 I (7739) BT_APP_HF: APP HFP event: UNKNOW_AT_CMD I (7739) BT_APP_HF: --UNKOW AT CMD: +IPHONEACCEV=2,1,8,2,0 I (7789) BT_APP_HF: APP HFP event: CLCC_RESPONSE_EVT I (7789) BT_APP_HF: --Calling Line Identification. I (7829) BT_APP_HF: APP HFP event: UNKNOW_AT_CMD I (7829) BT_APP_HF: --UNKOW AT CMD: +CSRSF=0,0,0,1,0,0,0 hfp_ag> hfp_ag> hfp_ag> hfp_ag> hfp_ag> hfp_ag> hfp_ag> blescan ble start scanning I (17059) APP_GATTC: scan start success I (17089) APP_GATTC: 1d a8 c0 ac e8 da I (17089) APP_GATTC: searched Adv Data Len 31, Scan Response Len 0 I (17089) APP_GATTC: searched Device Name Len 0 I (17099) APP_GATTC: I (17119) APP_GATTC: 53 7b 57 35 54 29 I (17119) APP_GATTC: searched Adv Data Len 17, Scan Response Len 0 I (17119) APP_GATTC: searched Device Name Len 0 I (17129) APP_GATTC: I (17129) APP_GATTC: 5d be a4 a5 2f 6f I (17129) APP_GATTC: searched Adv Data Len 31, Scan Response Len 0 I (17149) APP_GATTC: searched Device Name Len 0 I (17149) APP_GATTC: hfp_ag> I (17189) APP_GATTC: 1d a8 c0 ac e8 da I (17199) APP_GATTC: searched Adv Data Len 31, Scan Response Len 0 I (17199) APP_GATTC: searched Device Name Len 0 I (17209) APP_GATTC: I (17219) APP_GATTC: 2a 67 91 78 8e 5d I (17219) APP_GATTC: searched Adv Data Len 31, Scan Response Len 0 I (17219) APP_GATTC: searched Device Name Len 0 I (17229) APP_GATTC: I (17319) APP_GATTC: d4 f2 5d 21 96 5a I (17319) APP_GATTC: searched Adv Data Len 31, Scan Response Len 0 I (17319) APP_GATTC: searched Device Name Len 0 I (17329) APP_GATTC: Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled. Core 0 register dump: PC : 0x4001ac19 PS : 0x00060e31 A0 : 0x800881fe A1 : 0x3ffbe7f0 A2 : 0x008479d4 A3 : 0x00000007 A4 : 0x00000000 A5 : 0x3ffb8360 A6 : 0x000005b4 A7 : 0x00000000 A8 : 0x0000002f A9 : 0x00000507 A10 : 0x00000000 A11 : 0x3ffcc584 A12 : 0x00000000 A13 : 0x00000001 A14 : 0x00000000 A15 : 0x3ffb8360 SAR : 0x0000001e EXCCAUSE: 0x0000001c EXCVADDR: 0x008479d8 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Backtrace:0x4001ac16:0x3ffbe7f0 0x400881fb:0x3ffbe810 0x40085502:0x3ffbe850 0x4008aaea:0x3ffbe870 0x4008b603:0x3ffbe890 0x40082b59:0x3ffbe8b0 0x40170413:0x3ffbd690 0x400da8ca:0x3ffbd6b0 0x40091fb5:0x3ffbd6d0 0x40093cd9:0x3ffbd6f0 0x400881fb: r_lld_evt_schedule at ??:? 0x40085502: r_ea_finetimer_isr at ??:? 0x4008aaea: r_rwbt_isr at ??:? 0x4008b603: r_rwbtdm_isr_wrapper at intc.c:? 0x40082b59: _xt_lowint1 at /home/liupeng/WorkSpace/espressif/esp/esp-idf/components/freertos/port/xtensa/xtensa_vectors.S:1105 0x40170413: cpu_ll_waiti at /home/liupeng/WorkSpace/espressif/esp/esp-idf/examples/bluetooth/bluedroid/coex/bt_ble_coex/build/../../../../../../components/hal/esp32/include/hal/cpu_ll.h:183 (inlined by) esp_pm_impl_waiti at /home/liupeng/WorkSpace/espressif/esp/esp-idf/components/esp_pm/pm_impl.c:827 0x400da8ca: esp_vApplicationIdleHook at /home/liupeng/WorkSpace/espressif/esp/esp-idf/components/esp_common/src/freertos_hooks.c:63 0x40091fb5: prvIdleTask at /home/liupeng/WorkSpace/espressif/esp/esp-idf/components/freertos/tasks.c:3839 (discriminator 1) 0x40093cd9: vPortTaskWrapper at /home/liupeng/WorkSpace/espressif/esp/esp-idf/components/freertos/port/xtensa/port.c:168 |
只有小组成员才能发言,加入小组>>
471 浏览 0 评论
994 浏览 0 评论
1710 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1370 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1289浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2387浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2579浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-14 18:40 , Processed in 0.984880 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
365
