各位大佬好, 打扰了,最近尝试 zynq7020 上使用 rt-thread, 发现了一个奇怪的问题, 在启用文件系统后, shell 线程触发了异常, 通过 map 文件定位到是在调用 strcat 时出现了问题。串口打印并未发现参数有误。尝试用一个自定义的 strcat 替换掉 strcat, 就可以正常运行了。请问哪位大佬知道可能是什么原因? 谢谢 报错: initialize init_th:0 done tshell 20 running 0x00000040 0x00001000 13% 0x0000000a 000 diff --git a/rt-thread/components/finsh/shell.c b/rt-thread/components/finsh/shell.c char *tmp = dest; while (*dest)
while ((*dest++ = *src++) != '\0')
return tmp; const char *finsh_get_prompt(void)
initialize init_th:0 done .text.strcat 0x0011556c 0x40 d:/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7-ar/thumb/fpu\libc.a(lib_a-strcat.o) |
6个回答
感觉是非对齐的原因,反汇编再根据寄存器查一下。
感谢大佬的回复,请问您指的是链接脚本的字节对齐设置吗? 个人对汇编了解不多,想请大佬帮忙再看看,万分感谢
112d5c: ebfffcee bl 11211c 112d60: e30b0c14 movw r0, #48148 ; 0xbc14 112d64: e3400011 movt r0, #17 112d68: fa000ddb blx 1164dc 112d6c: e1a03000 mov r3, r0 112d70: e1a02003 mov r2, r3 112d74: e30b3c14 movw r3, #48148 ; 0xbc14 112d78: e3403011 movt r3, #17 112d7c: e0822003 add r2, r2, r3 112d80: e3093030 movw r3, #36912 ; 0x9030 112d84: e3403011 movt r3, #17 112d88: e1d330b0 ldrh r3, [r3] 112d8c: e1c230b0 strh r3, [r2] 112d90: e30b3c14 movw r3, #48148 ; 0xbc14 112d94: e3403011 movt r3, #17 112d98: e1a00003 mov r0, r3 112d9c: e8bd8830 pop {r4, r5, fp, pc} 00112da0 running on cpu 0 data abort:Execption: r00:0x00000005 r01:0x7f7f8000 r02:0x0011bc19 r03:0x0000003e r04:0x0011bc18 r05:0xdeadbeef r06:0xdeadbeef r07:0xdeadbeef r08:0xdeadbeef r09:0xdeadbeef r10:0xdeadbeef fp :0x0011eee4 ip :0x01010101 sp :0x0011eed8 lr :0x00112d6c pc :0x00112d94 cpsr:0x80000013 thread pri status sp stack size max used left tick error ---------------- --- ------- ---------- ---------- ------ ---------- --- tshell 20 running 0x00000040 0x00001000 13% 0x0000000a 000 test 20 suspend 0x000000a4 0x00000400 16% 0x00000005 000 ulog_async 30 ready 0x00000044 0x00000400 06% 0x00000014 000 tidle0 31 ready 0x00000040 0x00000200 12% 0x00000020 000 init 10 close 0x0000007c 0x00000800 15% 0x00000007 000 shutdown... (0) assertion failed at function:rt_hw_cpu_shutdown, line number:38 |
反汇编一般是编译生成的asm文件,也可以用编译器命令arm-none-eabi-objdump -D elf文件生成反汇编文件,一般是看你PC寄存器的值,说明CPU在此处触发了异常,然后再看LR的值,看看是谁是父函数,然后进行进一步分析,你截图里面是有PC与LR的值的,可以分析下。
或者从strcat本身分析,是不是可能是buffer溢出、地址非对齐等方面进行排查。 |
今天尝试写了几个测试函数,发现问题似乎与 strcat 的第二个参数直接给了字符串字面量有关。怀疑与链接 有关。不知各位大佬如何看,谢谢 !
