扫一扫,分享给好友
我用的芯片是STM32,以下程序可以编译通过,但是TFT是白屏,大侠帮忙看看,指出问题,小弟不胜感激! #include "stm32f10x.h" #include "stm32_eval.h" #include #include "ili9320.h" #include "stm32f10x_conf.h" #include "ili9320_api.h" #include "stm32f10x_adc.h" #include "stm32f10x_dma.h" #include "ARMJISHU_TouchScreen_ADS7843.h" #define BmpHeadSize (54) #define DR_ADDRESS ((uint32_t)0x4001244C) //ADC1 DR寄存器基地址 ADC_InitTypeDef ADC_InitStructure; //ADC初始化结构体声明 DMA_InitTypeDef DMA_InitStructure; //DMA初始化结构体声明 __IO uint16_t ADCConvertedValue; // ADC为12位模数转换器,只有ADCConvertedValue的低12位有效 void ADC_GPIO_Configuration(void); void Num2String(uint32_t Num,uint8_t *Ptr); #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ static void Delay_ARMJISHU(__IO uint32_t nCount) { for (; nCount != 0; nCount--) { if(GPIO_ADS7843_INT_VALID) { ARMJISHU_TouchScreen_ADS7843(); } } } void ili9320_PutStr_16x24(u16 StartX, u16 StartY, u8 *str, u16 len, u16 charColor, u16 bkColor) { u16 i; u8 *pstr = str; for (i=0 ;i ili9320_PutChar_16x24((StartX+16*i),StartY,*pstr++,charColor,bkColor); } } void ili9320_PutStr_16x24_Center(u16 StartY, u8 *str, u16 len, u16 charColor, u16 bkColor) { u16 StartX; StartX = (320 - 16*len)/2; ili9320_PutStr_16x24(StartX,StartY, str, len, charColor, bkColor); } int main(void) { u16 i, len; u8 AD_CharData[4]; u8 *str; u16 charColor; u16 bkColor; len = sizeof(AD_CharData)-1; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA时钟 /* DMA1 channel1 configuration ----------------------------------------------*/ DMA_DeInit(DMA1_Channel1); //开启DMA1的第一通道 DMA_InitStructure.DMA_PeripheralBaseAddr = DR_ADDRESS; //DMA对应的外设基地址 DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADCConvertedValue; //内存存储基地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //DMA的转换模式为SRC模式,由外设搬移到内存 DMA_InitStructure.DMA_BufferSize = 1; //DMA缓存大小,1个 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //接收一次数据后,设备地址禁止后移 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; //关闭接收一次数据后,目标内存地址后移 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //定义外设数据宽度为16位 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //DMA搬移数据尺寸,HalfWord就是为16位 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //转换模式,循环缓存模式。 DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA优先级高 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //M2M模式禁用 DMA_Init(DMA1_Channel1, &DMA_InitStructure); /* Enable DMA1 channel1 */ DMA_Cmd(DMA1_Channel1, ENABLE); /* Enable ADC1 and GPIOC clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE); //使能ADC和GPIOC时钟 /* ADC1 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //独立的转换模式 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //开启扫描模式 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //开启连续转换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //ADC外部开关,关闭状态 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //对齐方式,ADC为12位中,右对齐方式 ADC_InitStructure.ADC_NbrOfChannel = 1; //开启通道数,1个 ADC_Init(ADC1, &ADC_InitStructure); /* ADC1 regular channel13 configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 1, ADC_SampleTime_55Cycles5); //ADC通道组, 第13个通道 采样顺序1,转换时间 /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); //ADC命令,使能 /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); //开启ADC1 /* Enable ADC1 reset calibaration register */ ADC_ResetCalibration(ADC1); //重新校准 /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); //等待重新校准完成 /* Start ADC1 calibaration */ ADC_StartCalibration(ADC1); //开始校准 /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); //等待校准完成 /* Start ADC1 Software Conversion */ ADC_SoftwareStartConvCmd(ADC1, ENABLE); //连续转换开始,ADC通过DMA方式不断的更新RAM区。 ili9320_Initializtion(); ili9320_Clear(Blue); while (1) { Num2String(ADCConvertedValue,AD_CharData); ili9320_PutStr_16x24_Center(20, AD_CharData, len,charColor, bkColor); Delay_ARMJISHU(10000000); } } PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) { } return ch; } #ifdef USE_FULL_ASSERT void assert_failed(uint8_t* file, uint32_t line) { while (1) { } } #endif void ADC_GPIO_Configuration(void) //ADC配置函数 { GPIO_InitTypeDef GPIO_InitStructure; /* Configure PC.00 (ADC Channel10) as analog input -------------------------*/ //PC0 作为模拟通道10输入引脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //管脚1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//输入模式 GPIO_Init(GPIOC, &GPIO_InitStructure); //GPIO组 } //int整型数转换成字符串 void Num2String(uint32_t Num,uint8_t *Ptr) { uint8_t instr[4]; uint8_t i=4; uint8_t k; do { instr[--i] = Num%10+'0'; Num/=10; }while(Num!=0); for(k=i;k<4;k++) { *Ptr++=instr[k]; } *Ptr = ' |
