最近2周,文档服务器访问不稳定:偶尔可以访问,大多数时候不能访问。
以下是我从阿里云服务器上curl的信息: ----- # curl https://docs.espressif.com curl: (60) SSL certificate problem: certificate has expired More details here: http://curl.haxx.se/docs/sslcerts.html curl performs SSL certificate verification by default, using a "bundle" of Certificate Authority (CA) public keys (CA certs). If the default bundle file isn't adequate, you can specify an alternate file using the --cacert option. If this HTTPS server uses a certificate signed by a CA represented in the bundle, the certificate verification probably failed due to a problem with the certificate (it might be expired, or the name might not match the domain name in the URL). If you'd like to turn off curl's verification of the certificate, use the -k (or --insecure) option. ---- 头疼。 |
只有小组成员才能发言,加入小组>>
988 浏览 1 评论
554浏览 6评论
463浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
447浏览 5评论
448浏览 4评论
421浏览 4评论
GMT+8, 2024-11-29 10:25 , Processed in 0.673488 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