测试代码: #include int test_strcat(int argc, char **argv) { char tmp[20] = "0n"; static const char s2[] = "12n"; strcat(tmp, s2); rt_kprintf(tmp); return 0; } MSH_CMD_EXPORT(test_strcat, test strcat); int test_strcat_2(int argc, char **argv) { char tmp[20] = "0n"; strcat(tmp, "12"); rt_kprintf(tmp); return 0; } MSH_CMD_EXPORT(test_strcat_2, test strcat); 测试结果: test_strcat 正常,test_strcat_2 崩了 msh />test_strcat 0 12 msh />test_strcat_2 test_strcat_2 msh />test_strcat_2data abort:Execption: r00:0x0012d9c5 r01:0x0012db05 r02:0x80000000 r03:0x00000074 r04:0x0012d93c r05:0x0012d93c r06:0xdeadbeef r07:0xdeadbeef r08:0xdeadbeef r09:0xdeadbeef r10:0xdeadbeef fp :0x0012ebc4 ip :0x0012d9ba sp :0x0012ebb0 lr :0x00121e14 pc :0x00104a7a cpsr:0xa0000033 thread pri status sp stack size max used left tick error ---------------- --- ------- ---------- ---------- ------ ---------- --- tshell 20 running 0x000000cc 0x00001000 13% 0x00000001 000 test 20 suspend 0x000000a0 0x00000400 15% 0x00000005 000 ulog_async 30 suspend 0x000000ac 0x00000400 25% 0x00000009 000 tidle0 31 ready 0x00000070 0x00000200 28% 0x00000014 000 shutdown... (0) assertion failed at function:rt_hw_cpu_shutdown, line number:38 反汇编结果 pc 似乎运行到了 memcpy 104a62: d008 beq.n 104a76 104a64: 07d2 lsls r2, r2, #31 104a66: bf1c itt ne 104a68: f811 3b01 ldrbne.w r3, [r1], #1 104a6c: f800 3b01 strbne.w r3, [r0], #1 104a70: d301 bcc.n 104a76 104a72: 880b ldrh r3, [r1, #0] 104a74: 8003 strh r3, [r0, #0] 104a76: 4660 mov r0, ip 104a78: 4770 bx lr 104a7a: bf00 nop 104a7c: 2a08 cmp r2, #8 104a7e: d313 bcc.n 104aa8 104a80: 078b lsls r3, r1, #30 104a82: d0b1 beq.n 1049e8 104a84: f010 0303 ands.w r3, r0, #3 104a88: d0ae beq.n 1049e8 两个测试函数的反汇编结果: 00104cb4 104cb4: e92d4800 push {fp, lr} 104cb8: e28db004 add fp, sp, #4 104cbc: e24dd020 sub sp, sp, #32 104cc0: e50b0020 str r0, [fp, #-32] ; 0xffffffe0 104cc4: e50b1024 str r1, [fp, #-36] ; 0xffffffdc 104cc8: e3a03ea3 mov r3, #2608 ; 0xa30 104ccc: e50b3018 str r3, [fp, #-24] ; 0xffffffe8 104cd0: e24b3014 sub r3, fp, #20 104cd4: e3a02000 mov r2, #0 104cd8: e5832000 str r2, [r3] 104cdc: e5832004 str r2, [r3, #4] 104ce0: e5832008 str r2, [r3, #8] 104ce4: e583200c str r2, [r3, #12] 104ce8: e24b3018 sub r3, fp, #24 104cec: e3081278 movw r1, #33400 ; 0x8278 104cf0: e3401012 movt r1, #18 104cf4: e1a00003 mov r0, r3 104cf8: fa008061 blx 124e84 104cfc: e24b3018 sub r3, fp, #24 104d00: e1a00003 mov r0, r3 104d04: eb000a4c bl 10763c 104d08: e3a03000 mov r3, #0 104d0c: e1a00003 mov r0, r3 104d10: e24bd004 sub sp, fp, #4 104d14: e8bd8800 pop {fp, pc} 00104d18 104d18: e92d4800 push {fp, lr} 104d1c: e28db004 add fp, sp, #4 104d20: e24dd020 sub sp, sp, #32 104d24: e50b0020 str r0, [fp, #-32] ; 0xffffffe0 104d28: e50b1024 str r1, [fp, #-36] ; 0xffffffdc 104d2c: e3a03ea3 mov r3, #2608 ; 0xa30 104d30: e50b3018 str r3, [fp, #-24] ; 0xffffffe8 104d34: e24b3014 sub r3, fp, #20 104d38: e3a02000 mov r2, #0 104d3c: e5832000 str r2, [r3] 104d40: e5832004 str r2, [r3, #4] 104d44: e5832008 str r2, [r3, #8] 104d48: e583200c str r2, [r3, #12] 104d4c: e24b3018 sub r3, fp, #24 104d50: e1a00003 mov r0, r3 104d54: fa008089 blx 124f80 104d58: e1a03000 mov r3, r0 104d5c: e1a02003 mov r2, r3 104d60: e24b3018 sub r3, fp, #24 104d64: e0832002 add r2, r3, r2 104d68: e3053b78 movw r3, #23416 ; 0x5b78 104d6c: e3403012 movt r3, #18 104d70: e1d310b0 ldrh r1, [r3] 104d74: e5d33002 ldrb r3, [r3, #2] 104d78: e1c210b0 strh r1, [r2] 104d7c: e5c23002 strb r3, [r2, #2] 104d80: e24b3018 sub r3, fp, #24 104d84: e1a00003 mov r0, r3 104d88: eb000a2b bl 10763c 104d8c: e3a03000 mov r3, #0 104d90: e1a00003 mov r0, r3 104d94: e24bd004 sub sp, fp, #4 104d98: e8bd8800 pop {fp, pc} |
建议明确一下第2个参数字符串的地址,可以放到全局变量位置,方便在map文件中确认地址,
测试时,同时在此地址上加1,以改变地址对比验证。 可以根据map中字符串地址,以及dump出来的寄存器交叉确认。 你是不是cache没开?没开时是不能非对齐访问的。 |
多谢,确实是 cache 没开的原因。。。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1033 浏览 0 评论
2877 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9386 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2898 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2302 浏览 1 评论
/9
GMT+8, 2025-12-2 09:18 , Processed in 0.834763 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4678
